TrueNAS SCALE 22.12.1 has been released!
Kris Moore
SVP of Engineering
Administrator
Glad to hear it! Did mine this morning as well, no surprises along the way.
morganL
Captain Morgan
Administrator
Welcome all good and bad update stories here.
If there are any major issues, please also start a new thread.
rusty6285
Hi folks, I'm new to the forum and also new to TrueNAS as of a few weeks ago.
I just updated to this new release, and I cannot edit any existing replication tasks. I get the following error (all was working fine prior to update)
"[EINVAL] replication_update.sudo: null not allowed"
I can create brand new replication tasks, but cannot edit them after, same error.
Wondering if anyone else can replicate?
Trevor68
Update went fine, only 2 of 14 apps would start, I see these were the only 2 using PVC storage.
Once I disabled Hostpath Validation the other 12 started fine. I note that I had Hostpath Validation enabled ok before this update.
rusty6285
I got a response to same post in reddit:
Yep, that's a legit bug. We're tracking it here now:
https://ixsystems.atlassian.net/browse/NAS-120432
We'll post updated / details on work-arounds on the Jira ticket as they land.
HoneyBadger
actually does care
Administrator
Are you by any chance using hostPath on a child directory of a parent share, eg:
SMB share: /mnt/Poolname/media
hostPath: /mnt/Poolname/media/Movies
Trevor68
I absolutely am, as that was the original bluefin workaround, I am unsure best method now that is not possible? I'm know a lot of home users like myself serve media and would also like to know the recommended method for adding it?
Disable host path validation? As was discussed extensively when 22.12.0 was released?
Trevor68
Maybe, I would be interested in what changed in this release though
The popular workaround (using a subdirectory of the share as a host path) exploited a bug in the host path validation logic, as many of us (including me) suspected at the outset. That bug has now been fixed.
Tony-1971
Upgrade without problems.
Thank you!
morganL
Captain Morgan
Administrator
It looks like about 3,000 systems have updated... host path validation remains the primary issue to be aware of, but not unexpected.
andyjay777
Upgraded from 22.02.04 without issue.
I did preemptively change Plex to use NFS for media libraries (rather than hostpath). Took <5 mins to make that change before the upgrade.
Trevor68
Cool, can those NFS shares be accessed from a windows box?
andyjay777
Trevor68
Gotcha thanks
Patrick M. Hausen
What is the reasoning behind that? I mean, the very reason for hosting containerized applications on a NAS is to have file sharing access while simultaneously mounting the dataset into a container. This is never a problem on CORE and with jails. And NFS is not a substitute for a local mount. The file system semantics are completely different.
soopaman
