The Calomel write up should be reflected in the forums here. It is much more useful than what I found here. Happy to send it to you.Hmmm. Thank you.
The Calomel write up should be reflected in the forums here. It is much more useful that what I found here. Happy to send it to you.
You are of course welcome to link one to me... Could be useful on this thread...We do not plagiarize documents from other sources here. You are of course welcome to compose your own. Also, since I'm aware of at least a dozen discussions of various sets of tunables for various situations and use cases here, I find it puzzling that you would not have stumbled across at least one of those.
If there really is any gain.
Seems that with sync off, write speed is 10gbs full on, staturated the network card.
Can the read be improved? The pool is a 16bay stripe.
Hello,Hopefully this means "10Gbit/s". This was explained back in post #7 in this thread, writes will generally go as fast as the write cache or writing to the pool allows.
Read speeds can be improved by:
1) Adding RAM, which provides more ARC, which is your read cache
2) Selecting tunables that increase the prefetch, which really only works for sequential workloads
3) Increase the parallelism of the clients, which is incredibly effective at extracting more read speed, but only in aggregate
Another example is my supermicro machine, with an lsi 8885, 16bay raid5, i get 850 read and 900write.
RAM is your friend there. not just more, but the fastest speed of ram for whatever motherboard you have and then "more" is better. What controller are you using specifically and what firmware? LSI produces a solid line of controllers that Truenas/freeBSD support pretty well. As much as Intel does, I find that Chelsio NIC perform a bit better overall. Almost all switches, Quanta, Cisco, Intel, you name it all appear to perform very close to one another, so it likely in not the bottle neck.Oh my God. That seems to solve the write issue.
Read speed still 300MB/s.
Would the sync feature affect in somehow the transfer? We are under 2 ups backups, so the poweroff risk is manageble.
I wont go into macos Monterey performance, windows is perfect:))
Thank you!!
