Writes seem way too slow on ZFS pool.
norbs
Tested on a linux VM and I'm getting an average of about 550MB/s+ read but only 50MB/s to 60MB/s write... I also attached the iostat results that I ran on the freenas box itself.
System is a Xeon e3-1231 v3 system with 32GB ECC ram which is hosting iSCSI over 10Gb link to ESXi host. Using latest 9.3.1 stable train and going to latest build of ESXi 6.
All drives are connected through an LSI 9211-8i.
The pool config:
  pool: ZFS10
state: ONLINE
  scan: scrub repaired 0 in 9h18m with 0 errors on Sat Feb 27 09:18:55 2016
        NAME                                            STATE     READ WRITE CKS                  UM
        ZFS10                                           ONLINE       0     0                       0
          mirror-0                                      ONLINE       0     0                       0
            gptid/1ba2de10-d0fd-11e4-872a-000c294bff6f  ONLINE       0     0                       0
            gptid/1c8b1ac3-d0fd-11e4-872a-000c294bff6f  ONLINE       0     0                       0
          mirror-1                                      ONLINE       0     0                       0
            gptid/1d65cb0a-d0fd-11e4-872a-000c294bff6f  ONLINE       0     0                       0
            gptid/1e3962c7-d0fd-11e4-872a-000c294bff6f  ONLINE       0     0                       0
          mirror-2                                      ONLINE       0     0                       0
            gptid/1f1da057-d0fd-11e4-872a-000c294bff6f  ONLINE       0     0                       0
            gptid/1fee8dcf-d0fd-11e4-872a-000c294bff6f  ONLINE       0     0                       0
        logs
          gptid/4d52bc10-efb1-11e4-9401-000c294bff6f    ONLINE       0     0                       0
        cache
          gptid/58b47d2e-efb1-11e4-9401-000c294bff6f    ONLINE       0     0                       0
errors: No known data errors
I'm using 6 X WD 4TB drives and 1 intel s3700 ssd configured to only 10GB space for logs and 1 intel 520 for cache.
Sync is set to always but even with it set to disabled its not much faster.
I did try auto tune and it didn't have much of an impact.
  • iozone.txt
norbs
Added my replies to your quote, sorry for the weird format:
Mod note- edited it into something usable, so I can both reply and avoid clawing my eyes out - JG
How full is the pool?
The pool itself is 55% used but I did make the iSCSI dataset to be just a little bigger than the VMFS datastore sitting on it, so the datasets are closer to 99%. I can expand it if you think it will benefit it.
What's fragmentation like?
Not sure how to verify that, googled a bit and could not find anything I could quickly run and post.
Why in the world would you have L2ARC on such a small system?
Because despite being asked that and second guessing myself each time, whenever I remove the l2arc I get worse performance. With an l2arc the MAX performance is slightly lower (2-3%), but overall I get consistent performance and higher average performance. After you posted this, I removed it and same results. (and still 40-60MB/s write).
Writes using a S3700 will always be somewhat slowish because there's more latency inherent in the attachment hardware; see https://forums.freenas.org/index.php?threads/hw-raid-for-zil-question.30210/#post-194135
I mean I get sata vs nvme is significantly slower but 50-60MB/s slow? Pretty sure you could easily hit 200MB/s writes on these drives if not way higher.
What does gstat look like while you've got the system pegged writing?
%Busy seems to bounce around 60-80.
dT: 10.001s  w: 10.000s
L(q)  ops/s    r/s   kBps   ms/r    w/s   kBps   ms/w   %busy Name
    0      0      0      0    0.0      0      0    0.0    0.0| da0
    1    298      0      0    0.0    286  20039    0.7   56.9| da1
    1    292      0     13   33.2    281  19564    0.8   62.1| da2
    1    295      0      0    0.0    283  19732    1.1   67.4| da3
    0    683      0      0    0.0    616  51257    2.2   22.8| da4
    1    297      0      0    0.0    286  20052    0.7   54.7| da5
    1    294      0      0    0.0    283  19718    0.9   63.7| da6
    0      0      0      0    0.0      0      0    0.0    0.0| da0p1
    0      0      0      0    0.0      0      0    0.0    0.0| da1p1
    1    298      0      0    0.0    286  20039    0.7   57.0| da1p2
    0      0      0      0    0.0      0      0    0.0    0.0| da2p1
    1    292      0     13   33.2    281  19564    0.8   62.2| da2p2
    0      0      0      0    0.0      0      0    0.0    0.0| da3p1
    1    295      0      0    0.0    283  19732    1.1   67.5| da3p2
    0    683      0      0    0.0    616  51257    2.2   22.8| da4p1
    0      0      0      0    0.0      0      0    0.0    0.0| da5p1
    1    297      0      0    0.0    286  20052    0.7   54.8| da5p2
    0      0      0      0    0.0      0      0    0.0    0.0| da6p1
    1    294      0      0    0.0    283  19718    0.9   63.8| da6p2
    1    295      0      0    0.0    284  19860    0.9   65.7| da7
    0      0      0      0    0.0      0      0    0.0    0.0| ada0
    0      0      0      0    0.0      0      0    0.0    0.0| gptid/58b47d2e-efb1-11e4-9401-000c294bff6f
    1    298      0      0    0.0    286  20039    0.7   57.1| gptid/1fee8dcf-d0fd-11e4-872a-000c294bff6f
    0      0      0      0    0.0      0      0    0.0    0.0| da5p1.eli
    1    292      0     13   33.2    281  19564    0.8   62.2| gptid/1e3962c7-d0fd-11e4-872a-000c294bff6f
    0      0      0      0    0.0      0      0    0.0    0.0| da7p1.eli
    1    295      0      0    0.0    283  19732    1.1   67.6| gptid/1ba2de10-d0fd-11e4-872a-000c294bff6f
    0    683      0      0    0.0    616  51257    2.2   22.9| gptid/4d52bc10-efb1-11e4-9401-000c294bff6f
    0      0      0      0    0.0      0      0    0.0    0.0| da1p1.eli
    1    297      0      0    0.0    286  20052    0.7   54.9| gptid/1f1da057-d0fd-11e4-872a-000c294bff6f
    0      0      0      0    0.0      0      0    0.0    0.0| da2p1.eli
    1    294      0      0    0.0    283  19718    0.9   63.9| gptid/1d65cb0a-d0fd-11e4-872a-000c294bff6f
    1    295      0      0    0.0    284  19860    0.9   65.7| da7p2
    0      0      0      0    0.0      0      0    0.0    0.0| ada0p1
    0      0      0      0    0.0      0      0    0.0    0.0| ada0p2
    0      0      0      0    0.0      0      0    0.0    0.0| da6p1.eli
    1    295      0      0    0.0    284  19860    0.9   65.8| gptid/1c8b1ac3-d0fd-11e4-872a-000c294bff6f
    0      0      0      0    0.0      0      0    0.0    0.0| gptid/93a63019-e683-11e5-8618-0cc47a08e0a0
    0      0      0      0    0.0      0      0    0.0    0.0| da3p1.eli
norbs
Turned out to be a freespace in the dataset issue. As soon as I added about 25% freespace the write speed instantly quadrupled from 50MB/s to 200MB/s. Thanks for pointing me in the right direction.
norbs
A bit dramatic, but OK thanks.
HoneyBadger
actually does care
Administrator
For those Googling later, the command is
zpool list
And you want to find the result under the FRAG column, notably this shows fragmentation of the free space in your pool, not the existing data.
norbs
zpool list
NAME           SIZE  ALLOC   FREE  EXPANDSZ   FRAG    CAP  DEDUP  HEALTH  ALTROOT
ZFS10         10.9T  6.32T  4.56T         -    26%    58%  1.00x  ONLINE  /mnt
Yikes 26%, a lot higher than I expected. I made a new zvol which I'm migrating all iSCSI to, I'm assuming that should help with the fragmentation?
Thanks HoneyBadger!
jgreco
Resident Grinch
Call it a friendly request not to make other people do your formatting. It'd be preferable to just not inline your comments at all. The forumware strips out previous replies in comments, so doing it the way that you did it makes it both very difficult to read, AND then when I reply, it would have wiped out the entire quoted message.
I didn't mean to leave that hanging. It was intended to be directly followed up by a more in-depth response, which I got busy and didn't provide. Sorry 'bout that.
The dataset size is irrelevant because they're still part of the pool, and using the space on the pool.
If you have a high degree of fragmentation, 55% is already going to be pathetically slow. The two variables here are the pool percent-full and the pool fragmentation. A pool that's 90% full and 0% fragmented will seem really fast. Over time, what happens in a copy-on-write (CoW) filesystem like ZFS is that you get a lot of fragmentation. Free space combats fragmentation. Over time, speeds will decrease until you get to a "steady state" where things settle into a "this is about as bad as it gets."
If we look at a graph of steady state performance on a single drive:
So, see, the thing here is that a single drive with random I/O on it would normally only be capable of maybe 150 IOPS or about 600KB/sec. What you'll notice is that ZFS is actually making it possible for that drive to go a lot faster for writes. But there are some caveats: first, ZFS treats sequential and random writes very similarly. Normally storage guys think of sequential and random I/O as very different things, but ZFS basically just looks for a nice contiguous run of blocks to allocate, and starts writing. What this means is that as a pool fills, both sequential and random write speeds suffer. It also means that fragmentation can become a significant performance problem. We mitigate the read performance issues associated with fragmentation by using lots of RAM (ARC) and L2ARC. We mitigate the write performance issue primarily by throwing lots of extra space at the pool.
Do note in particular that at 10% occupancy, a one disk pool, at its worst, is likely to seem a full TEN TIMES faster at random writes than the underlying storage device would be capable of in a normal environment.
The real world implications get hard to wrap your head around.
That's kind of typical. People often think of the L2ARC as something to make their stuff go faster, but in reality if a single read is fulfilled from the L2ARC rather than the pool, you're not likely to be able to tell. The L2ARC is more usefully thought of as a tool to reduce the load on your pool, which will in turn make a very busy pool seem more responsive and tends to result in better performance for the stuff that's being used heavily. However, at only 32GB, you're also going to be stressing the available memory. We usually don't recommend L2ARC until you have at least 64GB of RAM. This is a complex thing, though, partially dependent on how much stuff you're actually using on the volume.
Of course. An NVMe drive can hit gigabytes per second of writes. If that's all that was involved. It's not. A sync write starts at the client, and has to make a very complicated round trip, in lockstep, for EACH WRITE REQUEST. The "sync" part of "sync write" means that the client is requesting that the current data block be confirmed as written to disk before the write() system call returns to the client. Without sync writes, a client is free to just stack up a bunch of write requests and then they can send over a slowish channel, and they arrive when they can. Look at the layers:
Client initiates a write syscall
Client filesystem processes request
Filesystem hands this off to the network stack as NFS or iSCSI
Network stack hands this packet off to network silicon
Silicon transmits to switch
Switch transmits to NAS network silicon
NAS network silicon throws an interrupt
NAS network stack processes packet
Kernel identifies this as a NFS or iSCSI request and passes to appropriate kernel thread
Kernel thread passes request off to ZFS
ZFS sees "sync request", sees an available SLOG device
ZFS pushes the request to the SAS device driver
Device driver pushes to LSI SAS silicon
LSI SAS chipset serializes the request and passes it over the SAS topology
SAS or SATA SSD deserializes the request
SSD controller processes the request and queues for commit to flash
SSD controller confirms request
SSD serializes the response and pssses it back over the SAS topology
LSI SAS chipset receives the response and throws an interrupt
SAS device driver gets the acknowledgment and passes it up to ZFS
ZFS passes acknowledgement back to kernel NFS/iSCSI thread
NFS/iSCSI thread generates an acknowledgement packet and passes it to the network silicon
NAS network silicon transmits to switch
Switch transmits to client network silicon
Client network silicon throws an interrupt
Client network stack receives acknowledgement packet and hands it off to filesystem
Filesystem says "yay, finally, what took you so long" and releases the syscall, allowing the client program to move on.
That's what happens for EACH sync write request. It always amazes me that a network based storage solution can be doing that for each block and yet it is still possible, under optimal conditions, to get a few hundred MBytes/sec write speeds.
That strikes me as probably a fair bit of fragmentation, where having some additional free space is probably the best solution to help increase performance.
The crap part about ZFS is that for VM storage, you really want to use mirrors, and with mirrors, if you have a resiliency goal of something like "a single disk failure shall not compromise redundancy" then that means three-way mirrors. Then ZFS only performs well if you have ~25-50% pool fill, so you end up in this sorta-unhappy space where to get 1TB of really good VM storage you might need 12TB of raw disk space (3 4TB disks at 25% full, mirrored 3 way). But on the other hand, it'll really fly if you go and do it right, and it will still be a lot less expensive than commercial solutions.
norbs
First off, thanks for taking the time to write that lengthy and informative response.
I think the problem was a quota on the dataset which was just a tiny bit larger than the actual VMFS Datastore. After removing the quota, writes went from 50MB/s to 200MB/s. I'm not even sure why I even had a quota in the first place but it was definitely affecting performance.
As far as fragmentation, is there any way to easily address it?
I did manage to drop my pool consumption from 55% to 41% but the fragmentation only dropped by 1% after that.
I'm tempted to just do a complete backup and then restore of all the data but it would be time consuming.
Lastly I'm curious if there is any type of work going on towards all SSD freenas arrays?
Seems like EMC Xbrick and Pure both use dedupe and compression and while I get freenas has both of those, I'm wondering how it actually perform well enough and if it's a viable option.
https://forums.freenas.org/index.php?threads/defragging-a-raid-zfs-set-of-drives.995/
But if I am correct now that the quota has been removed the system during its utilization should begin to place everything into contiguous space as long as enough space is available on the pool to do so. It may take a while but things should start to work themselves out from my understanding. I would guess that running a scrub wouldn't hurt things in any way when there will be a lot of downtime and the VM's do not need to be up and running.
jgreco
Resident Grinch
The system is always putting stuff into contiguous space, except perhaps if you were actually ramming into a quota... it isn't clear what was actually happening to you, but there's no need to set a quota on a zvol, and actually I am inclined to say nothing good is likely to come of it.
gpsguy
Active Member
Compression is enabled by default.
Dedupe is a different story. The recommendation is that you have 5GB of RAM for each 1TB of storage, with no upper bound. We don't recommend it, unless you understand what you are doing and the risks involved.
jgreco
Resident Grinch
... suddenly gets an itch to enable dedupe on the VM filer...
diehard
jgreco just get with the openzfs guys and get them to get block pointer re-write working. Solve half your problems man
