Virtual Machine clone fault (bug?)
el1milka
Dear Community,
I tried to clone a VM on my Truenas Scale in GUI, but I got the next message:
libvirtError
operation failed: domain '4_ubuntu' is already defined with uuid eb1f9d24-0daf-4b43-a2dc-c8e0ce5c3ba3
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 175, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1257, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1261, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1129, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/clone.py", line 130, in clone
raise e
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/clone.py", line 113, in clone
await self.middleware.call('vm.do_create', vm)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1308, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vms.py", line 176, in do_create
await self.middleware.run_in_thread(self._add, vm_id)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1172, in run_in_thread
return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1169, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 13, in _add
self._add_with_vm_data(vm)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 16, in _add_with_vm_data
self.vms[vm['name']] = VMSupervisor(vm, self.middleware)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 40, in __init__
self.update_domain()
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 59, in update_domain
self.__define_domain()
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 87, in __define_domain
if not self.LIBVIRT_CONNECTION.defineXML(vm_xml):
File "/usr/lib/python3/dist-packages/libvirt.py", line 4380, in defineXML
raise libvirtError('virDomainDefineXML() failed')
libvirt.libvirtError: operation failed: domain '4_ubuntu' is already defined with uuid eb1f9d24-0daf-4b43-a2dc-c8e0ce5c3ba3
The VM_clone0 was created, but I cannot edit anything in it. Then I tried to delete this clone, but I got the following message.
CallError
[EFAULT] Unable to retrieve VM status. Failed to destroy VM
More info...
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 175, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1257, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/service.py", line 942, in delete rv = await self.middleware._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1257, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1129, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1261, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vms.py", line 400, in do_delete raise CallError('Unable to retrieve VM status. Failed to destroy VM') middlewared.service_exception.CallError: [EFAULT] Unable to retrieve VM status. Failed to destroy VM
Can somebody tell me, how to clone a VM correctly, and how to delete this false VM clone.
Thank you,
Milan Peter
Specs:
ASUS Z9PA-D8C
2pc Intel Xeon E5-2690 V2
8 x 8GB ECC DDR3
2 x 250GB mirrored ssd for sys
2 x 2TB mirrored ssd for VMs
6 x 2TB WDRED raidz2
2 x 2TB mirrored WDGREEN for veeam backup
morganL
Captain Morgan
Administrator
Which version of TrueNAS SCALE were you using?
Any idea whether it worked on a previous version.... or is this your first attempt?
luredivino
Same error. TrueNAS-SCALE-22.02.1
Tried to clone a vm, now getting the same error. Tried to delete the vm and now its stuck. Tried removing all devices and rebooting, but will not delete
el1milka
I installed it last Friday. This was my first attempt.
briangr
Hello Forum,
I can confirm the cloning error on TrueNAS-SCALE-22.02.1-MASTER-20220508-040717 nightly. After rebooting the cloned VM does appear in the list, but cannot be started:
[EFAULT] Unable to define domain for debianvm2: operation failed: domain '1_debianvm1' is already defined with uuid 058531df-b4a4-4adf-bc6e-3c98e87296e7
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 42, in _check_add_domain self._add(self._vm_from_name(vm_name)['id']) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 13, in _add self._add_with_vm_data(vm) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 16, in _add_with_vm_data self.vms[vm['name']] = VMSupervisor(vm, self.middleware) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 40, in __init__ self.update_domain() File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 59, in update_domain self.__define_domain() File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 87, in __define_domain if not self.LIBVIRT_CONNECTION.defineXML(vm_xml): File "/usr/lib/python3/dist-packages/libvirt.py", line 4380, in defineXML raise libvirtError('virDomainDefineXML() failed') libvirt.libvirtError: operation failed: domain '1_debianvm1' is already defined with uuid 058531df-b4a4-4adf-bc6e-3c98e87296e7 During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 176, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1291, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1263, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1131, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 39, in start await self.middleware.run_in_thread(self._start, vm['name']) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1206, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1203, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 61, in _start self._check_add_domain(vm_name) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 44, in _check_add_domain raise CallError(f'Unable to define domain for {vm_name}: {e}') middlewared.service_exception.CallError: [EFAULT] Unable to define domain for debianvm2: operation failed: domain '1_debianvm1' is already defined with uuid 058531df-b4a4-4adf-bc6e-3c98e87296e7
briangr
And just to be complete, trying to delete the (incorrectly) cloned VM triggers the original cloning error again:
Perhaps the code fails to set a new uuid and/or name for the clone?
Brian
Adnan
same issue
ctag
I'm seeing the same error. Does anyone know if there's a bug report filed?
unixland
same issue here.
vyper013
Hey all... I had the same issue... I was fortunate enough that I could try deleting the "original" VM.... this then allowed me to delete the failed clone... I had just started to create a "template" VM to save me doing installs each time... for now that is what I will have to do!! lucky I don't need too many
Dasos
I can confirm I have ran into the same issue.
The "work around" was mentioned here did work. I had to delete the orginal VM (using the "forced" option) then I was able to remove the other and re-make the original attaching the orginal zvol & re-attaching the NICs with the MAC addresses I saved before hand & same devices & device order etc.
stergio
I have not cloned anything. I restart to change Bios time to match UTC time, I was curious how my VMs would react, and i got this error when I tried to run it. What gives?! Makes no sense! Wow this is beyong frustrating, it is irritating. Same issue happened when i Forced a bridge connection on the NIC.
Are you all telling me I need to delete the VM and redo thing install and config from scratch everytime I see this kind of error? That is plain crazy
Anyone else seen this before?
