Unauthorized Reboot - 11.1-RELEASE
FFF
Mine still aren't actually rebooting, but I received another email from a new system today. Tracked it down to this:
Mar  6 03:45:03 hostname1 kernel: pid 262 (python3.6), uid 0: exited on signal 11 (core dumped)
So I checked for python processes started around that time and found this:
root	   13531	0.0  0.1  74884  65288  -  I	03:45		0:02.68 /usr/local/bin/python /etc/find_alias_for_smtplib.py -FCronDaemon -odi -oem -oi -t (python3.6)
root	   13665	0.0  0.2 188560 138304  -  S	03:45		0:12.82 python3.6: middlewared (python3.6)
Went back and found the same thing on another system:
Feb 28 12:19:08 hostname2 kernel: pid 250 (python3.6), uid 0: exited on signal 11 (core dumped)
And again:
root			   42507	0.0  0.2 194096 136816  -  S	Wed12	   22:34.33 python3.6: middlewared (python3.6)
hey @Scharbag any updates on your bug? I still can't see it. I'm about ready to log one of mine own too because my hosts thankfully aren't *actually* rebooting ... they're just emailing me telling me they did erroneously.
gurtonBuster
Mine is, scrub started this morning and, it has rebooted 7 times since about 4:30. I changed the scrub to 3 days, the reboots changed to 3 days. I guess it will keep rebooting until it completes the scrub. Scrub a dub dub. I'm thinking of running memtest to see if it's a memory thing. I have ecc ram, but it may be that it's having a big error, and halting the system.
Scharbag
My server has been more stable - hope it stays that way. I am resilvering 2 drives right now (replacing to swap sizes). We will see how it goes...
Scharbag
And again:
Still marked as private. Still targeted for 11.2. No further information given.
Cheers,
If you haven't filed a bug report you probably should if IX systems are having trouble reproducing the problem and you can consistently reproduce it your information maybe valuable to them.
Hossa
Hey,
it looks like I have a "huge" problem with my Storage03.....
As I am having restarts when scrubbing the volume, I decided to backup all my data to an external drive, just to make sure....
Now the system even restarts when I am copying files.....
So in the past hours I already had 3 more unauthorized reboots.....
Cheers
Hossa
Update: Make it five! :-(
gurtonBuster
I'm having the same problem, I tried a memory test to see if it would fail, and it didn't I also updated the bios on my motherboard. Also while I was there Pulled my system event log from the motherboard with the intel sel tool, and nothing showed up apart from the normal boot messages.
gurtonBuster
Does your's reboot when you manually initiate a scrub? I tried that, and it didn't reboot, it just finished. Which sort of seems odd to meeeee.
Hossa
bitterly it does! :-(
Again had 2 more reboots during file copy.
Hossa
Changed back to 11.0-U4
Still copying files....but for over a day no reboots.....
So it must be a strange combination of HW and SW !?
gurtonBuster
I unfortunately don't have the option to revert to 11.0-U4 it is no longer in my boot list. I guess I will just have to deal. It stinks because on the older versions my up-time (much like my pimp hand) was way strong. I also don't have a copy of 11.0 I looked but cant find one.
Is there somewhere I can download older versions from freenas I wonder?
I would be afraid to download it from an unofficial source even if I could find it elsewhere.
I doubt I can install a downgrade but I can always just back up my meager nas to a temporary storage device, and reinstall.
If it's a hardware problem, I just wish I knew what it was. I can't even fine log file information showing what happened.
unitstif
Having the same issue, 11.1 U2 running on Dell R510. Just discovered this yesterday as the system isn't in PROD yet (thankfully).
Hossa
IceBoosteR
gurtonBuster
I'm going to try it tonight when I get home I can't even use my nas, It keeps rebooting so I have nothing to loose. I'm going to have to reinstall an older version anyways. I'll let you know. There seems to be enough of a workaround. For my purposes as I only have two users.
gurtonBuster
FreeNAS-11.1-U3
was released !
Anyone tried yet ?
So I have been running u3 for three days. I have not had a reboot yet I did a manual scrub on the first day, it did the scheduled scrub (which always triggers a reboot). everything seems to be going well. so I upgraded to u4 moments ago, which is the fix for the smb problem with u3 I will let you know what I get from that.
Prior to changing over to u3 that day It was in a boot loop. it rebooted 18 times before I got home from work. I manually turned off the machine and turned it back on. It stayed up long enough to cancel the scrub, and upgrade to u3. So here's hoping it sticks.
changelog: post edited to add missing e to the word been lol
Hossa
I also updated to U4 yesterday evening. We will see what happens next.....
28.03.2018 Update: Running good so far....no abnormalities...
