SOLVED TrueNas Fail to install after 10G Intel card added
RPPT
Probably it’s a rookie mistake but the usb installer of TrueNas core is failing to me.
I added one 10Gb card to my setup and wanted a clean install but I doesn’t seem to go throw no matter what I do.
I get stoped in install at
“Stopped at 0xc2f78ea4: movq %rcx,%rax
db>”
My system:
MoBo: Asus Prime H310M-E R2.0
Latest firmware version: 2209 (x64)
CPU: Intel i3-8100T
Ram: 16GB DDR4 2400MHz (2x8gb)
SSD: 2x Seagate Ironwolf 125 2,5” sata 2TB (2x2)
Boot ssd: crucial 240gb 2,5” CT240BX500
Added Network Card:
Intel x520-SR2 10G SFP+ double port (HP branded)
Transceivers: Intel FTLX8571D3BCV-IT E10GSFPSR SFP+SR
I have another equal 10g card conect directly to my main pc via one new OM3 fiber
Inside of the pc bios I’ve gone to advanced setting and disabled all parameters related to iSCSI for the 10G card, because I tough that was some DHCP malfunction, but it doesn’t made it work. Please some advice.
RPPT
I get arround the problem after some resets to factory settings :smile:
RPPT
Please close this threat, I don't have the option.
And sory I see now that I posted in legacy and I'm in latest Truenas Core :rolleyes:
Davvo
Up right you should have the option to edit the thread. Mark it as solved.
As a bonus, here is a link to a guide for optimizing your system to fully utilize your new card.
