- Aug 16, 2011
Looks like theStill running into this issue here, haven't been able to figure out. Any ideas?
zpool
binary is now at /usr/local/sbin/zpool.Yes, it is.Isn't the high RAM usage on Core intentional though?
It doesn't hurt things. It means the system is using all available RAM (mostly for caching in a properly-resourced system). Under SCALE, I understand as a result of how Linux manages memory (though I admit I'm not super-clear on that), the system doesn't use all available RAM; a significant amount is wasted.I thought it did not affect things.
That sounds like the TrueCharts breaking change I mentioned.I had one person I know, switch to Scale, and he said while he was on Scale, there was an update that was pushed to update the containers. But they were not simply "update-able", but needed to be destroyed.
It can be. I removed the old boot SSD and put in a new one, installed SCALE to that, and uploaded my saved config file. Reverting, had it been necessary (and it was the first time I tried to move to SCALE), would just be a matter of putting in the old SSD again.It's just an in place update, correct?
