Snapshots created by Periodic Snapshot Task are not created.
ArchatParks
  • Lets say I go to Data Protection > Periodic Snapshot Tasks
  • I set up a snapshot.
  • I sent it to go off once and day and the next one to happen ten minutes from now.
  • Twenty minutes go by and a day goes by (just to see if one or the other didn't work).
  • If I click on the datasets tab > Manage datasets, then "Manage Snapshots" under "Data Protection" there are no snapshots created.
  • Bug report is filed.
Does the status show as Finished on that task? (maybe you need to show the status column)
ArchatParks
Nope...it never changes off of "pending". Lets say I set it for 11:00AM today, if you keep clicking refresh, "Periodic Snapshot Tasks " it will count down until 11:00AM (the time for it to fire) then changes to the next day but nothing happens (no snapshots are created).
OK, so checking if the snapshots are there is kind of redundant then...
Have you created a fresh task? and what schedule (and other settings) have you set exactly? (maybe a screenshot would help).
ArchatParks
They were freshly created tasks but I just deleted them all and started all over.
I have three screen shots attached:
1. TruenasCapture_task-create.PNG - shows me creating a brand new task set to go off at 1:10PM (shoudl have all the settings).
2. TruenasCapture_task-menu-after-create1-107PM.PNG - shows the menu at 1:07PM just after I created the task.
3. TruenasCapture_task-menu-after-running-112PM.PNG - shows the menu at 1:12PM just after I created the task.
somethingweird
How much data is in the pool? Just wondering - I'm assuming the first one is going to take a lot more time then the rest..
ArchatParks
Also, I noticed that, as soon as I create a task, the file /var/db/system/syslog-53179c7b52fa4a339b6bdedf76998629/log/syslog shows a bunch of errors (may be a coincidence).
Sep 27 13:05:32 trurnasrocks middlewared[161459]: Unhandled exception during zettarepl startup
Sep 27 13:05:32 trurnasrocks middlewared[161459]: Traceback (most recent call last):
Sep 27 13:05:32 trurnasrocks middlewared[161459]: File "/usr/lib/python3/dist-packages/middlewared/plugins/zettarepl.py", line 151, in __call__
Sep 27 13:05:32 trurnasrocks middlewared[161459]: move_to_root_cgroups(os.getpid())
Sep 27 13:05:32 trurnasrocks middlewared[161459]: File "/usr/lib/python3/dist-packages/middlewared/utils/cgroups.py", line 8, in move_to_root_cgroups
Sep 27 13:05:32 trurnasrocks middlewared[161459]: with open(f"/sys/fs/cgroup/cgroup.procs", "w") as f2:
Sep 27 13:05:32 trurnasrocks middlewared[161459]: OSError: [Errno 30] Read-only file system: '/sys/fs/cgroup/cgroup.procs'
Sep 27 13:05:38 trurnasrocks middlewared[161468]: Unhandled exception during zettarepl startup
Sep 27 13:05:38 trurnasrocks middlewared[161468]: Traceback (most recent call last):
Sep 27 13:05:38 trurnasrocks middlewared[161468]: File "/usr/lib/python3/dist-packages/middlewared/plugins/zettarepl.py", line 151, in __call__
Sep 27 13:05:38 trurnasrocks middlewared[161468]: move_to_root_cgroups(os.getpid())
Sep 27 13:05:38 trurnasrocks middlewared[161468]: File "/usr/lib/python3/dist-packages/middlewared/utils/cgroups.py", line 8, in move_to_root_cgroups
Sep 27 13:05:38 trurnasrocks middlewared[161468]: with open(f"/sys/fs/cgroup/cgroup.procs", "w") as f2:
Sep 27 13:05:38 trurnasrocks middlewared[161468]: OSError: [Errno 30] Read-only file system: '/sys/fs/cgroup/cgroup.procs'
Sep 27 13:06:23 trurnasrocks middlewared[161490]: Unhandled exception during zettarepl startup
Sep 27 13:06:23 trurnasrocks middlewared[161490]: Traceback (most recent call last):
Sep 27 13:06:23 trurnasrocks middlewared[161490]: File "/usr/lib/python3/dist-packages/middlewared/plugins/zettarepl.py", line 151, in __call__
Sep 27 13:06:23 trurnasrocks middlewared[161490]: move_to_root_cgroups(os.getpid())
Sep 27 13:06:23 trurnasrocks middlewared[161490]: File "/usr/lib/python3/dist-packages/middlewared/utils/cgroups.py", line 8, in move_to_root_cgroups
Sep 27 13:06:23 trurnasrocks middlewared[161490]: with open(f"/sys/fs/cgroup/cgroup.procs", "w") as f2:
Sep 27 13:06:23 trurnasrocks middlewared[161490]: OSError: [Errno 30] Read-only file system: '/sys/fs/cgroup/cgroup.procs'
Sep 27 13:07:04 trurnasrocks middlewared[161530]: Unhandled exception during zettarepl startup
Sep 27 13:07:04 trurnasrocks middlewared[161530]: Traceback (most recent call last):
Sep 27 13:07:04 trurnasrocks middlewared[161530]: File "/usr/lib/python3/dist-packages/middlewared/plugins/zettarepl.py", line 151, in __call__
Sep 27 13:07:04 trurnasrocks middlewared[161530]: move_to_root_cgroups(os.getpid())
Sep 27 13:07:04 trurnasrocks middlewared[161530]: File "/usr/lib/python3/dist-packages/middlewared/utils/cgroups.py", line 8, in move_to_root_cgroups
Sep 27 13:07:04 trurnasrocks middlewared[161530]: with open(f"/sys/fs/cgroup/cgroup.procs", "w") as f2:
Sep 27 13:07:04 trurnasrocks middlewared[161530]: OSError: [Errno 30] Read-only file system: '/sys/fs/cgroup/cgroup.procs'
Patrick M. Hausen
I am seeing a lot of reference to read only filesystem. Is that dataset read only?
Sounds like a case of needing to report a bug so it can be sorted out then. Although I see you already did that... please post the link to it here if possible.
