Removing a disc
sekroots
Hello. How can i remove a disk from my pool?
root@POC-STGMASTER[~]# zpool status -x
  pool: tank
 state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
        the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-2Q
  scan: scrub repaired 0B in 00:00:03 with 0 errors on Fri Mar 25 09:44:47 2022
        tank                                            DEGRADED     0     0     0
          raidz1-0                                      DEGRADED     0     0     0
            gptid/089c83bb-a52a-11ec-b3bf-00155d032ee0  ONLINE       0     0     0
            gptid/08b257e6-a52a-11ec-b3bf-00155d032ee0  ONLINE       0     0     0
            gptid/08a9944c-a52a-11ec-b3bf-00155d032ee0  ONLINE       0     0     0
            gptid/08b70295-a52a-11ec-b3bf-00155d032ee0  ONLINE       0     0     0
            gptid/08cad6bc-a52a-11ec-b3bf-00155d032ee0  ONLINE       0     0     0
            16293776385333853924                        UNAVAIL      0     0     0  was /dev/gptid/08c3dbb8-a52a-11ec-b3bf-00155d032ee0
errors: No known data errors
root@POC-STGMASTER[~]# zpool remove tank /dev/gptid/08c3dbb8-a52a-11ec-b3bf-00155d032ee0
cannot remove /dev/gptid/08c3dbb8-a52a-11ec-b3bf-00155d032ee0: operation not supported on this type of pool
Patrick M. Hausen
You can only replace, not remove, a failed disk from a RAIDZ1 vdev.
sekroots
OMG. really?
Let´s imagine this disk has a failure. Where is ZFS redundancy?
Patrick M. Hausen
OMG. really?
Of course. Apart from single <--> mirror (attach/detach) you cannot change the redundancy level of a vdev.
You replace the failed disk to rebuild your desired level of redundancy. All the while the pool continues to work even without redundancy and no data is lost (hopefully).
Stux
Believe RaidZ expansion is coming
IIRC it may work in reverse too, its been a while since I looked into it
Yorick
Won’t work in reverse.
