jgreco
Resident Grinch
- May 29, 2011
NVMe or bust!
Don't say things like that. These are computers. They like to break. You're tempting the inevitable "NVMe and bust".
NVMe or bust!
Boys and their toysYou have entirely too many toys to play with.
Boys and their toys![]()
Next year does sound good to me.Pretty sure we'll hit your 40c/GB next year for NVMe.
Have you tried pfSense yet? If not and you can build a rig from home scraps, I'd do it. Both pfSense and Sophos are difficult to get them installed and running correctly. There is a lot of help out there so it's not hopeless (sometime I felt it was hopeless) but they are also not simply a hands off solution either. Well Sophos for me has been almost hands off once I configured it and I'm sure pfSense would be similar.Thoughts?
I was thinking of just exploring the UI by setting it up in a VM. Actually part of the reason I want pfSense is because I want something more "hands-on" than my Netgear R7000 "Nighthawk" which is too dumbed-down and lacks configuration and data/stats. :) I miss Tomato on my old Buffalo router.Have you tried pfSense yet? If not and you can build a rig from home scraps, I'd do it. Both pfSense and Sophos are difficult to get them installed and running correctly. There is a lot of help out there so it's not hopeless (sometime I felt it was hopeless) but they are also not simply a hands off solution either. Well Sophos for me has been almost hands off once I configured it and I'm sure pfSense would be similar.
Citation neededBoth pfSense and Sophos are difficult to get them installed and running correctly.
I really want to integrate pfSense into my network. I keep looking around at modern hardware options for small size and low power, but at the end of the day after adding up all the pieces I still can't seem to beat pfSense's own SG-2220 (which is just a rebranded Netgate RCC-DFF 2220 for $25 more).
Sure I could go with old PC hardware lying around but size and power usage matter to me. And I want enough CPU (and AES) to run VPN. I only need 2 NICs and my internet is 50 down/ 25 up (and not likely to increase).
Thoughts?
As for pfSense running out of the box as a firewall, well a basic router does the same thing.
It does. The default rules on the WAN interface block RFC1918 and bogon networks. The default install also allows more fine-tuned egress filtering than a cheap gateway thingy. PF is a really powerful tool even if it doesn't have the bells and whistles of a 'security appliance'. I view most of those bells and whistles as yet another thing to maintain and so avoid them unless I have a specific need (and IDS sensor placement is something that has to be planned out - the perimeter isn't always the best place to put it).I believe that the pfSense wizard actually does provide an actual correctly configured stateful firewall that protects against this sort of thing.
There really aren't any significant bogon networks anymore, as virtually all IPv4 space has been allocated. :)
It's nice to hear you say that an IDS sensor doesn't necessarily belong at the edge. There's far too much "big giant network with squishy vulnerable innards" design that goes on.
I could install dd-wrt on my R7000 but it's a hack and disables the hardware acceleration as a result. So I thought it might be better to try pfSense and separate out the firewall/VPN tasks to separate hardware than my wireless, making the R7000 just an AP. (Plus it's a chance to deploy more FreeBSD in my house!)
