Nextcloud External Storage SMB package missing
twsps
As I have upgraded NC to 19 and with PHP to PHP74, I have occurred this error. I have installed php74-pecl-smbclient but that does not seem to solve the issue. Would anyone try to help me solve the issue? I tried several ways on Google, but none of those work for me. I am on FreeNAS 11.1 U7.
Here is a list of packages that are installed in iocage:
ImageMagick6-nox11-6.9.11.6,1  Image processing tools (legacy version)
apache24-2.4.46                Version 2.4.x of Apache web server
apr-1.7.0.1.6.1_1              Apache Portability Library
autoconf-2.69_1                Automatically configure source code on many Un*x platforms
autoconf-wrapper-20131203      Wrapper script for GNU autoconf
automake-1.16.1                GNU Standards-compliant Makefile generator
avahi-app-0.7_3                Service discovery on a local network
binutils-2.30_4,1              GNU binary tools
bison-3.0.4,1                  Parser generator from FSF, (mostly) compatible with Yacc
ca_root_nss-3.38               Root certificate bundle from the Mozilla Project
cmake-3.12.0_1                 Cross-platform Makefile generator
cmocka-1.1.1_1                 Unit testing framework for C with support for mock objects
compat10x-amd64-10.4.1004000.20181014 Convenience package to install the compat10x libraries
cups-2.3.3_1                   Common UNIX Printing System
curl-7.61.0                    Command line tool and library for transferring data with URLs
db5-5.3.28_6                   Oracle Berkeley DB, revision 5.3
dbus-1.10.16_1                 Message bus system for inter-application communication
dbus-glib-0.108                GLib bindings for the D-BUS messaging system
dialog4ports-0.1.6             Console Interface to configure ports
docbook-1.5                    Meta-port for the different versions of the DocBook DTD
docbook-sgml-4.5_1             DocBook SGML DTD
docbook-xml-5.0_3              DocBook XML DTD
docbook-xsl-1.76.1,1           XSL DocBook stylesheets
expat-2.2.5                    XML 1.0 parser written in C
fftw3-3.3.8_6                  Fast C routines to compute the Discrete Fourier Transform
fontconfig-2.13.92_2,1         XML-based font configuration API for X Windows
freetype2-2.9.1                Free and portable TrueType font rendering engine
fribidi-0.19.7                 Free Implementation of the Unicode Bidirectional Algorithm
gamin-0.1.10_9                 File and directory monitoring system
gdbm-1.18.1_1                  GNU database manager
gettext-runtime-0.19.8.1_1     GNU gettext runtime libraries and programs
gettext-tools-0.19.8.1         GNU gettext development and translation tools
ghostscript9-agpl-base-9.52_8  PostScript and PDF interpreter
giflib-5.2.1                   Tools and library routines for working with GIF images
glib-2.50.3_5,1                Some useful routines of C programming (current stable version)
gmake-4.2.1_2                  GNU version of 'make' utility
gmp-6.1.2                      Free library for arbitrary precision arithmetic
gnome_subr-1.0                 Common startup and shutdown subroutines used by GNOME scripts
gnutls-3.5.18                  GNU Transport Layer Security library
gobject-introspection-1.56.1_1,1 Generate interface introspection data for GObject libraries
graphite2-1.3.14               Rendering capabilities for complex non-Roman writing systems
gsfonts-8.11_8                 Standard Fonts for Ghostscript
harfbuzz-2.7.1                 OpenType text shaping engine
help2man-1.47.6                Automatically generating simple manual pages from program output
html2text-1.3.2a               Converts HTML documents into plain text
icu-67.1,1                     International Components for Unicode (from IBM)
indexinfo-0.3.1                Utility to regenerate the GNU info page index
intltool-0.51.0_1              Tools to internationalize various kinds of data files
iso8879-1986_3                 Character entity sets from ISO 8879:1986 (SGML)
jansson-2.11                   C library for encoding, decoding, and manipulating JSON data
jbig2dec-0.18                  Decoder implementation of the JBIG2 image compression format
jbigkit-2.1_1                  Lossless compression for bi-level images such as scanned pages, faxes
jpeg-turbo-1.5.3               SIMD-accelerated JPEG codec which replaces libjpeg
jsoncpp-1.8.1_4                JSON reader and writer library for C++
kbproto-1.0.7                  KB extension headers
lcms2-2.11_1                   Accurate, fast, and small-footprint color management engine
ldb12-1.2.3                    LDAP-like embedded database
libICE-1.0.9_1,1               Inter Client Exchange library for X11
libSM-1.2.2_3,1                Session Management library for X11
libX11-1.6.5,1                 X11 library
libXau-1.0.8_3                 Authentication Protocol library for X11
libXdmcp-1.1.2                 X Display Manager Control Protocol library
libXext-1.3.3_1,1              X11 Extension library
libXpm-3.5.12                  X Pixmap library
libXt-1.1.5,1                  X Toolkit library
libarchive-3.3.2,1             Library to create and read several streaming archive formats
libargon2-20171227             Memory hard password hashing program and library
libdaemon-0.14_1               Lightweight C library that eases the writing of UNIX daemons
libedit-3.1.20170329_2,1       Command line editor library
libffi-3.3_1                   Foreign Function Interface
libffi321-3.2.1_2              Foreign Function Interface (stripped down compat version)
libgcrypt-1.8.3                General purpose cryptographic library based on the code from GnuPG
libgd-2.3.0,1                  Graphics library for fast creation of images
libgpg-error-1.31              Common error values for all GnuPG components
libiconv-1.14_11               Character set conversion library
libidn-1.35                    Internationalized Domain Names command line tool
libidn2-2.0.5                  Implementation of IDNA2008 internationalized domain names
libinotify-20180201            Kevent based inotify compatible library
liblqr-1-0.4.2                 Easy to use C/C++ seam carving library
libltdl-2.4.6                  System independent dlopen wrapper
liblz4-1.8.2,1                 LZ4 compression library, lossless and very fast
libnghttp2-1.32.0              HTTP/2.0 C Library
libpaper-1.1.24.4              Library providing routines for paper size management
libpthread-stubs-0.4           This library provides weak aliases for pthread functions
libraqm-0.6.0                  Library that encapsulates complex text layout logic
libraw-0.19.5                  Library for manipulating raw images
libsunacl-1.0.1                Wrapper providing SunOS NFSv4 ACL API
libtasn1-4.13                  ASN.1 structure parser library
libtool-2.4.6                  Generic shared library support script
libunistring-0.9.10            Unicode string library
libuv-1.22.0                   Multi-platform support library with a focus on asynchronous I/O
libwmf-nox11-0.2.8.4_15        Tools and library for converting Microsoft WMF (windows metafile)
libxcb-1.13                    The X protocol C-language Binding (XCB) library
libxml2-2.9.7                  XML parser library for GNOME
libxslt-1.1.32                 The XSLT C library for GNOME
libzip-1.5.1                   C library for reading, creating, and modifying ZIP archives
lmdb-0.9.24_2,1                OpenLDAP Lightning Memory-Mapped Database
lua52-5.2.4                    Small, compilable scripting language providing easy access to C code
lzo2-2.10_1                    Portable speedy, lossless data compression library
m4-1.4.18,1                    GNU M4
mariadb102-client-10.2.16      Multithreaded SQL database (client)
mariadb102-server-10.2.16      Multithreaded SQL database (server)
minixmlto-0.0.2_1              Minimalistic alternative to xmlto
mod_php74-7.4.9                PHP Scripting Language
mpfr-4.0.1                     Library for multiple-precision floating-point computations
nano-2.9.8                     Nano's ANOther editor, an enhanced free Pico clone
nettle-3.4                     Low-level cryptographic library
ninja-1.8.2,2                  Ninja is a small build system closest in spirit to Make
oniguruma-6.8.1                Regular expressions library compatible with POSIX/GNU/Perl
openjpeg-2.3.1                 Open-source JPEG 2000 codec
openldap-client-2.4.46         Open source LDAP client implementation
p11-kit-0.23.12                Library for loading and enumerating of PKCS#11 modules
p5-Locale-gettext-1.07         Message handling functions
p5-Parse-Yapp-1.05_2           Perl extension for generating and using LALR parsers
p5-XML-Parser-2.44             Perl extension interface to James Clark's XML parser, expat
panda-cclient-20130621_1       Mark Crispin's C-client mail access routines forked from UW
pcre-8.42                      Perl Compatible Regular Expressions library
pcre2-10.35                    Perl Compatible Regular Expressions library, version 2
perl5-5.32.0                   Practical Extraction and Report Language
php74-bcmath-7.4.9             The bcmath shared extension for php
php74-bz2-7.4.9                The bz2 shared extension for php
php74-ctype-7.4.9              The ctype shared extension for php
php74-curl-7.4.9               The curl shared extension for php
php74-dom-7.4.9                The dom shared extension for php
php74-exif-7.4.9               The exif shared extension for php
php74-fileinfo-7.4.9           The fileinfo shared extension for php
php74-filter-7.4.9             The filter shared extension for php
php74-ftp-7.4.9                The ftp shared extension for php
php74-gd-7.4.9                 The gd shared extension for php
php74-gmp-7.4.9                The gmp shared extension for php
php74-iconv-7.4.9              The iconv shared extension for php
php74-imap-7.4.9               The imap shared extension for php
php74-intl-7.4.9               The intl shared extension for php
php74-json-7.4.9               The json shared extension for php
php74-ldap-7.4.9               The ldap shared extension for php
php74-mbstring-7.4.9           The mbstring shared extension for php
php74-mysqli-7.4.9             The mysqli shared extension for php
php74-opcache-7.4.9            The opcache shared extension for php
php74-openssl-7.4.9            The openssl shared extension for php
php74-pcntl-7.4.9              The pcntl shared extension for php
php74-pdo-7.4.9                The pdo shared extension for php
php74-pdo_mysql-7.4.9          The pdo_mysql shared extension for php
php74-pecl-APCu-5.1.18         APC User Caching
php74-pecl-imagick-3.4.4       PHP wrapper to the ImageMagick/GraphicsMagick library version 6
php74-pecl-redis-5.3.1         Extension to access Redis
php74-pecl-smbclient-1.0.0_1   Smbclient wrapper extension
php74-posix-7.4.9              The posix shared extension for php
php74-session-7.4.9            The session shared extension for php
php74-simplexml-7.4.9          The simplexml shared extension for php
php74-xml-7.4.9                The xml shared extension for php
php74-xmlreader-7.4.9          The xmlreader shared extension for php
php74-xmlwriter-7.4.9          The xmlwriter shared extension for php
php74-xsl-7.4.9                The xsl shared extension for php
php74-zip-7.4.9                The zip shared extension for php
php74-zlib-7.4.9               The zlib shared extension for php
pkg-1.14.7                     Package manager
pkgconf-1.4.2,1                Utility to help to configure compiler and linker flags
png-1.6.34                     Library for manipulating PNG images
poppler-data-0.4.9_5           Poppler encoding data
popt-1.16_2                    Getopt(3) like library with a number of enhancements, from Redhat
py27-Babel-2.6.0               Collection of tools for internationalizing Python applications
py27-Jinja2-2.10               Fast and easy to use stand-alone template engine
py27-MarkupSafe-1.0            Implements XML/HTML/XHTML Markup safe string for Python
py27-alabaster-0.7.6           Modified Kr Sphinx theme
py27-asn1crypto-0.22.0         ASN.1 library with a focus on performance and a pythonic API
py27-certifi-2018.4.16         Mozilla SSL certificates
py27-cffi-1.11.5               Foreign Function Interface for Python calling C code
py27-chardet-3.0.4             Universal encoding detector for Python 2 and 3
py27-cryptography-2.3          Cryptographic recipes and primitives for Python developers
py27-cython-0.28.2             Compiler for Writing C Extensions for the Python Language
py27-dnspython-1.15.0          DNS toolkit for Python
py27-docutils-0.14_3           Python Documentation Utilities
py27-enum34-1.1.6              Python 3.4 Enum backported to 3.3, 3.2, 3.1, 2.7
py27-idna-2.7                  Internationalized Domain Names in Applications (IDNA)
py27-imagesize-0.7.1           Python image size library
py27-ipaddress-1.0.22          Port of Python 3.3+ ipaddress module to 2.7
py27-iso8601-0.1.11            Simple module to parse ISO 8601 dates
py27-openssl-17.5.0_1          Python interface to the OpenSSL library
py27-pycparser-2.18            C parser in Python
py27-pygments-2.2.0            Syntax highlighter written in Python
py27-pysocks-1.6.8             Python SOCKS module
py27-pystemmer-1.3.0_2         Snowball Stemming Algorithms for Information Retrieval
py27-pytest-runner-2.11.1      Test support for pytest runner in setup.py
py27-pytz-2018.5,1             World Timezone Definitions for Python
py27-requests-2.18.4_1         HTTP library written in Python for human beings
py27-setuptools-44.0.0         Python packages installer
py27-setuptools_scm-1.17.0     Setuptools plugin to manage your versions by scm tags
py27-six-1.11.0                Python 2 and 3 compatibility utilities
py27-snowballstemmer-1.2.0_1   Snowball stemming library collection for Python
py27-sphinx-1.6.5_1,1          Python documentation generator
py27-sphinx_rtd_theme-0.4.0    Mobile-friendly py-sphinx theme
py27-sphinxcontrib-websupport-1.0.1 Sphinx API for Web Apps
py27-typing-3.6.4              Type Hints for Python
py27-urllib3-1.22,1            HTTP library with thread-safe connection pooling, file post, and more
py37-iso8601-0.1.12            Simple module to parse ISO 8601 dates
py37-setuptools-44.0.0         Python packages installer
python27-2.7.15                Interpreted object-oriented programming language
python37-3.7.8_1               Interpreted object-oriented programming language
readline-7.0.3_1               Library for editing command lines as they are typed
redis-4.0.10                   Persistent key-value database with built-in net interface
rhash-1.3.5                    Utility and library for computing and checking of file hashes
samba410-4.10.17               Free SMB/CIFS and AD/DC server and client for Unix
scons-3.0.1                    Build tool alternative to make
sdocbook-xml-1.1_2,2           "Simplified" DocBook XML DTD
sudo-1.8.23_2                  Allow others to run commands as root
swig30-3.0.12                  Generate wrappers for calling C/C++ code from other languages
talloc-2.1.14                  Hierarchical pool based memory allocator
tdb-1.3.16,1                   Trivial Database
tevent-0.9.37                  Talloc based event loop library
texinfo-6.5,1                  Typeset documentation system with multiple format output
tiff-4.1.0                     Tools and library routines for working with TIFF images
tpm-emulator-0.7.4_2           Trusted Platform Module (TPM) emulator
trousers-0.3.14_2              Open-source TCG Software Stack
unixODBC-2.3.6                 ODBC library suite for Unix
webp-1.1.0                     Google WebP image format conversion tool
wget-1.19.5                    Retrieve files from the Net via HTTP(S) and FTP
xcb-util-0.4.0_2,1             Module with libxcb/libX11 extension/replacement libraries
xcb-util-renderutil-0.3.9_1    Convenience functions for the Render extension
xextproto-7.3.0                XExt extension headers
xmlcatmgr-2.2_2                SGML and XML catalog manager
xmlcharent-0.3_2               XML character entities
xorg-macros-1.19.2             X.Org development aclocal macros
xproto-7.0.31                  X11 protocol headers
Thanks
RSVP
In the newer versions, you have to apps and scroll to bottom and enable external storage support I think. Any mounted shares then can be added to external storage local.
twsps
It has already been enabled. Even if I try to uninstall and reinstall it, I still got the same error. Would it be possible that Nextcloud 19 doesn't support PHP74?
twsps
A update from trying a command in jail
I got the follow error when trying 'smbclient'
root@nextcloud:/ # smbclient
/usr/local/lib/libtdb.so.1: version TDB_1.3.17 required by /usr/local/lib/samba4/libsmbconf.so.0 not found
twsps
S
So that error was resolved by replacing the new version of libtdb.so.1 by visiting the following page and replace it.
However, it seems like that does not relate to the problem that I had in nextcloud, as I still get the exact same error. Would it be that php74-pecl-smbclient is not stable or somehow not compatible with NC19 or the External Storage version that I use?
twsps
Any ideas on this? 'smbclient' works perfectly in jails, why would the error still occur?
