Jail repository wrong ABI
LGSONE
Running the latest nightlies on Dell T5500 x64 with Dual Xeon 2.13Ghz with 24GB-EEC Ram, 5 500gb z2
Went to create a new jail and it downloaded freenas-standard-11-release.tgz
the below is what happened.
Thoughts.. I did some searching on here but missed anything relative if already here.
login as: root
root@172.20.2.22's password:
Last login: Mon Apr 17 23:28:31 2017 from 172.20.2.189
FreeBSD 11.0-STABLE (FreeNAS.amd64) #0 ae7e9fd16(freenas/11-stable): Tue Apr 18 04:37:58 UTC 2017
[root@LGSONE-NAS] ~# jexec 3 tcsh
root@Test:/ # pkg update
Updating FreeBSD repository catalogue...
Repository FreeBSD has a wrong packagesite, need to re-create database
[Test] Fetching meta.txz: 100% 944 B 0.9kB/s 00:01
[Test] Fetching packagesite.txz: 100% 6 MiB 3.0MB/s 00:02
Processing entries: 0%
pkg: wrong architecture: freebsd:10:x86:64 instead of FreeBSD:11:amd64
pkg: repository FreeBSD contains packages with wrong ABI: freebsd:10:x86:64
Processing entries: 100%
Unable to update repository FreeBSD
root@Test:/ # pkg upgrade
All repositories are up-to-date.
pkg: Repository FreeBSD cannot be opened. 'pkg update' required
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
root@Test:/ # pkg info
apr-1.5.2.1.5.4_2 Apache Portability Library
ca_root_nss-3.29 Root certificate bundle from the Mozilla Project
curl-7.52.1_1 Non-interactive tool to get files from FTP, GOPHER, HTTP(S) servers
cvsps-2.1_2 Create patchset information from CVS
db5-5.3.28_6 Oracle Berkeley DB, revision 5.3
expat-2.2.0_1 XML 1.0 parser written in C
gdbm-1.12 GNU database manager
gettext-runtime-0.19.8.1_1 GNU gettext runtime libraries and programs
git-2.11.1 Distributed source code management tool
indexinfo-0.2.6 Utility to regenerate the GNU info page index
libffi-3.2.1 Foreign Function Interface
libnghttp2-1.19.0 HTTP/2.0 C Library
p5-Authen-SASL-2.16_1 Perl5 module for SASL authentication
p5-Digest-HMAC-1.03_1 Perl5 interface to HMAC Message-Digest Algorithms
p5-Error-0.17024 Error/exception handling in object-oriented programming style
p5-GSSAPI-0.28_1 Perl extension providing access to the GSSAPIv2 library
pcre-8.40 Perl Compatible Regular Expressions library
perl5-5.24.1 Practical Extraction and Report Language
pkg-1.9.4_1 Package manager
python27-2.7.13_1 Interpreted object-oriented programming language
readline-6.3.8 Library for editing command lines as they are typed
serf-1.3.9_1 Serf HTTP client library
sqlite3-3.16.2 SQL database engine in a C library
subversion-1.9.5 Version control system
root@Test:/ # pkg -vv
Version : 1.9.4
PKG_DBDIR = "/var/db/pkg";
PKG_CACHEDIR = "/var/cache/pkg";
PORTSDIR = "/usr/ports";
INDEXDIR = "";
INDEXFILE = "INDEX-11";
HANDLE_RC_SCRIPTS = false;
DEFAULT_ALWAYS_YES = false;
ASSUME_ALWAYS_YES = false;
REPOS_DIR [
"/etc/pkg/",
"/usr/local/etc/pkg/repos/",
PLIST_KEYWORDS_DIR = "";
SYSLOG = true;
ABI = "FreeBSD:11:amd64";
ALTABI = "freebsd:11:x86:64";
DEVELOPER_MODE = false;
VULNXML_SITE = "http://vuxml.freebsd.org/freebsd/vuln.xml.bz2";
FETCH_RETRY = 3;
PKG_PLUGINS_DIR = "/usr/local/lib/pkg/";
PKG_ENABLE_PLUGINS = true;
PLUGINS [
DEBUG_SCRIPTS = false;
PLUGINS_CONF_DIR = "/usr/local/etc/pkg/";
PERMISSIVE = false;
REPO_AUTOUPDATE = true;
NAMESERVER = "";
HTTP_USER_AGENT = "pkg/1.9.4";
EVENT_PIPE = "";
FETCH_TIMEOUT = 30;
UNSET_TIMESTAMP = false;
SSH_RESTRICT_DIR = "";
PKG_ENV {
PKG_SSH_ARGS = "";
DEBUG_LEVEL = 0;
ALIAS {
CUDF_SOLVER = "";
SAT_SOLVER = "";
RUN_SCRIPTS = true;
CASE_SENSITIVE_MATCH = false;
LOCK_WAIT = 1;
LOCK_RETRIES = 5;
SQLITE_PROFILE = false;
WORKERS_COUNT = 0;
READ_LOCK = false;
PLIST_ACCEPT_DIRECTORIES = false;
IP_VERSION = 0;
AUTOMERGE = true;
VERSION_SOURCE = "";
CONSERVATIVE_UPGRADE = true;
PKG_CREATE_VERBOSE = false;
AUTOCLEAN = false;
DOT_FILE = "";
REPOSITORIES {
VALID_URL_SCHEME [
"pkg+http",
"pkg+https",
"https",
"http",
"file",
"ssh",
"ftp",
"ftps",
"pkg+ssh",
"pkg+ftp",
"pkg+ftps",
ALLOW_BASE_SHLIBS = false;
WARN_SIZE_LIMIT = 1048576;
METALOG = "";
Repositories:
FreeBSD: {
url : "pkg+http://pkg.FreeBSD.org/freebsd:10:x86:64/latest",
enabled : yes,
priority : 0,
mirror_type : "SRV",
signature_type : "FINGERPRINTS",
fingerprints : "/usr/share/keys/pkg"
root@Test:/ #
root@Test:/ # pkg rquery %n-%v
root@Test:/ #
root@Test:/ # pkg: wrong architecture: freebsd:10:x86:64 instead of FreeBSD:11:amd64
root@Test:/ #
Jailer
Not strong, but bad
Follow the direction in this post and change your repository from 10 latest to 11 latest. It's a bug that's been reported by other members.
LGSONE
File did not have any current data (see pic) Updated per instruction in post and still the same error.
Zyrusvirus
i use a FreeNAS11 and i create a new Jail for CalmAV.
When I give into the ssh "pkg update" command, says the Jail System, repo error.
when edit vi /usr/local/etc/pkg/repos/FreeBSD.conf and save the Config, the error remains.
Can you help me?
