Nextcloud 403 Forbidden - Truenas Scale
jdn
I installed Nextcloud using the Applications section and put down the default config. Now I am getting the below error. I have put the files in one of the Samba share folders. Please help...
I am using below folders-
shui136
I used the default path instead but got the same result. Have you solved it yet?
copz1998
Good day,
I have the same issue. When I enable - Storage - Nextcloud Storage Data volume - /mnt/nas-name/nextcloud and select the same host path volume, I receive the 403 Forbidden error when trying to use the web portal for Nextcloud.
Any suggestions would be much appreciated!
[Str1n]
I got it to work as follows (using TrueNAS-SCALE-22.12.0):
Base URL abbreviated as {BURL}
1) For the userName specified in NextCloud settings {BURL}/ui/apps, go to {BURL}/ui/credentials/users and add "www-data" group to that user's profile .
2) Then for the Host Path for NextCloud Data Volume specified in NextCloud settings {BURL}/ui/apps, add permissions for the "www-data" User group to that Dataset path.
[Str1n]
CORRECTION to above - sorry :confused:
Just realised its setting operational permissions as User, not Group
==> For the Host Path for NextCloud Data Volume specified in NextCloud settings {BURL}/ui/apps, add permissions for the "www-data" User to that Dataset path.
