Missing dataset in GUI in Cobia beta
liraelia
I have upgraded to TrueNAS-SCALE-23.10-BETA.1, did the pool upgrade and now my datasets aren't showing in GUI.
I get the following error from /var/log/middlewared.log when I click on datasets in GUI
[2023/08/18 12:14:42] (WARNING) application.call_method():249 - Exception while calling pool.dataset.details(*[])
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 213, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1372, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1271, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 181, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 50, in nf
    res = f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_details.py", line 209, in details
    self.collapse_datasets(dataset, info, mnt_info)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_details.py", line 235, in collapse_datasets
    self.collapse_datasets(child, info, mnt_info)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_details.py", line 233, in collapse_datasets
    self.normalize_dataset(dataset, info, mnt_info)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_details.py", line 229, in normalize_dataset
    dataset['rsync_tasks_count'] = self.get_rsync_tasks_count(dataset, info['rsync'])
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_details.py", line 418, in get_rsync_tasks_count
    if pathlib.Path(ds['mountpoint']).is_relative_to(i['path']):
  File "/usr/lib/python3.11/pathlib.py", line 872, in __new__
    self = cls._from_parts(args)
  File "/usr/lib/python3.11/pathlib.py", line 510, in _from_parts
    drv, root, parts = self._parse_args(args)
  File "/usr/lib/python3.11/pathlib.py", line 494, in _parse_args
    a = os.fspath(a)
TypeError: expected str, bytes or os.PathLike object, not NoneType
and my datasets tab looks like this
Is there anything that can be done?
Thank you
morganL
Captain Morgan
Administrator
@liraelia another user submitted a bug reported on this and a fix is expected in RC.1.
NAS-123560
@liraelia
RC.1 is expected at end of September.
If data is not critical, then the Nightly images could be used.
If anyone else sees the issue, please log it here. Its not clear what % of users get this problem and whether its related to cloudsync or rsync tasks that have been scheduled.
hege
I saw this issue as well, but didn't capture any logs. For what it's worth, I have a cloudsync task, so it's plausibly the same issue as NAS-123560.
For now I'm back on 22.12 due to broken UPS and SNMP, both issues seem to be fixed already. Any chance a BETA.2 is cut before end of September? Looks like all my blocker bugs have fixes, but I'm not sure I'd trust a nightly build with my data.
liraelia
I don't have any cloud sync tasks. I do have one rsync task, I have disabled it and the rsync service before upgrading.
I tried to delete it now and my datasets are visible in gui again.
jace92
Confirming I have the same missing Datasets issue on the Cobia Beta
Saberwolf
i can confirm just remove your cloud sync in your data protection tab and data set return reboot server.
jace92
Oh, that's fun. I can also confirm that removing your cloud sync task shows the datasets again. Now I'm re-adding it to see if that breaks it again. I hope not...
Do we know why that's the issue/fix? (Other than because it's a bug on a beta product)
Saberwolf
i can confirm it has been fixed for next release but they are collecting and working on ups and few other bugs it is slated to be fixed in RC.1
jace92
That's good, thanks for that update!
jace92
Well... re-adding the task broke it again. Darn
NickF
ULTIoNT
Sorry I didn't read other responses carefully. Indeed this is a problem with the cloud sync tasks. When they are removed, the datasets shows up again.
Also encountered this problem. I just moved my system dataset from boot-pool to another SSD data pool and then datasets are gone in the WebUI while everything else seems to be intact, including apps, VMs, SMB, pointing to these datasets when modifying configs in the WebUI, etc. The errors I see are the same as liraelia has pointed out:
[2023/08/26 19:56:09] (WARNING) application.call_method():249 - Exception while calling pool.dataset.details(*[])
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_details.py", line 228, in normalize_dataset
    dataset['cloudsync_tasks_count'] = self.get_cloudsync_tasks_count(dataset, info['cloud'])
  File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_details.py", line 408, in get_cloudsync_tasks_count
    a = os.fspath(a)
It seems like there is some `None` mountpoints in the response to `pool.dataset`. I took a look at the response to `/pool/dataset` (I am not familiar with websocket) and it seems that there is going to be `"mountpoint": null` for zvols inside a dataset and maybe that's what confuses middleware. In my case, they are `SSD/virtual-machines/OpenWRT`and `SSD/virtual-machines/Ubuntu` themselves and wherever they are considered children.
  • pool-dataset.txt
Saberwolf
    a = os.fspath(a)
Thanks for the enthusiasm but if you look at the above Jira ticket they have found the solution it has to deal with cloud replication task ease workaround is to disable them / remove until the next release.
cfmedicus
Just happened to me right now - I was shocked, but all my machines are running. in the CLI all Datasets are there. Last task before "loosing" the Datasets on the ui was to add a rsync task for one (sub)Dataset.
jace92
I updated to the RC for 23.10 yesterday and I still show my datasets after re-configuring the Cloud Sync.
