Mismatch between kernel and FreeNAS versions?
harper5
When I log into my FreeNAS, I see:
FreeBSD freenas.mynet.local 11.1-STABLE FreeBSD 11.1-STABLE #0 r321665+79f05c3dd3d(HEAD): Wed Jan 23 12:02:34 EST 2019 root@nemesis.tn.ixsystems.com:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64
But, then I see this:
me@freenas:/ % cat /etc/version
FreeNAS-11.2-U7 (299a0ab8e2)
When I'm in the web UI, I see many indications that my system is on the 11.2-STABLE train.
Here is the system status from the web UI (copy/pasted text only):
System Information
FREENAS-MINI-XL
OS Version:
FreeNAS-11.2-U7
(Build Date: Nov 19, 2019 0:4)
Processor:
Intel(R) Atom(TM) CPU C2750 @ 2.40GHz (8 cores)
Memory:
32 GiB
HostName:
freenas.mynet.local
Uptime:
1:08PM up 11 mins, 1 user
Here is the text from the "Update" screen (copy/pasted here):
Train
FreeNAS-11.2-STABLE - Release Train for FreeNAS 11.2 [release]
OperationName
Upgradebase-os-11.2-U7-f93a3b67973bac31ececa871460a45e7 -> base-os-11.2-U8-8ba69aba1ecc4c3b9aa817078e77f308
Upgradefreebsd-pkgdb-11.2-U7-f93a3b67973bac31ececa871460a45e7 -> freebsd-pkgdb-11.2-U8-8ba69aba1ecc4c3b9aa817078e77f308
Upgradefreenas-pkg-tools-11.2-U7-f93a3b67973bac31ececa871460a45e7 -> freenas-pkg-tools-11.2-U8-8ba69aba1ecc4c3b9aa817078e77f308
UpgradeFreeNASUI-11.2-U7-f93a3b67973bac31ececa871460a45e7 -> FreeNASUI-11.2-U8-8ba69aba1ecc4c3b9aa817078e77f308
Maybe related or maybe requiring a new ticket...I have "applied" these updates several times but the system is locked in this state. 11.1-STABLE from CLI and 11.2-STABLE from web UI no matter how many times I "apply" the updates.
Is this expected?
Samuel Tai
Per forum rules, please provide more information about your hardware and pool setup. From the very limited information you've currently provided, it appears you have a failed upgrade from 11.1 to 11.2, which is why the 11.2-U8 upgrade isn't applying.
Fredda
Please check if there is enough space left on your boot device to install the upgrade.
The info you see upon login comes from /etc/motd, that is not necessarily correct. What is the output of uname -a?
harper5
My apologies for providing such very limited information.
Here is more information. Hopefully I get the formatting correct and haven't missed any tags.
It is a IXSystems FreeNAS Mini-XL with 8 drives. No after-market additions have been added other than replacing the failed SATADOM with a new SSD.
Provide the exact build number:
Per Forum Rules I'm unable to give the exact build number because my FreeNAS doesn't have a System > Information screen. I've pasted the system information from the Dashboard in my original post.
My pool setup is as follows:
me@freenas:~ % zpool status
  pool: freenas-boot
 state: ONLINE
  scan: none requested
    freenas-boot  ONLINE       0     0     0
      ada3p2    ONLINE       0     0     0
errors: No known data errors
  pool: tank
 state: ONLINE
  scan: scrub repaired 0 in 0 days 07:42:20 with 0 errors on Sun Aug 23 07:42:21 2020
    tank                                            ONLINE       0     0     0
      raidz2-0                                      ONLINE       0     0     0
        gptid/fae314d6-588c-11e9-b20a-d05099d08537  ONLINE       0     0     0
        gptid/fbdc4b5c-588c-11e9-b20a-d05099d08537  ONLINE       0     0     0
        gptid/fcdb914d-588c-11e9-b20a-d05099d08537  ONLINE       0     0     0
        gptid/fde139af-588c-11e9-b20a-d05099d08537  ONLINE       0     0     0
        gptid/fef4a20c-588c-11e9-b20a-d05099d08537  ONLINE       0     0     0
        gptid/0022792f-588d-11e9-b20a-d05099d08537  ONLINE       0     0     0
        gptid/014bc61a-588d-11e9-b20a-d05099d08537  ONLINE       0     0     0
        gptid/0260da25-588d-11e9-b20a-d05099d08537  ONLINE       0     0     0
I have attached my debug file as specified in the rules.
More hardware information:
Motherboard make and model:
root@freenas:~ # dmidecode -s baseboard-manufacturer
ASRock
root@freenas:~ # dmidecode -s baseboard-product-name
C2750D4I
root@freenas:~ # dmidecode -s baseboard-version
1.03
Processor make and model:
root@freenas:~ # dmidecode -s processor-family
Atom
root@freenas:~ # dmidecode -s processor-manufacturer
Intel(R) Corporation
root@freenas:~ # dmidecode -s processor-version
root@freenas:~ # dmidecode -s processor-frequency
2400 MHz
RAM quantity:
32GB
Hard drives, quantity, model numbers, and RAID configuration, including boot drives:
No RAID, only ZFS
root@freenas:~ # camcontrol devlist
<Hitachi HDS723030ALA640 MKAOAAM0>  at scbus0 target 0 lun 0 (pass0,ada0)
<Hitachi HDS723030ALA640 MKAOAAM0>  at scbus1 target 0 lun 0 (pass1,ada1)
<INTEL SSDSA2CW080G3 4PC10362>     at scbus4 target 0 lun 0 (pass2,ada2)
<WDC WD5000LPVX-22V0TT0 01.01A01>  at scbus5 target 0 lun 0 (pass3,ada3)
<Marvell Console 1.01>             at scbus9 target 0 lun 0 (pass4)
<WDC WD30EFRX-68N32N0 82.00A82>    at scbus10 target 0 lun 0 (pass5,ada4)
<WDC WD30EFRX-68N32N0 82.00A82>    at scbus11 target 0 lun 0 (pass6,ada5)
<Hitachi HDS723030ALA640 MKAOAAM0>  at scbus12 target 0 lun 0 (pass7,ada6)
<Hitachi HDS723030ALA640 MKAOAAM0>  at scbus13 target 0 lun 0 (pass8,ada7)
<WDC WD30EFRX-68N32N0 82.00A82>    at scbus14 target 0 lun 0 (pass9,ada8)
<WDC WD30EFRX-68N32N0 82.00A82>    at scbus15 target 0 lun 0 (pass10,ada9)
Hard disk controllers:
root@freenas:~ # lspci | grep -i controller
00:16.0 USB controller: Intel Corporation Atom processor C2000 USB Enhanced Host Controller (rev 03)
00:17.0 SATA controller: Intel Corporation Atom processor C2000 AHCI SATA2 Controller (rev 03)
00:18.0 SATA controller: Intel Corporation Atom processor C2000 AHCI SATA3 Controller (rev 03)
04:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9172 SATA 6Gb/s Controller (rev 12)
06:00.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 21)
07:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
08:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
09:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9230 PCIe SATA 6Gb/s Controller (rev 11)
Network cards:
root@freenas:~ # lspci | grep -ie 'ether\|network'
@Fredda uname -a shows:
root@freenas:~ # uname -a
FreeBSD freenas.pjakey.local 11.1-STABLE FreeBSD 11.1-STABLE #0 r321665+79f05c3dd3d(HEAD): Wed Jan 23 12:02:34 EST 2019     root@nemesis.tn.ixsystems.com:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64  amd64
Drive space:
me@freenas:~ % df -h
Filesystem                                               Size    Used   Avail Capacity  Mounted on
freenas-boot/ROOT/default                                447G    1.0G    446G     0%    /
devfs                                                    1.0K    1.0K      0B   100%    /dev
tmpfs                                                     16G     10M     16G     0%    /etc
tmpfs                                                    2.0G    8.0K    2.0G     0%    /mnt
tmpfs                                                    5.3T     41M    5.3T     0%    /var
fdescfs                                                  1.0K    1.0K      0B   100%    /dev/fd
tank                                                     7.5T    352G    7.2T     5%    /mnt/tank
tank/audio                                               8.6T    1.4T    7.2T    17%    /mnt/tank/audio
tank/audio/audiobooks                                    7.2T     14G    7.2T     0%    /mnt/tank/audio/audiobooks
tank/audio/podcasts                                      7.2T    188K    7.2T     0%    /mnt/tank/audio/podcasts
tank/backups                                              10T    2.9T    7.2T    29%    /mnt/tank/backups
tank/db                                                  7.2T    510M    7.2T     0%    /mnt/tank/db
tank/documents                                           8.2T    1.1T    7.2T    13%    /mnt/tank/documents
tank/iocage                                              7.2T    4.3M    7.2T     0%    /mnt/tank/iocage
tank/iocage/download                                     7.2T    188K    7.2T     0%    /mnt/tank/iocage/download
tank/iocage/download/11.2-RELEASE                        7.2T    126M    7.2T     0%    /mnt/tank/iocage/download/11.2-RELEASE
tank/iocage/images                                       7.2T    188K    7.2T     0%    /mnt/tank/iocage/images
tank/iocage/jails                                        7.2T    188K    7.2T     0%    /mnt/tank/iocage/jails
tank/iocage/jails/nextcloud                              7.2T    205K    7.2T     0%    /mnt/tank/iocage/jails/nextcloud
tank/iocage/jails/nextcloud/root                         7.2T    3.8G    7.2T     0%    /mnt/tank/iocage/jails/nextcloud/root
tank/iocage/jails/plex                                   7.2T    205K    7.2T     0%    /mnt/tank/iocage/jails/plex
tank/iocage/jails/plex/root                              7.2T    6.6G    7.2T     0%    /mnt/tank/iocage/jails/plex/root
tank/iocage/log                                          7.2T    205K    7.2T     0%    /mnt/tank/iocage/log
tank/iocage/releases                                     7.2T    188K    7.2T     0%    /mnt/tank/iocage/releases
tank/iocage/releases/11.2-RELEASE                        7.2T    188K    7.2T     0%    /mnt/tank/iocage/releases/11.2-RELEASE
tank/iocage/releases/11.2-RELEASE/root                   7.2T    449M    7.2T     0%    /mnt/tank/iocage/releases/11.2-RELEASE/root
tank/iocage/templates                                    7.2T    188K    7.2T     0%    /mnt/tank/iocage/templates
tank/movies                                              7.2T    188K    7.2T     0%    /mnt/tank/movies
tank/pictures                                            7.2T    3.2G    7.2T     0%    /mnt/tank/pictures
tank/software                                            7.3T    160G    7.2T     2%    /mnt/tank/software
tank/tvshows                                             7.6T    470G    7.2T     6%    /mnt/tank/tvshows
tank/videos                                              8.9T    1.7T    7.2T    19%    /mnt/tank/videos
tank/virtualmachines                                     9.2T    188K    9.2T     0%    /mnt/tank/virtualmachines
tank/.system                                             7.2T    471M    7.2T     0%    /var/db/system
tank/.system/cores                                       7.2T    913K    7.2T     0%    /var/db/system/cores
tank/.system/samba4                                      7.2T    606K    7.2T     0%    /var/db/system/samba4
tank/.system/syslog-b54c927c46164d20b01735720beb7291     7.2T    188K    7.2T     0%    /var/db/system/syslog-b54c927c46164d20b01735720beb7291
tank/.system/rrd-b54c927c46164d20b01735720beb7291        7.2T    188K    7.2T     0%    /var/db/system/rrd-b54c927c46164d20b01735720beb7291
tank/.system/configs-b54c927c46164d20b01735720beb7291    7.2T    2.1M    7.2T     0%    /var/db/system/configs-b54c927c46164d20b01735720beb7291
tank/.system/webui                                       7.2T    188K    7.2T     0%    /var/db/system/webui
tmpfs                                                    1.0G     82M    942M     8%    /var/db/collectd/rrd
Here is /etc/motd:
root@freenas:~ # cat /etc/motd
FreeBSD 11.1-STABLE (FreeNAS.amd64) #0 r321665+79f05c3dd3d(HEAD): Wed Jan 23 12:02:34 EST 2019
    FreeNAS (c) 2009-2019, The FreeNAS Development Team
    All rights reserved.
    FreeNAS is released under the modified BSD license.
    For more information, documentation, help or support, go here:
    http://freenas.org
Welcome to FreeNAS
  • debug-freenas-20200828093521.tgz
Samuel Tai
Was this originally an 11.1 installation? You may have to reboot back into that version, and try the 11.2 upgrade again.
