Installing TrueNAS Scale onto USB
georgelza
Hi all
I got my TrueNAS Core installed onto a USB atm,
Planning on now switching to TrueNAS Scale and thinking of doing the same, not seeing any notes on how to do this.
G
georgelza
... need some input/comment.
My "bunker" pool has 3 x 4TB space / RaidZ1.
I normally like installing apps on a SSD based "App" pool, keep it segregated. just finding, after last nights failure of my single M.2 based App pool, I got some 500GB SSD's... but don't have power cables, was thinking of taking 2 and creating a mirror pair.
I can create a directory on the "Bunker" pool and install apps there.
so it's a time to do this... vs going and getting the cables, but also using 2 Sata ports on my LSI controller.
comments please.
extra fact, part of the Scale desire is to run docker images, which i think would be better suited on the mirror pair of 500GB SSD's. so might be answering my own question.
G
georgelza
hmm, and while I'm thinking out loud.
At the moment I got my TrueNAS CORE OS deployed on a single 16GB USB, slightly worried about the state of the USB...
So want to deploy the new SCALE onto a new USB, as per above question...
The other option is to install it onto this App Mirror pair ?
Comments please.
G
Do you mean going to the Update screen, changing trains to SCALE and then doing the "Upgrade"?
Also, running on a USB stick is not great... USB to SATA with an SSD is much better.
You can't share the OS and a "data pool" (apps live on data pools) without going "off piste" and unsupported (but there is a method if you want to look it up).
georgelza
If you propose I do it via this then sure...
thought I would build a new USB and then "pull" the storage configurations into it... but happy to run a upgrade, sure that's well tested.
georgelza
ok... well then I'm def not using those 2 x 500GB's for that.
Could this not have been done by partitioning those 500GB's into say 50GB OS and 450GB for data usage.
With he sizes of discs today it is a big waste to allocate one or 2 in mirror purely then for OS.
funny enough, App pool has been on a M.2 device and OS on a USB, the USB outlived/lasted the M.2.
I will then rather do an in place upgrade,
georgelza
with a plan to relook location of the OS down the line ?
G
That's the "hack" I'm talking about... unsupported and can cause you trouble down the line when a disk fails.
You don't need to mirror the OS, just keep config backups.
You're certainly in the 1% on that one.
georgelza
h
ehehe ok, ok so won't do...
but it makes so much sense... considering drive sizes today, for home usage.
I understand for enterprise they can throw away a drive for the OS.
G
georgelza
well i could maybe then buy the smallest M.2 I can pick up, replace that onto the MB as a OS host... and then add the 2 SSD's for Application.
How difficult is it to move the OS from a USB onto the M.2 thinking it can be done using a simple DD command, or is there a TrueNAS capability / functionality for this.
Just looking at time line and ($$$ flow atm)
G
So do it if you can't stand to see "waste"... just know these things:
Sounds fine.
Don't do that.
Save your config.
Fresh install onto M.2
Restore config.
Done.
georgelza
Don't do that.
Save your config.
Restore config.
Done.
well that's the procedure/functionality then.
Will see quickly what M.2's the local shop has and at what cost.
aka upgrade CORE->SCALE in place on the USB now or tell SCALE during process to install directly onto new M.2 available.
G
georgelza
Whats the view of M.2 based PCI cards on hosting a couple of large/fast M.2's for pool storage ?
G
That's OK. M.2 is just PCI lanes anyway.
georgelza
comments please.
G
update, no M.2 SSD in town, only M.2 NVME which does not work on my MB,
going to see if I can for now fit a standard SSD/500Gb, install onto that, then source a M.2 and then do a reinstall onto that in 2 odd weeks.
if I can't get the SSD/500GB working for now, got a lack of power points... will then do in place upgrade, and then do re-install onto new M.2 SSD in 2 weeks.
G
