Install problem - TrueNAS 13.0
RichyM
My 1st post.
I have built a NAS using the following equipment.
  • Motherboard make and model - ASUS ROG STRIX 550-I Gaming
  • CPU make and model - AMD Ryzen 3 3200g 3.6 GHZ AM4 Quad Core Processor mit Radeon Vega 8 Grafik
  • RAM quantity - 2 x 16GB DDR4-3600MHz + Intel Optane NVMe H10 HBRPEKNX0202A 0YDH3V 512GB + 32GB M2 80mm SSD
  • Hard drives, quantity, model numbers, and RAID configuration, including boot drives - 5 x Toshiba NAS N300 6TB 7200rpm/256MB Buffer. Boot Drive => Verbatim Vi550 S3 SSD - internal SSD 128GB (2.5")
  • Hard disk controllers - M.2 SATA Adapter M.2 M-Key to 5 port SATA 3.0 6Gbps Expansion Card with JMB585 Chipset of 2280 Size Adapter Card for HHD expansion.
  • Network cards - Intel I225-V 2.5Gb Ethernet port - AMD 550 Chipset
  • Power Supply - EVGA 650 GM
  • Enclosure Case - Jonsbo N1 NAS Server
  • Issue - When booting to install the TrueNAS 13.0 I get the following script on the screen. The install goes no further.
  • Help needed.
  • Photos attached of screen during TrueNAS install (x2).
  • I am stuck. Looking forward to any help.
  • Thanks in advance
  • Richy
RichyM
Hi Again,
2 things I have realized are that the Intel Octane 512GB + 32GB is not recognised by the BIOS - or at least I cannot see it listed anywhere in the BIOS. The 2nd thing is that it seems that this ASUS M-Board only supports 4 drives in RAID mode. So I guess I will need to reconfigure this. Say. 4 onto the ASUS M-Board SATA connectors and the extra (5th) to the M.2 NVMe adapter.
Any guidance most welcome.
Richard
