- Feb 15, 2014
Still a better experience than vbulletin.Ahhh, forum software from hell...
Mods: you can delete this post.
What you want is also a stable temp, it doesn't matter much that you are at 35 °C if the temp oscillate between 30 and 40 °C every minute... you're much better at 30 or 40 °C with a rock stable temp.
60 °C is cooking it, even a good quality one. Fans are cheap, drives aren't, and your data is probably priceless...
The current version of my script is posted here. It lives at /root/bin/control_hd_temp.pl@Kevin Horton : Would you care to share some further details on how your cronjob works? (<- newbie lvl plz)
Ipmiutil works fine under Windows, no assembly required.I was having a Hell of a time when I ran into this problem in a Windows only environment.
[root@freenas ~]# ipmitool sensor list all System Temp | 28.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000 Peripheral Temp | 29.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000 CPU Temp | 0x8 | discrete | 0x0700| na | na | na | na | na | na FAN 1 | 525.000 | RPM | nc | 300.000 | 450.000 | 600.000 | 18975.000 | 19050.000 | 19125.000 FAN 2 | 1575.000 | RPM | ok | 300.000 | 450.000 | 600.000 | 18975.000 | 19050.000 | 19125.000 FAN 3 | na | | na | na | na | na | na | na | na FAN 4 | 1725.000 | RPM | ok | 300.000 | 450.000 | 600.000 | 18975.000 | 19050.000 | 19125.000 FAN A | 975.000 | RPM | ok | 300.000 | 450.000 | 600.000 | 18975.000 | 19050.000 | 19125.000 Vcore | 0.928 | Volts | ok | 0.480 | 0.512 | 0.544 | 1.488 | 1.520 | 1.552 3.3VCC | 3.392 | Volts | ok | 2.816 | 2.880 | 2.944 | 3.584 | 3.648 | 3.712 12V | 11.978 | Volts | ok | 10.494 | 10.600 | 10.706 | 13.091 | 13.197 | 13.303 VDIMM | 1.504 | Volts | ok | 1.152 | 1.216 | 1.280 | 1.760 | 1.776 | 1.792 5VCC | 5.088 | Volts | ok | 4.096 | 4.320 | 4.576 | 5.344 | 5.600 | 5.632 -12V | -12.098 | Volts | ok | -13.844 | -13.650 | -13.456 | -10.934 | -10.740 | -10.546 VBAT | 3.088 | Volts | ok | 2.816 | 2.880 | 2.944 | 3.584 | 3.648 | 3.712 VSB | 3.328 | Volts | ok | 2.816 | 2.880 | 2.944 | 3.584 | 3.648 | 3.712 AVCC | 3.408 | Volts | ok | 2.816 | 2.880 | 2.944 | 3.584 | 3.648 | 3.712 Chassis Intru | 0x0 | discrete | 0x0000| na | na | na | na | na | na [root@freenas ~]# ipmitool sensor thresh “FAN 1” lower 400 500 700 Valid threshold '1”' for sensor '“FAN' not specified! [root@freenas ~]#
[root@freenas ~]# ipmitool sensor thresh “FAN 1” lower 400 500 700 Valid threshold '1”' for sensor '“FAN' not specified! [root@freenas ~]# ipmitool sensor thresh “FAN1” lower 400 500 700 Locating sensor record '“FAN1”'... Sensor data record not found! [root@freenas ~]# ipmitool sensor thresh “FAN/ 1” lower 400 500 700 Valid threshold '1”' for sensor '“FAN/' not specified! [root@freenas ~]# ipmitool sensor thresh “PIZZA” lower 400 500 700 Locating sensor record '“PIZZA”'... Sensor data record not found! [root@freenas ~]# ipmitool sensor thresh “FAN1” lower 400 500 700 Locating sensor record '“FAN1”'... Sensor data record not found! [root@freenas ~]#
Try removing the space between "FAN" and "1". I.e.ipmitool sensor thresh “FAN1” lower 400 500 700
ipmitool> sensor SDRR successfully erased Load SDRs from 0x20 Get SDR 0000 command failed: Requested sensor, data, or record not found Get SDR 0000 command failed: Requested sensor, data, or record not found Get SDR 0000 command failed: Requested sensor, data, or record not found Get SDR 0000 command failed: Requested sensor, data, or record not found Get SDR 0000 command failed: Requested sensor, data, or record not found Get SDR 0000 command failed: Requested sensor, data, or record not found Get SDR 0000 command failed: Requested sensor, data, or record not found Get SDR 0000 command failed: Requested sensor, data, or record not found Get SDR 0000 command failed: Requested sensor, data, or record not found Get SDR 0000 command failed: Requested sensor, data, or record not found ipmitool>
ipmitool> ipmitool sdr fill sensors
fill <option> sensors Creates the SDR repository for the current configuration nosat Creates the SDR repository for the current configuration, without satellite scan file <file> Load SDR repository from a file range <range> Load SDR repository from a provided list or range. Use ',' for list or '-' for range, eg. 0x28,0x32,0x40-0x44
That's a new one. A factory reset of the BMC should do the trick. Maybe changing fan modes if only the fans are affected.
It reports everything as normalWhat does the IPMI webGUI report, sensors-wise?
NameStatus
Reading
System Temp Normal 26 degrees C Peripheral Temp Normal 26 degrees C CPU Temp Uninstall FAN 1 Normal 1875 R.P.M FAN 2 Normal 1950 R.P.M FAN 3 N/A Not Present! FAN 4 Normal 2175 R.P.M FAN A Normal 2100 R.P.M Vcore Normal 0.968 Volts 3.3VCC Normal 3.392 Volts 12V Normal 11.978 Volts VDIMM Normal 1.504 Volts 5VCC Normal 5.088 Volts -12V Normal -12.098 Volts VBAT Normal 3.088 Volts VSB Normal 3.344 Volts AVCC Normal 3.392 Volts Chassis Intru OK![]()
So it probably didn't change anything on the BMC.
