Hi Everyone,
Sorry to bump this thread.
I have been looking at a couple of different WD drives to upgrade my PVR with.
Namely the WD20EARX and WD20EZRX. The Former is supposed to be a decicated AV drive, it uses less power (4 watts to 6 watts of the WD20EZRX) going by the specs but I wonder if this is marketing hype?
Reading on forums it appears that I can use the cheaper WD20EZRX (even though this is not an AV drive will it make any difference?) if i set the jumpers to the 3Gbps setting becasue the PVR is old and uses the Sata I type.
I am here to ask about the timer on these drives, im a noob but would be able to change this value, would this procedure still be of benefit when adding the drive to a PVR? If so what would the recomended amount of time be if any (or disabled).
Thank you for any advice.
Statalite
I wonder if this is marketing hype?..........will it make any difference?
WD Purples might be more up your alley.
Please take any discussions about the Purple drives elsewhere. This thread is for hacking the WD Green drives.
Thanks. :)
Placing the jumper across pins 5 and 6 will force the drive to use the slower SATA 1.5Gbits/s (OPT1) transferspeed. This is only necessary for certain SATA controllers that do not properly implement the SATA 3.0 Gb/s speed negotiation, like the VIA VT8237 and VT8237R south bridge chips.
That depends on how the PVR works. To be honest, I wouldn't use Greens in a PVR environment to preclude the possibility of problems.
Alright DAD! :p
But I still would like to know what he means by changing the jumper settings.
EDIT:
Ok, here is what my google came up with.
Hi Everyone,
Statalite
Is this a standalone PVR, or are you having a PVR write to FreeNAS via ethernet?
I can't see how disabling head parking would negatively impact performance.
It was two years ago, I can't remember for sure but this post claims that such behavior can occur if you don't power cycle drive in between. I do remember that I observed decrease in performance.
http://lime-technology.com/forum/index.php?PHPSESSID=63276d6f794f6d31e53c72fc63cc855d&topic=15554.15
