[FreeNAS 9 Plugins] - SAB / SB / CP / HP / Maraschino / HTPC / Mylar / LL / Gamez
Allred
I did restart it. Im going to try another movie and see. Its taking forever to dl a file dont know if the QOS in my router is slowing it down or what its at like 2.90mbs right now.
Joshua Parker Ruehlig
2.90mbs on transmission? that's actually decent. if you do the port forward it allows more peers to connect. theres a screen in transmission that shows if the port is correctly forwarded.
sabnzbd should max your download speed, one of the advantages of Usenet.
Allred
Hey Joshua,
Got it all running thanks for the help. Hey one more question what do I need to change to be able to move a file out of uncompleted to the videos file it wont let me. Also Im trying to set up headphones. do you have a walkthru for that. I tried to wing it but not getting it to work like CP or sickbeard. I want it to download then move the same way.
Thanks,
Hey Joshua,
Thanks,
"move a file out of uncompleted to the videos file"
I'm assuming you meant "move a file from incomplete to the videos folder", this should happen automatically. If this failed there are logs in /usr/local/share/nzbToMedia, or available in sabnzbd if that's what did the downloading+post-processing.
No writeup on HP right now, and I probably won't do it for a while. https://github.com/clinton-hall/nzbToMedia/wiki is where I would look.
Allred
Ok these are files that complete but I didnt reboot CP so it didnt move them. When I go into the folder in windows I can see and click it but not move it says I dont have permissions to do that what do I change?
ok look at that link still lost. So heres what I have setup
I made the following folders
/mnt/media/downloads/headphones
/mnt/media/downloads/headphones/complete
/mnt/media/downloads/headphones/incomplete
/mnt/media/music
In Usenet I have downloads set to goto /mnt/media/downloads/headphones
On torrents i have transmission and the same /mnt/media/downloads/headphones
Under post-process I have the /mnt/media/music this is where I want everything to end up after downloading from either download program.
Right now if I click a artist and it downloads in transmission when its done its not removed it stays in the folder /mnt/media/download/transmission/incomplete
Ideas on what I did wrong?
I don't really know about Windows permissions and try to stay away from that mess...
I suggest you just go in CP > Wanted > ... > Manual Folder Scan
Then pick whatever folder contains the movies you want CP to rename/cleanup. Before you do that it would help to add an .NFO file in each directory that contains a movie otherwise CP might not be able to figure out what movie it is.
My .NFO's usually are just a single line that is the IMDB url, for example "http://www.imdb.com/title/tt0114709" for Toy Story.
I can't really help you with HP, cause I've never really used/tested it. Once thing I do notice though is that you aren't following the same pattern I laid out for folders. download should go in /mnt/media/downloads/(sabnzbd|transmission)/complete/music
TheDubiousDubber
Wondering if someone in here can help me out. I have Sickbeard set up with SABnzbd, and everything appears to be working as intended, but I'm getting error logs in Sickbeard that are a bit confusing to me. They keep showing up about permissions and Sickbeard failed to change permissions to 664. Not sure what is going on as Sickbeard has the proper permissions to move and rename the file downloaded by SABnzbd. I also don't understand why it's trying to change permissions in the first place as I don't see that anywhere in settings.
Ray Milyard
So looks like last SickRage update broke mine. I can no longer add files to Season folders and Re-Scan. It does nothing. Also keep getting 404 errors etc. Any ideas?
Ray Milyard
Might be same issue I am now having.
RobertT
I just noticed I am getting this error in sickbeard..
Any thoughts?
[Errno 24] Too many open files: '/usr/pbi/sickbeard-amd64/share/sickbeard/Sick-Beard/gui/slick/interfaces/default/home.tmpl'
Ray Milyard
I am new to FreeNAS but I have something like this setup on my IX4-300d. I was given a Free Lenovo TS130 with Xeon quad and 16gb of ram so I am going to switch to this. Using (4) 2tb drives.
I have followed you guide step by step but have run into some issues.
Using this web page: https://www.jruehlig.com/wordpress/installation-configuration-of-freenas-plugins/#comment-381
Jails > Add Jails
  • Jail Name = download_jail
  • Add Storage
    • Source = /mnt/tank/media
    • Destination = /mnt/media (see error)
Error: The path could not be mounted /mnt/tank/media: Mount failed (64) -> mount: /mnt/tank/jails/download_jail/mnt/media: No such file or directory
I have even SSH in system and goto /mnt and make folder media and still get same error.
Transmission WebGUI
Download Directory = /mnt/media/downloads/transmission/complete
Since can't make /mnt/media folder I can use it here. However when I try to change for now to /mnt/tank/jails/download)jails/media it seems like this setting never gets saved. Same with changing the Encryption.
Changing to the folder via the Transmission web page seems to work but since from the Jails the /mnt/media folder isn't there not sure about this.
Side notes something else I have found. Seems like anytime I stop a plugin via FreeNAS/Plugins whenever try to restart them they never start.
Plugin Jail Command-Line
root@download_jail:/ # service transmission stop && service sickbeard stop
Stopping transmission.
Stopping sickbeard.
Waiting for PIDS: 41558.
root@download_jail:/ # pkg install git nginx python py27-sqlite3 sqlite3
Updating repository catalogue
digests.txz 100% 1091KB 1.1MB/s 931.3KB/s 00:01
packagesite.txz 100% 5189KB 1.7MB/s 938.8KB/s 00:03
Incremental update completed, 23445 packages processed:
23187 packages updated, 335 removed and 258 added.
New version of pkg detected; it needs to be installed first.
The following 1 packages will be installed:
Upgrading pkg: 1.2.7_2 -> 1.3.5.1
The installation will require 772 kB more space
1 MB to be downloaded
Proceed with installing packages [y/N]:y
pkg-1.3.5.1.txz 100% 1931KB 965.6KB/s 1.5MB/s 00:02
Checking integrity... done
[1/1] Upgrading pkg from 1.2.7_2 to 1.3.5.1... done
If you are upgrading from the old package format, first run:
# pkg2ng
FreeBSD repository is up-to-date
All repositories are up-to-date
pkg: Repo FreeBSD needs schema upgrade from 2006 to 2010 but it is opened readonly
pkg: need to re-create repo FreeBSD to upgrade schema version
Updating database digests format: 100%
pkg: No packages available to install matching 'git' have been found in the repositories
This is what error I am getting.
So I haven't been able to really continue. Please any help would be GREAT!
Joshua Parker Ruehlig or anyone
I have started up over due to some issues. However now I can seem to get the files in right folders etc.
I am not sure in the storage for the jail how I should be setting this up.
If anyone can help me out that would be GREAT!
not sure what you are asking. do you have any specific questions?
if you have questions about the steps on my blog, please post a comment there and I'll email you.
David Prince
Could I ask if it is possible to add a password to the user "media" or will this cause problems?
I want /mnt/tank/media to be available as a CIFS share, and I don't like having a user on a share without a password.
David Prince
Actually, that isn't really the right question.
I have everything on my server working correctly, except I don't have write access (or rather sufficient privileges) to /mnt/tank/media/video through my CIFS share (to /mnt/tank/media). I do have write access to other folders in /mnt/tank/media. I can't add my windows user (and associated freenas user) to "video" through windows security/permissions.
I'm a bit baffled as to why. Everything was set up exactly as in Joshua's tutorial.
The problem persists if change my windows user to group "media".
Any thoughts would be greatly appreciated.
where are you setting up this 'media' group?
I usually avoid windows/cifs but in the past I have set this up. I just have cifs always access the media share as the media user. I then setup accounts at the cifs level. when I try to touch the share it asks me for the cifs credentials.
when I set this up it was with freebsd configs but I'm pretty sure all the options are available from FN.
finally, ask in a different section of the forum. others probably know this subject better
David Prince
Thanks, for whatever reason /mnt/tank/media/downloads and /mnt/tank/media/video were set during the process (probably my own error) as 755. Not allowing users in the group to modify. Sorted!
Many many thanks for your guide. Genius really.
I have a Noob question so sorry guys.
My Sabnzbd is saying has an update. When I click on it I get this page:
http://sourceforge.net/projects/sabnzbdplus/files/sabnzbdplus/0.7.19/
Is there a way to install this? Doesn't it update like sickrage or CP?
nope, sabnzbd are packaged as releases and don't have a built in updating method. thanks for the heads up. I'll build a pbi tonight and submit it to the FN repo.
for you, just wait a few days, then click update in FN plugin's menu
Ray Milyard
Didn't read info for it yet but does it add anything or just big fixes?
