* Failed to check for alert Quota: concurrent.futures.process._RemoteTraceback:
psoni
Debug attached.
Version -TrueNAS-12.0-U7
Something I can do to fix this if it's a problem?
The following alert has been cleared:
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 94, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 33, in _call
with Client('ws+unix:///var/run/middlewared-internal.sock', py_exceptions=True) as c:
File "/usr/local/lib/python3.9/site-packages/middlewared/client/client.py", line 283, in __init__
self._ws.connect()
File "/usr/local/lib/python3.9/site-packages/middlewared/client/client.py", line 124, in connect
rv = super(WSClient, self).connect()
File "/usr/local/lib/python3.9/site-packages/ws4py/client/__init__.py", line 223, in connect
bytes = self.sock.recv(128)
socket.timeout: timed out
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/alert.py", line 740, in __run_source
alerts = (await alert_source.check()) or []
File "/usr/local/lib/python3.9/site-packages/middlewared/alert/base.py", line 211, in check
return await self.middleware.run_in_thread(self.check_sync)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/alert/source/quota.py", line 38, in check_sync
datasets = self.middleware.call_sync("zfs.dataset.query_for_quota_alert")
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1276, in call_sync
return self.run_coroutine(self._call_worker(name, *prepared_call.args))
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1312, in run_coroutine
return fut.result()
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 438, in result
return self.__get_result()
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 390, in __get_result
raise self._exception
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1227, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1154, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1128, in run_in_executor
  • debug-VISPANAS01-20231114113733.tgz
