[EFAULT] VM will not start as DISK Device: /dev/zvol/Pool 1/xxxx device(s) are not available.
rjone1
Hi community,
I upgraded from TrueNAS Core to Scale and I need some guidance. I've created VMs in core perfectly fine but Scale seems to be a different animal all together. As the subject of the thread insinuates I can't start my VM because it seems to not be able to locate or have permissions to access the location it created where the files are stored. I deleted and recreated the VM thinking maybe I missed a step but still running into this issue. Currently I'm trying to use a CentOS iso for the image. I read in another forum there may be a permission issue but this was during the beta Forums TrueNAS TrueNAS SCALE TrueNAS SCALE 21.06-BETA Now Available! and it wasn't clear on a solution. Here is the error log from the failed start after install.
report_problem CallError​
[EFAULT] VM will not start as DISK Device: /dev/zvol/Pool 1/VM/CentOS-ysh3w device(s) are not available.
remove_circle_outlineMore info...
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 175, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1275, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1261, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1129, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 39, in start
await self.middleware.run_in_thread(self._start, vm['name'])
File "/usr/lib/python3/dist-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 62, in _start self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name))
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 138, in start
raise CallError(
middlewared.service_exception.CallError: [EFAULT] VM will not start as DISK Device: /dev/zvol/Pool 1/VM/CentOS-ysh3w device(s) are not available.
KrisBee
Got a horrible feeling this is because you have a space in your pool name - "Pool 1". So the middleware throws that final error re: disk device not available. Search the forum for other reports of the same issue.
TheNiTz
interesting I'm having the same problem existing VM and new VMs all give me the same issue but it's only with 1 of my Pools if I save the VM Location as my 1st pool (slow HDD pool) it works perfectly
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 175, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self, File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1275, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1261, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1129, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 39, in start await self.middleware.run_in_thread(self._start, vm['name']) File "/usr/lib/python3/dist-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 62, in _start self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name)) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor_base.py", line 138, in start raise CallError( middlewared.service_exception.CallError: [EFAULT] VM will not start as DISK Device: /dev/zvol/SDDs/QB VM/QbServer-qe2j9m device(s) are not available.
identical
I see a space in your path also...
What part of @KrisBee's suggestion wasn't clear?
Can you try it in a path that doesn't contain a space?
TheNiTz
Yes it worked - just found it interesting that it worked for a few days and then decided it didn't like it.
