Delete Interface Overview from Dashboard?
TAC
My MoBo has to NICs and I am only using one of them. Both show up on my Dashboard and I was wondering if I can delete the second Interface (igb0) that always reports LINK STATE DOWN, No Traffic?
Yes. Its called tunables.
TAC
@elvisimprsntr In looking at my System / Tunables I see hint.isp.0.role, hint.isp.1.role,...,hint.isp.3.role. It's not clear on which 'Tunable' might remove igb0 from my dashboard, or what value I need to change.
Since I really don't want to disable my primary Ethernet port I'm hesitant to start changing things. :smile: Do I change the Value to 1, or just disable?
I did look at the documentation and it looks like I'll need to reboot the system for the change to take place.
TAC
@elvisimprsntr added the following and got the igb0 interface to disappear! Thanks for the pointers. I find it was important to have '...disabled', and not '...disable'! :smile:
Thanks again.
-TAC
Scharbag
Strange - on my system, 2 of the 4 unused interfaces hide as expected. 2 do not.
Anyone else run into this? I may just remove the cards as I do not have a 10GigE switch.
Cheers,
Bedreddin
Dear @elvisimprsntr
i have applied the command hint.igb.0.disabled=1, i got the following error message: zsh: command not found: hint.igb.0.diasbled=1
i have the following machine:
System Information
Version:TrueNAS-13.0-U2
i have delete the interface igb0 and igb1 from tunables and restarted the machine, it didn't work.
