Core to Scale and VM Migration
Lee Spangler
I have migrated from Core to Scale - with the understanding the VMs could also make the migration. I am now having a permission issue with all my VMs.
The shell reports the following:
WARNING: Your user does not have sudo privileges so /usr/bin/virsh command will run
on your behalf. This might cause permission issues.
Connected to domain '37_Hassio'
My log file is attached.
All of the VMs start, but they will not truly boot into the VM.
Does anyone have any insight on how to address this?
Thanks,
-LeeTXJD
  • 37_Hassio.log.txt
claudius139
Thanks,
-LeeTXJD
Lee, did you find an answer to your question? I just upgraded to Scale and have exactly the same issue with my VM (same message)
Lee Spangler
I am going to disappoint you a bit... I don't remember exactly (to the commands) how I fixed it.
However, it is a permissions issue with "user" libvirt-qemu. VMs under Scale operate in part with the permissions of user libvert-qemu
The solution was - in the ACL editor or with the command line - adding libvirt-qemu so it has permission. Add the user libvirt-qemu to the filesystem ACL (and apply the permission recursively).
Just in case you are very new - don't create that user. It exists already. However, I can't find the instructions I followed to modify the permissions appropriately.
Do more searches (here and on google) dealing with libvirt-qemu and TrueNas Scale. I am sorry I can only provide this clue.
