All jails missing
Zofoor
Hi all!
I am running the latest version of Freenas, and usually I don't have troubles.
Yesterday I rebooted my server and after that all jails aren't showed anymore, but I can still see the jail storage configuration with all my jails. Also I can see the data of the jails inside the dataset.
It seems like that the jail service isn't running
[root@freenas] /etc/rc.d# ps aux
USER PID %CPU %MEM VSZ RSS TT STAT STARTED TIME COMMAND
root 11 800.0 0.0 0 128 - RL 9:21AM 223:48.34 [idle]
root 5895 1.7 0.0 232260 22016 - Ss 9:23AM 0:16.56 /usr/local/sbin/collectd
root 0 0.0 0.0 0 13744 - DLs 9:21AM 0:01.29 [kernel]
root 1 0.0 0.0 9488 848 - ILs 9:21AM 0:00.03 /sbin/init --
root 2 0.0 0.0 0 16 - DL 9:21AM 0:00.00 [crypto]
root 3 0.0 0.0 0 16 - DL 9:21AM 0:00.00 [crypto returns]
root 4 0.0 0.0 0 48 - DL 9:21AM 0:00.10 [cam]
root 5 0.0 0.0 0 64 - DL 9:21AM 0:00.00 [ctl]
root 6 0.0 0.0 0 240 - DL 9:21AM 0:00.28 [zfskern]
root 7 0.0 0.0 0 32 - DL 9:21AM 0:00.13 [pagedaemon]
root 8 0.0 0.0 0 16 - DL 9:21AM 0:00.00 [vmdaemon]
root 9 0.0 0.0 0 16 - DL 9:21AM 0:00.00 [pagezero]
root 10 0.0 0.0 0 16 - DL 9:21AM 0:00.00 [audit]
root 12 0.0 0.0 0 400 - WL 9:21AM 0:05.40 [intr]
root 13 0.0 0.0 0 128 - DL 9:21AM 0:00.00 [ng_queue]
root 14 0.0 0.0 0 48 - DL 9:21AM 0:00.83 [geom]
root 15 0.0 0.0 0 16 - DL 9:21AM 0:00.48 [rand_harvestq]
root 16 0.0 0.0 0 80 - DL 9:21AM 0:00.21 [usb]
root 17 0.0 0.0 0 16 - DL 9:21AM 0:00.04 [acpi_thermal]
root 18 0.0 0.0 0 16 - DL 9:21AM 0:00.01 [bufdaemon]
root 19 0.0 0.0 0 16 - DL 9:21AM 0:00.01 [vnlru]
root 20 0.0 0.0 0 16 - DL 9:21AM 0:00.08 [syncer]
root 201 0.0 0.0 14460 1884 - Is 9:21AM 0:00.00 daemon: /usr/local/bin/middlewared[203] (daemon)
root 203 0.0 0.1 346196 86660 - I 9:21AM 0:01.57 python2.7: middlewared (python2.7)
root 263 0.0 0.0 0 16 - DL 9:21AM 0:00.00 [g_mp_kt]
root 805 0.0 0.0 0 16 - DL 9:21AM 0:00.00 [ftcleanup]
root 872 0.0 0.0 0 16 - DL 9:21AM 0:00.00 [ipmi0: kcs]
root 1284 0.0 0.0 16712 2120 - Is 9:22AM 0:00.00 /usr/sbin/moused -p /dev/ums0 -t auto -I /var/run/moused.ums0.pid
root 1301 0.0 0.0 14048 5828 - Is 9:22AM 0:00.04 /sbin/devd -q
root 1457 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [Timer]
root 1458 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [Timer]
root 1526 0.0 0.0 38428 3592 - I 9:22AM 0:00.00 /usr/local/sbin/syslog-ng -p /var/run/syslog.pid
root 1527 0.0 0.0 68812 8736 - Ss 9:22AM 0:00.22 /usr/local/sbin/syslog-ng -p /var/run/syslog.pid
root 1655 0.0 0.0 6304 2272 - Ss 9:22AM 0:02.99 /usr/sbin/watchdogd
root 1676 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[0] ada0p1]
root 1677 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[1] ada0p1]
root 1678 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[2] ada0p1]
root 1679 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[3] ada0p1]
root 1680 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[4] ada0p1]
root 1681 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[5] ada0p1]
root 1682 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[6] ada0p1]
root 1683 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[7] ada0p1]
root 1685 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[0] ada6p1]
root 1686 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[1] ada6p1]
root 1687 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[2] ada6p1]
root 1688 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[3] ada6p1]
root 1689 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[4] ada6p1]
root 1690 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[5] ada6p1]
root 1691 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[6] ada6p1]
root 1692 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[7] ada6p1]
root 1694 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[0] ada5p1]
root 1695 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[1] ada5p1]
root 1696 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[2] ada5p1]
root 1697 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[3] ada5p1]
root 1698 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[4] ada5p1]
root 1699 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[5] ada5p1]
root 1700 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[6] ada5p1]
root 1701 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[7] ada5p1]
root 1703 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[0] ada4p1]
root 1704 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[1] ada4p1]
root 1705 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[2] ada4p1]
root 1706 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[3] ada4p1]
root 1707 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[4] ada4p1]
root 1708 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[5] ada4p1]
root 1709 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[6] ada4p1]
root 1710 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[7] ada4p1]
root 1712 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[0] ada3p1]
root 1713 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[1] ada3p1]
root 1714 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[2] ada3p1]
root 1715 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[3] ada3p1]
root 1716 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[4] ada3p1]
root 1717 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[5] ada3p1]
root 1718 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[6] ada3p1]
root 1719 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[7] ada3p1]
root 1721 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[0] ada2p1]
root 1722 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[1] ada2p1]
root 1723 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[2] ada2p1]
root 1724 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[3] ada2p1]
root 1725 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[4] ada2p1]
root 1726 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[5] ada2p1]
root 1727 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[6] ada2p1]
root 1728 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[7] ada2p1]
root 1730 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[0] ada1p1]
root 1731 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[1] ada1p1]
root 1732 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[2] ada1p1]
root 1733 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[3] ada1p1]
root 1734 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[4] ada1p1]
root 1735 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[5] ada1p1]
root 1736 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[6] ada1p1]
root 1737 0.0 0.0 0 16 - DL 9:22AM 0:00.00 [g_eli[7] ada1p1]
root 2018 0.0 0.0 30260 18104 - Ss 9:22AM 0:00.32 /usr/sbin/ntpd -g -c /etc/ntp.conf -p /var/run/ntpd.pid -f /var/db/ntpd.drift
root 2021 0.0 0.0 14468 2008 - Ss 9:22AM 0:00.84 /usr/sbin/powerd
uucp 2127 0.0 0.0 20968 2608 - Ss 9:22AM 0:00.14 /usr/local/libexec/nut/usbhid-ups -a ups
uucp 2129 0.0 0.0 69968 2432 - Ss 9:22AM 0:00.05 /usr/local/sbin/upsd
uucp 2132 0.0 0.0 20792 2384 - Is 9:22AM 0:00.00 /usr/local/bin/upslog -s ups -l /var/log/ups.log -i 300
root 2135 0.0 0.0 20812 2400 - Is 9:22AM 0:00.00 /usr/local/sbin/upsmon localhost
uucp 2136 0.0 0.0 20812 2412 - S 9:22AM 0:00.04 /usr/local/sbin/upsmon localhost
root 2431 0.0 0.0 61028 6628 - Is 9:22AM 0:00.00 /usr/local/sbin/sshd
root 2843 0.0 0.0 30732 4956 - I 9:22AM 0:00.22 /usr/local/sbin/smartd -i 1800 -c /usr/local/etc/smartd.conf -p /var/run/smartd.pid
root 3012 0.0 0.0 34272 6328 - Is 9:22AM 0:00.00 nginx: master process /usr/local/sbin/nginx
www 3013 0.0 0.0 34272 6652 - I 9:22AM 0:00.04 nginx: worker process is shutting down (nginx)
root 3258 0.0 0.2 275596 101520 - I 9:22AM 0:05.91 python: alertd (python2.7)
root 3309 0.0 0.3 385456 168976 - S 9:22AM 0:14.46 /usr/local/bin/python -R /usr/local/www/freenasUI/manage.py runfcgi method=threaded host=127.0.0.1 port=9042 pidfile=/var/run/django.pid (python2.7)
messagebus 3321 0.0 0.0 21264 2788 - Is 9:22AM 0:00.00 /usr/local/bin/dbus-daemon --system
root 3533 0.0 0.0 14460 2004 - Is 9:22AM 0:00.00 daemon: /usr/local/libexec/nas/register_mdns.py[5720] (daemon)
root 4101 0.0 0.0 51712 4824 - Is 9:22AM 0:00.03 /sbin/zfsd
root 4112 0.0 0.0 20740 2372 - Ss 9:22AM 0:00.01 /usr/sbin/cron -s
root 4427 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[0] gptid/cd49]
root 4428 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[1] gptid/cd49]
root 4429 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[2] gptid/cd49]
root 4430 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[3] gptid/cd49]
root 4431 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[4] gptid/cd49]
root 4432 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[5] gptid/cd49]
root 4433 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[6] gptid/cd49]
root 4434 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[7] gptid/cd49]
root 4437 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[0] gptid/cc8f]
root 4438 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[1] gptid/cc8f]
root 4439 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[2] gptid/cc8f]
root 4440 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[3] gptid/cc8f]
root 4441 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[4] gptid/cc8f]
root 4442 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[5] gptid/cc8f]
root 4443 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[6] gptid/cc8f]
root 4444 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[7] gptid/cc8f]
root 4448 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[0] gptid/ac61]
root 4449 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[1] gptid/ac61]
root 4450 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[2] gptid/ac61]
root 4451 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[3] gptid/ac61]
root 4452 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[4] gptid/ac61]
root 4453 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[5] gptid/ac61]
root 4454 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[6] gptid/ac61]
root 4455 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[7] gptid/ac61]
root 4457 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[0] gptid/cbd5]
root 4458 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[1] gptid/cbd5]
root 4459 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[2] gptid/cbd5]
root 4460 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[3] gptid/cbd5]
root 4461 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[4] gptid/cbd5]
root 4462 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[5] gptid/cbd5]
root 4463 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[6] gptid/cbd5]
root 4464 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[7] gptid/cbd5]
root 4486 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[0] gptid/cb25]
root 4487 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[1] gptid/cb25]
root 4488 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[2] gptid/cb25]
root 4489 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[3] gptid/cb25]
root 4490 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[4] gptid/cb25]
root 4491 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[5] gptid/cb25]
root 4492 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[6] gptid/cb25]
root 4493 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[7] gptid/cb25]
root 4496 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[0] gptid/ca75]
root 4497 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[1] gptid/ca75]
root 4498 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[2] gptid/ca75]
root 4499 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[3] gptid/ca75]
root 4500 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[4] gptid/ca75]
root 4501 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[5] gptid/ca75]
root 4502 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[6] gptid/ca75]
root 4503 0.0 0.0 0 16 - DL 9:23AM 0:00.01 [g_eli[7] gptid/ca75]
www 5406 0.0 0.0 34272 6696 - S 9:23AM 0:00.28 nginx: worker process (nginx)
root 5597 0.0 0.0 236404 16616 - Ss 9:23AM 0:00.03 /usr/local/sbin/nmbd --daemon --configfile=/usr/local/etc/smb4.conf
root 5601 0.0 0.0 294788 22544 - Is 9:23AM 0:00.01 /usr/local/sbin/smbd --daemon --configfile=/usr/local/etc/smb4.conf
root 5603 0.0 0.0 290628 22060 - I 9:23AM 0:00.00 /usr/local/sbin/smbd --daemon --configfile=/usr/local/etc/smb4.conf
root 5605 0.0 0.0 290620 22044 - I 9:23AM 0:00.00 /usr/local/sbin/smbd --daemon --configfile=/usr/local/etc/smb4.conf
root 5607 0.0 0.0 278764 20256 - Ss 9:23AM 0:00.03 /usr/local/sbin/winbindd --daemon --configfile=/usr/local/etc/smb4.conf
root 5608 0.0 0.0 285404 20876 - S 9:23AM 0:00.01 /usr/local/sbin/winbindd --daemon --configfile=/usr/local/etc/smb4.conf
nobody 5656 0.0 0.0 17036 2728 - Ss 9:23AM 0:00.03 /usr/local/sbin/mdnsd
root 5690 0.0 0.0 286240 20508 - S 9:23AM 0:00.01 /usr/local/sbin/winbindd --daemon --configfile=/usr/local/etc/smb4.conf
root 5720 0.0 0.0 104096 14828 - I 9:23AM 0:00.04 /usr/local/bin/python /usr/local/libexec/nas/register_mdns.py (python2.7)
root 14340 0.0 0.0 17064 3576 - IN 9:31AM 0:00.03 /bin/sh /usr/local/sbin/pbid
root 16729 0.0 0.0 85848 7340 - Ss 9:32AM 0:00.19 sshd: root@pts/0 (sshd)
root 17207 0.0 0.0 332764 25912 - I 9:38AM 0:00.28 /usr/local/sbin/smbd --daemon --configfile=/usr/local/etc/smb4.conf
root 17208 0.0 0.0 332764 24752 - I 9:38AM 0:00.09 /usr/local/sbin/smbd --daemon --configfile=/usr/local/etc/smb4.conf
root 18112 0.0 0.0 8228 1884 - IN 9:46AM 0:00.00 sleep 300
root 4165 0.0 0.1 185536 54040 v0 Is+ 9:22AM 0:00.41 python /etc/netcli (python2.7)
root 4166 0.0 0.0 14488 2052 v1 Is+ 9:22AM 0:00.00 /usr/libexec/getty Pc ttyv1
root 4167 0.0 0.0 14488 2052 v2 Is+ 9:22AM 0:00.00 /usr/libexec/getty Pc ttyv2
root 4168 0.0 0.0 14488 2052 v3 Is+ 9:22AM 0:00.00 /usr/libexec/getty Pc ttyv3
root 4169 0.0 0.0 14488 2052 v4 Is+ 9:22AM 0:00.00 /usr/libexec/getty Pc ttyv4
root 4170 0.0 0.0 14488 2052 v5 Is+ 9:22AM 0:00.00 /usr/libexec/getty Pc ttyv5
root 4171 0.0 0.0 14488 2052 v6 Is+ 9:22AM 0:00.00 /usr/libexec/getty Pc ttyv6
root 4172 0.0 0.0 14488 2052 v7 Is+ 9:22AM 0:00.00 /usr/libexec/getty Pc ttyv7
root 16731 0.0 0.0 27716 4000 0 Ss 9:32AM 0:00.15 -csh (csh)
root 19166 0.0 0.0 18740 2452 0 R+ 9:50AM 0:00.00 ps aux
My messages.log seems doesn't say anything about that (attached).
What can I do to find the problem and fix it? Can I have some help?
PS: my last operations was disabling the domain controller and NFS services, and reboot the server after that.
  • messages.txt
Zofoor
Some pictures.. hoping that could help to find the trouble
Zofoor
I have noticed one thing.
On the jails configuration page I have, as jail root
/mnt/work_volume/jails
while the correct setting would be
/mnt/main_volume/jails
That's very strange becouse I didn't change it.
If I change the jail root to
and click on save, I get this message
  • Jail dataset created on a share
but if I re-open the page I get again
as jail root.
So, the problem seems located at this setting, but I don't have any idea on how to fix that (and also, why that happened).
anyway, the data on main_volume/jails is all there:
[root@freenas] /mnt/main_volume/jails# ls
./ .warden-files-cache/
../ .warden-template-pluginjail/
.media_server.meta/ .warden-template-standard/
.mysql.meta/ media_server/
.nextcloud.meta/ mysql/
.plugins/ nextcloud/
.proxy_server.meta/ proxy_server/
.sickrage_1.meta/ sickrage_1/
.transmission.meta/ transmission/
NOTE: I have an encrypted dataset (main_volume) and a not encrypted storage (work_volume). When I reboot the system I have to enter the password on the storage page to open the encrypted mount.
Zofoor
I got some news. If I fix the locations in the file /etc/local/warden.conf then it works untill the next reboot. So, I'm happy that I my jails are working currently, but the issue has not been fixed, it's just a workaround.
To me it sounds like a bug of FreeNAS-9.10.2-U1.
Zofoor
I think that I have found how to fix that, I still have to reboot the server but on the web interface now the settings are fixed.
I have fixed in that way:
1. ssh to the freenas
2. copy /data/freenas-v1.db to a shared folder
3. opened the file with a sqllite client and changed. Inside that I have found a table with the jails settings, and the wrong path stored. I have fixed the path and wrote the changes to the db file
4. again in ssh shell, copy the fixed db file to /data/freenas-v1.db (better make a backup of the older one first)
5. chown www:www /data/freenas-v1.db
6. checked that on the web interface the settings are now correct
mstang1988
I'm also having this problem. Did you ever find a permanent solution? Mine does exactly the same thing and changes the directory of in which the jails are supposed to exist.
