MisterE2002
- Sep 5, 2015
I settled on this board. Now looking for memory. The Supermicro has no 3rd party memory on the list. So i started with the usual brands: crucial, samsung, hynix.
Samsung does not have ECC it seems, hynix had no decent filters on the webpage (and need to download a pdf to read the specs).
I am aiming for 64GB. Actual availibilty is shops is always a problem. I rather order by trusted (dutch) shops.
I get lost with the "speed" and the "rankings".
This is the PDF.
The spec page itself is stating: "Up to 128GB ECC UDIMM, DDR4-2666MHz"
Question 1: Does this mean i need 2666 memory banks if i want to upgrade to 128 in the future? Or will it downclock 3200 to 2666 speeds?
Question 2 : AFAIK it is better to run 2x32 (dual channel) instead of 4x16. So why is this table hinting towards 4 banks?
Question 3: Now opting for KSM26ED8/32ME. Seems amply present and seems Crucial/Micron chips anyway.
Will this work?
This is the PDF.
Will this work?
Supermicro X11SCL-F | Memory RAM & SSD Upgrades | Crucial.com
Crucial Memory and SSD upgrades - 100% Compatibility Guaranteed for Supermicro X11SCL-F - FREE US Delivery.
www.crucial.com
- MTA18ASF4G72AZ-3G2R - Micron 32GB DDR4-3200 ECC UDIMM 2Rx8 CL22 - 180 (unknown shops)
- MTA18ASF4G72AZ-3G2F1R - Micron 32GB DDR4-3200 ECC UDIMM 2Rx8 CL22 - 270 (unknown shops)
- MTA18ASF4G72AZ-2G6B1R - Micron 32GB DDR4-2666 ECC UDIMM 2Rx8 CL19 - 203 (azerty 10+ days)
- MTA18ASF4G72AZ-3G2B1R - Micron 32GB DDR4-3200 ECC UDIMM 2Rx8 CL22 - 193 euro (unknown shop)
- MTA9ASF2G72AZ-3G2R - Micron 16GB DDR4-3200 ECC UDIMM 1Rx8 CL22 - 130 (unknown shops)
- MTA18ASF2G72AZ-3G2R1R - Micron 16GB DDR4-3200 ECC UDIMM 2Rx8 CL22
- MTA9ASF2G72AZ-3G2B1R - Micron 16GB DDR4-3200 ECC UDIMM 1Rx8 CL22 - 111 (unknown shops)
- MTA9ASF2G72AZ-3G2F1R - Micron 16GB DDR4-3200 ECC UDIMM 1Rx8 CL22 - 92 euro
- MTA18ASF2G72AZ-2G6E2R - Micron 16GB DDR4-2666 ECC UDIMM 2Rx8 CL19
Memory for a Supermicro - X11SCL-F Motherboard- Kingston Technology
Kingston has compatible memory for Supermicro - X11SCL-F Motherboard
www.kingston.com
- KSM26ED8/32HC - 32GB DDR4 2666MT/s ECC Unbuffered DIMM (DDR4 2666MT/s ECC Unbuffered DIMM CL19 2RX8 1.2V 288-pin 16Gbit Hynix C) - 170 Euro
- KSM26ED8/32ME - 32GB DDR4 2666MT/s ECC Unbuffered DIMM (DDR4 2666MT/s ECC Unbuffered DIMM CL19 2RX8 1.2V 288-pin 16Gbit Micron E) - 170 Euro
- KSM26ED8/16HD - 16GB DDR4 2666MT/s ECC Unbuffered DIMM (DR4 2666MT/s ECC Unbuffered DIMM CL19 2RX8 1.2V 288-pin 8Gbit Hynix D) - 92 euro
- KSM26ED8/16MR - 16GB DDR4 2666MT/s ECC Unbuffered DIMM (DDR4 2666MT/s ECC Unbuffered DIMM CL19 2RX8 1.2V 288-pin 8Gbit Micron R) - unknown shops
- KSM26ES8/16HC - 16GB DDR4 2666MT/s ECC Unbuffered DIMM (DDR4 2666MT/s ECC Unbuffered DIMM CL19 1RX8 1.2V 288-pin 16Gbit Hynix C) - unknown shops
- KSM26ES8/16MF - 16GB DDR4 2666MT/s ECC Unbuffered DIMM (DDR4 2666MT/s ECC Unbuffered DIMM CL19 1RX8 1.2V 288-pin 16Gbit Micron F) - 92 euro
