Unencrypted nested ix-applications dataset warning & replication error
I am receiving the following notifications in my TrueNAS Scale (Bluefin) instance. I know why this is occurring. At install time (on Angelfish,) I wanted there to be no unencrypted root dataset, including ix-systems. Angelfish sort of let me do this, and at first seemed to operate correctly (even though I am now aware it never actually did.) And Bluefin is now notifying me about this.
The forum posts I've read on this to date are full of debate, but I haven't yet found an actual solution. I am not interested in any of the reasoning as to why or how things are implemented this way. Rather, can someone please help me with a solution to correct this issue in my existing Scale instance? Any help is greatly appreciated!
The dataset structure is:
apps (encrypted)
- ix-applications (unencrypted)
- app1-dataset (encrypted)
- app2-dataset (encrypted)
Notification 1:
The following datasets are not encrypted but are within an encrypted dataset: 'apps/ix-applications' which is not supported behaviour and may lead to various issues.
Notification 2:
Replication "apps/ix-applications,tank - tank/snapshots" failed: cannot receive incremental stream: inherited key must be loaded.
The "solution" is to ignore the warning. (Not sure if you can permanently dismiss the alert?)
Notification 2:
But isn't it loaded?
zfs get keystatus apps
EDIT: Which direction is this replication task? Are you receiving from a remote server to be replicated to your local ix-applications dataset?
