SOLVED The web interface could not be accessed at TueNAS Core (FreeBSD 13.1 | Dell PowerEdge CS24-NV7)
basnek
Dell PowerEdge CS24-NV7 Twin Quad Core Rack Server AMD 2.1GHz
Processor (CPU) - 2 x AMD Opteron Quad Core 2.10 Ghz (2373)
32 GB RAM
2 HD x 4TB
AMD-v (Virtualization)
2MB Cache 64-Bit Memory (RAM)
PC2-5300P ECC Chipset
nVIDIA® nForce Professional 3600 MCP Hard Disk Controller
On Board SATA Controller Hard Disk Configuration - 4 x 3.5" hot swap SATA drive Bays
Hello everyone!
Previously on this computer I had FreeNAS 11.x and everything worked but it became obsolete.
I have decided to start from 0 and it occurred to me to install TrueNAS (FreeBSD 13.1-RELEASE-p7 n245428-4dfb91682c1 TRUENAS), the installation was OK until the reboot where I discovered that I do not have access to the web interface.
I have tried changing the interface cable (since it has two) but nothing in any of the cases.
I leave you a little information
root@truenas [~]# ifconfig
lo0: flags=8049<UP,LOOPBACK, RUNNING, MULTICAST> metric 0 mtu 16384
options=680003<RXCSUM, TXCSUM, LINKSTATE, RXCSUM_IPV6, TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
nd6 options=21<PERFORMNUD, AUTO_LINKLOCAL>
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
root@truenas [~]# |
Any suggestions? I
From already thank you very much.
I hope you can help me
PS:I leave you some screenshots made
Arwen
If I remember that chipset, it supplies an Ethernet port through the nVIDIA chipset. That chipset is pretty old. Like 15 years old. It appears that TrueNAS Core does not have the drivers for that chipset any more.
You may want to try TrueNAS Core 12.x and see if the network interface shows up.
basnek
@Arwen First of all, thank you very much for your prompt response. It is true that it is a very good hard and made precisely because I ran out of possibilities to continue updating the Jails packages with pkg, I decided to do this "update" but what you are telling me would actually be like a temporary patch. In a short time I suppose TrueNAS Core 12.x will die? or I am I wrong to think in my head of FreeNAS 12? I would appreciate it if you could tell me how to download that package you told me about. Thank you so much and sorry for my poor english.
basnek
@Arwen I just did the install but unfortunately with the same result .....
Arwen
Then, if you want to stay current, their are 2 options, buy a supported Ethernet card. Or perhaps try TrueNAS SCALE.
However, the second option seems like it would not work for you. SCALE is based on Linux, which does not support Jails. SCALE does have Apps and VMs which might work for you. Though the development is on-going which at times reduces stability.
On the first, Intel Gigabit cards are highly recommended and are pretty cheap, at least in the U.S.
basnek
@Arwen I finally got a much newer SuperMicro so when I installed it to test everything went smoothly. Thank you so much
Arwen
Glad you have something working.
