Spotlight with elasticsearch backend on SMB shares
ak111pro
Hey guys, maybe you can help me out.
I'm really not sure if I getting this right. I'm trying to get an SMB share with proper spotlight working accessing form macos clients, according to here you can use elasticserach as backend: https://wiki.samba.org/index.php/Spotlight_with_Elasticsearch_Backend
So I was trying to set this up in a jail, following this guide:
Getting through all of this I'm not sure what to do now?
In theory I should add a mountpoint to the jail, then build an index with elasticserach and access the smb share through a macos client...
How do I access an SMB share through a jail?
How do I connect elasticserach to spotlight?
anodos
Sambassador
12.0-BETA2 is compiled with spotlight support / elasticsearch. You just need to configure through auxiliary parameters. Do note that we started compiling with this to give users options in the main install. Spotlight isn't a "supported" feature in the sense that we take steps to QE / fix it.
ak111pro
cool, I'll try this out.
are those the right aux params to set this up, or where can I look up the right ones?
[global]
spotlight backend = elasticsearch
elasticsearch:address = localhost
elasticsearch:port = 9200
[share]
spotlight = yes
anodos
Sambassador
[global]
[share]
spotlight = yes
They are documented in the smb.conf manpage. Do note that 12.0-BETA2 (and pre-release versions in general) should not be used in production environments.
ak111pro
You'll need to look up in the manpage of the samba version installed in TrueNAS. `man smb.conf`
thanks, is the man file only in TrueNAS?
one other thing, when i do the command
afp -version
I get
netatalk has been compiled with support for these features:
      Zeroconf support: No
     Spotlight support: No
Do you know how can I enable spotlight?
anodos
Sambassador
afp -version
I get
11.3 It's not possible. 12.0 it's, in principle, possible for TrueNAS for an intrepid BETA tester
tmueko
I did some testing on this: looks promising:
I started a jail with NAT and forwarded 5601 for kibana.
I mountet my dataset to /mnt/my_dataset.
Then I installed elasticsearch and so on:
pkg install -y elasticsearch7 kibana7 openjdk15 tesseract-data tesseract curl
sysrc elasticsearch_enable="YES"
sysrc kibana_enable="YES"
I edited /usr/local/etc/kibana/kibana.yml to contain:
server.host: "0.0.0.0"
and /usr/local/etc/elasticsearch/elasticsearch.yml for
network.host: 0.0.0.0
discovery.seed_hosts: ["127.0.0.1", "[::1]"]
cd /usr/local/
fetch  https://oss.sonatype.org/content/repositories/snapshots/fr/pilato/elasticsearch/crawler/fscrawler-es7/2.7-SNAPSHOT/fscrawler-es7-2.7-20210407.064623-168.zip
unzip fscrawler-es7-2.7-20210407.064623-168.zip
ln -s fscrawler-es7-2.7-SNAPSHOT fscrawler
cd fscrawler
setenv JAVA_HOME /usr/local/openjdk15
./bin/fscrawler my_dataset
Then edit ~/.fscrawler/my_dataset/_settings.yaml to your needs (at least the path)
Edit SMB in Services and Shares:
[global]
elasticsearch:address = 172.16.0.2
[my_dataset]
spotlight = yes
Then run fscrawler:
/usr/sbin/daemon -t fscrawler-creativteam -P /var/run/daemon-fscrawler-creativteam.pid -p /var/run/fscrawler-creativteam.pid -S -R 60 /usr/local/fscrawler/bin/fscrawler creativteam
now I'm waiting for the crawler for first run.
dak180
kapitainsky
there is no spotlight support in smbd in truenas
TrueNAS-13.0-U2:
root@truenas[~]# smbd -b | grep SPOT
   HAVE_SPOTLIGHT_BACKEND_ES
   WITH_SPOTLIGHT
It is also enabled in TrueNAS SCALE 22.02.4 and TrueNAS SCALE 22.12-BETA2
