SMB hangs with NT_STATUS_IO_TIMEOUT after upgrading to 13.0-U6.1
JMY1000
Hi all, we recently upgraded from 13.0-U3.1 to 13.0-U6.1; after this upgrade, our SMB seems very broken. The service does seem to run:
root@server[~]# service smbd status
smbd is running as pid 2622.
root@server[~]# smbstatus
Samba version 4.15.13
PID     Username     Group        Machine                                   Protocol Version  Encryption           Signing
Service      pid     Machine       Connected at                     Encryption Signing
No locked files
But attempting to connect over SMB results in the connection simply timing out, with no further information.
root@server[~]# smbclient -L //<server_ip> -U jmy1000 -d 3
lp_load_ex: refreshing parameters
Initialising global parameters
Processing section "[global]"
added interface ix1 ip=<server_ip> bcast=<xx.xx.xx>.255 netmask=255.255.254.0
Client started (version 4.15.13).
Connecting to <server_ip> at port 445
protocol negotiation failed: NT_STATUS_IO_TIMEOUT
root@server[~]# midclt call smb.status AUTH_LOG | jq
I don't see anything suspicious in /var/log/messages, or in /var/log/samba4:
root@server[~]# cat /var/log/samba4/log.smbd
[2024/01/03 00:22:42.682625,  0] ../../source3/smbd/server.c:1734(main)
  smbd version 4.15.13 started.
  Copyright Andrew Tridgell and the Samba Team 1992-2021
[2024/01/03 00:22:42.693011,  1] ../../source3/profile/profile.c:55(set_profile_level)
  INFO: Profiling turned OFF from pid 3623
[2024/01/03 00:22:43.087634,  1] ../../source3/smbd/files.c:811(file_init_global)
  file_init_global: Information only: requested 3771576 open files, 59392 are available.
[2024/01/03 00:47:21.143465,  0] ../../source3/smbd/server.c:1734(main)
[2024/01/03 00:47:21.153232,  1] ../../source3/profile/profile.c:55(set_profile_level)
  INFO: Profiling turned OFF from pid 4319
[2024/01/03 00:47:21.505445,  1] ../../source3/smbd/files.c:811(file_init_global)
[2024/01/03 00:52:00.467408,  0] ../../source3/smbd/server.c:1734(main)
[2024/01/03 00:52:00.477144,  1] ../../source3/profile/profile.c:55(set_profile_level)
  INFO: Profiling turned OFF from pid 4578
[2024/01/03 00:52:00.833740,  1] ../../source3/smbd/files.c:811(file_init_global)
[2024/01/03 01:06:44.478847,  0] ../../source3/smbd/server.c:1734(main)
[2024/01/03 01:06:44.489788,  1] ../../source3/profile/profile.c:55(set_profile_level)
  INFO: Profiling turned OFF from pid 5013
[2024/01/03 01:06:44.858269,  1] ../../source3/smbd/files.c:811(file_init_global)
[2024/01/03 01:15:14.288915,  0] ../../source3/smbd/server.c:1734(main)
[2024/01/03 01:15:14.298831,  1] ../../source3/profile/profile.c:55(set_profile_level)
  INFO: Profiling turned OFF from pid 5401
[2024/01/03 01:15:14.654848,  1] ../../source3/smbd/files.c:811(file_init_global)
[2024/01/03 01:25:03.094936,  0] ../../source3/smbd/server.c:1734(main)
[2024/01/03 01:25:03.141834,  1] ../../source3/profile/profile.c:55(set_profile_level)
  INFO: Profiling turned OFF from pid 2620
[2024/01/03 01:25:03.561780,  1] ../../source3/smbd/files.c:811(file_init_global)
[2024/01/03 01:25:03.667215,  0] ../../source3/smbd/server.c:1734(main)
[2024/01/03 01:25:03.675469,  1] ../../source3/profile/profile.c:55(set_profile_level)
  INFO: Profiling turned OFF from pid 2640
Any idea what's going on?
Edit: Since I was a dumb-dumb and posted this to the archives instead of the main forums I can't reply.
Unfortunately using 127.0.0.1 didn't work, it also times out. Here's the output, along with the output of testparm -s:
root@server[~]# smbclient -L //127.0.0.1 -U jmy1000 -d 3
Connecting to 127.0.0.1 at port 445
root@server[~]# testparm -s
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
# Global parameters
[global]
        aio max threads = 2
        bind interfaces only = Yes
        disable spoolss = Yes
        dns proxy = No
        enable web service discovery = Yes
        kernel change notify = No
        load printers = No
        logging = file
        map to guest = Bad User
        max log size = 5120
        registry shares = Yes
        server multi channel support = No
        server role = standalone server
        unix extensions = No
        fruit:nfs_aces = No
        rpc_server:mdssvc = disabled
        rpc_daemon:mdssd = disabled
        idmap config * : backend = tdb
        directory name cache size = 0
        dos filemode = Yes
[cookie]
        comment = Main server share
        ea support = No
        kernel share modes = No
        path = /mnt/server/club
        posix locking = No
        read only = No
        smbd max xattr size = 2097152
        vfs objects = fruit streams_xattr shadow_copy_zfs ixnas zfs_core aio_fbsd
        fruit:resource = stream
        fruit:metadata = stream
        nfs4:chown = true
        ixnas:dosattrib_xattr = false
[vm-alpine]
        ea support = No
        path = /mnt/server/Virtual Machines
        posix locking = No
        read only = No
        nfs4:chown = true
[signup]
        browseable = No
        comment = Holds Utility for Account Registration
        ea support = No
        guest ok = Yes
        mangled names = no
        path = /mnt/server/clubsignup
        read only = No
        vfs objects = audit catia fruit streams_xattr ixnas
        fruit:encoding = native
        nfs4:chown = true
Top Bottom
