- Aug 16, 2011
The more additional subforums are created, the less sense it's making to me. Back in the old days (i.e., before rebranding everything to "TrueNAS"), there was a pretty well-defined set of subforums for FreeNAS, with divisions that pretty well made sense. Although there were tweaks to it, the same basic structure was deemed adequate for releases 8.x through 11.x, and changes from one release to the next were incremental enough that there wasn't really any perceived need to create different forums for each release.
Then iX decided that everything had to be called TrueNAS, and with that came a new set of forums. Rather than rename the existing forums (which would, IMO, have made more sense, since it was 99% the same product), we got a new forum division for "TrueNAS", a forum within that for "General Help", with its own set of subforums that weren't similar at all to the ones that had worked well for FreeNAS. We have a separate top-level forum for "Applications and Plugins" (which might include jails and VMs, or it might not--and may or may not include SCALE applications). We have a separate forum for SCALE, which makes sense, as it's a different product with (inexplicably) a mostly-different UI (which incorporates a number of feature requests people have logged against CORE which weren't included in CORE, but that's a different thread). And now we have a separate forum for TrueNAS 13, with no subforums.
The result is that threads are posted all over the place, without apparent consideration of which version of Free/TrueNAS they apply to. And to what end? We didn't need a new set of forums for 9 when it was released, nor for 9.10 (which should have been 10 but for the dumpster fire that wasCorralThe Release That Must Not Be Named), nor for 11 (despite the change of 11.1 to including a completely new UI, to 11.2 making that new UI the default, to 11.3 removing the legacy UI). But for 12, despite using substantially the same UI, now we need a new set of forums. And for 13, which again uses substantially the same UI, we have a new single forum?
