plex not detecting nvidia GPU
dean.viens
hello all, i dont know what is going on but all of a sudden after an upgrade to plex my gpu is no longer listed in the menu.
here are commands for information:
admin@truenas[~]$ nvidia-smi
Fri Jan 5 16:12:19 2024
| NVIDIA-SMI 535.54.03 Driver Version: 535.54.03 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 1660 ... Off | 00000000:01:00.0 Off | N/A |
| 29% 34C P0 1W / 125W | 0MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
admin@truenas[~]$
admin@truenas[~]$ lspci
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 0d)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 0d)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:17.0 RAID bus controller: Intel Corporation SATA Controller [RAID mode] (rev 10)
00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #21 (rev f0)
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #5 (rev f0)
00:1c.5 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #6 (rev f0)
00:1c.7 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #8 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device a308 (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation TU116 [GeForce GTX 1660 SUPER] (rev a1)
01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
01:00.2 USB controller: NVIDIA Corporation TU116 USB 3.1 Host Controller (rev a1)
01:00.3 Serial bus controller: NVIDIA Corporation TU116 USB Type-C UCSI Controller (rev a1)
02:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 500f (rev 03)
03:00.0 SATA controller: ASMedia Technology Inc. ASM1166 Serial ATA Controller (rev 02)
04:00.0 SATA controller: ASMedia Technology Inc. ASM1166 Serial ATA Controller (rev 02)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
06:00.0 Non-Volatile memory controller: Micron/Crucial Technology P1 NVMe PCIe SSD (rev 03)
admin@truenas[~]$
OS Version:TrueNAS-SCALE-23.10.1
Product:System Product Name
Model:Intel(R) Core(TM) i5-9400 CPU @ 2.90GHz
not sure how to fix it but it just says 0 nvidia gpu to allocate in the menu for plex
all using bluecharts
nikkon
I have the same situation with a p2000. have you managed to fix the issue?
dean.viens
yes, all you need to do is remove gpu suppoirt from kubernites settings and then put it back and it recognizes it again.
nikkon
you mean these ones? under plex config?
dean.viens
no in the advanced settings of the apps in general.
nikkon
got it. thanks
nikkon
not yet done. I think I'm missing something:
the driver seems ok. the gpu is on.
I enabled and disabled the GPU support in k8s
the problem is I can't see it in plex. all GPU entries are 0. I start the app and force a transcode, then my CPU goes to the roof => the GPU is not used!
there is a setting I miss. But I can't find which.
nikkon
I did. It required a restart to actually use it. not it works, with the setting you suggested and restart it works
nikkon
Yes. No.issues
nikkon
I just did a new check. restarted and checked - it seems to work nice
nikkon
what version are you?
