PID fan controller Perl script
Gaspetaahl
They are Arctic P12 PWM 120mm (4Pins) I had 3 Pin Fans before but the X10 cant control 3Pin fans
Gaspetaahl
I wondered why the ipmitool commands failed so I edited the script to print each command. This is my output. maybe that helps:
]# ./PID_fan_control.pl
/usr/local/bin/ipmitool raw 0x30 0x45 0x01 1
/usr/local/bin/ipmitool raw 0x30 0x70 0x66 0x01 1 30
/usr/local/bin/ipmitool raw 0x30 0x70 0x66 0x01 0 20
/usr/local/bin/ipmitool raw 0x30 0x70 0x66 0x01 0 16
Unable to send RAW command (channel=0x0 netfn=0x30 lun=0x0 cmd=0x70 rsp=0xcc): Invalid data field in request
No data available
Get Device ID command failed
No data available
Get Device ID command failed: 0xc1 Invalid command
Unable to open SDR for reading
No data available
^C
Caught SIGINT: setting fan mode to optimal
/usr/local/bin/ipmitool raw 0x30 0x45 0x01 2
No data available
Unable to send RAW command (channel=0x0 netfn=0x30 lun=0x0 cmd=0x45 rsp=0xc1): Invalid command
I am confused about the numbers not being in hex. Maybe I did the printing wrong. I never coded in perl.
This is my script:
Edit:
I also saw this when running ipmitool commands after triggering a bmc reset which are the same errors:
ipmitool bmc reset cold
Sent cold reset command to MC
[root@freenas ~/nas_fan_control]# ipmitool raw 0x30 0x45 0x01 0x01
No data available
Edit2:
I updated my BMC and BIOS and I think it might have fixed some errors. This is the new stdout. The "Unable to send RAW command" errors do not appear anymore
/usr/local/bin/ipmitool raw 0x30 0x70 0x66 0x01 0 37
No data available
No data available
No data available
No data available
/usr/local/bin/ipmitool raw 0x30 0x70 0x66 0x01 1 60
/usr/local/bin/ipmitool raw 0x30 0x70 0x66 0x01 1 100
^C
This happens when I execute the ipmitool commands without the script after a reset:
# ipmitool bmc reset cold
root@freenas:~/nas_fan_control # ipmitool raw 0x30 0x45 0x01 0x01
No data available
No data available
No data available
No valid response received
 20 01 03 88 02 bf 7c 2a 00 01 08 00 00 00 00
  • PID_fan_control.txt
Edit2:
No data available
No data available
No data available
No data available
^C
It seems strange that ipmitool raw 0x30 0x45 0x01 1 appears to work sometimes, and sometimes it triggers an error. I'm baffled. Maybe there is still some bug in your current version of the BMC. Or maybe the BMC is randomly rebooting for an unknown reason - perhaps a bad BMC, or a flakey power supply, or loose connection somewhere in the system. Is the power supply wattage guaranteed to be adequate for your system?
No data available
No data available
No data available
It takes the BMC many seconds to reboot after a cold reset, so it is expected that there would be no valid response for some period of time.
Gaspetaahl
Its a 630W PSU for a Xeon e3-1231 v3 and 5 HDDs I think it should be adequate.
Also I noticed that the bmc intervenes when I try to manually set the fan speed. Before using the script I used the commands as described here:
which set the fans to a constant speed when using "Full" Fan mode. But now the bmc sometimes ramps up the fans only to set them to low speed afterwards. I sound quite annoying. This also happened before the BMC update.
Here is my current theory, which I think matches the available evidence since you updated the BMC.
Looking at the Debug Log, I see frequent occurrences where the monitored HD Fan (fan header FAN1) fails to report a speed. If this condition persists, the script assumes that the BMC has locked up (I saw occasional BMC lockups during my testing) and it resets the BMC. The BMC fan mode is set to Full, so the HD fans go to full speed after the BMC resets, then the script will command a lower duty cycle once that part of the control loop runs (the HD temperatures are only checked every 90 seconds, so the fans could be at max speed for up to 90s before the script commands a lower duty cycle).
So, the question is why FAN1 frequently fails to report a speed. Maybe FAN1 or its cable, or the connection to the motherboard is flakey. I'd disconnect and reconnect FAN1 from the motherboard. If the problem persists, try changing $hd_fan_header to "FAN2", or "FAN3", or "FAN4".
Another possibility is that the BIOS is interfering somehow. Comparing the manual for your X10SLL board against the manual for my X10SRH board, I see that the BIOS for your board has an Energy Performance setting, which selects different fan modes. I don't see reference to that on my board. It might be worth checking that setting in the BIOS - looking at the various options, I think "Performance" is likely the one you want.
Stux
You do need to set the fan critical thresholds on the BMC to prevent it restting or taking over when fans fall below the thresholds.
Also, I do remember some RAW command flakiness from other people with older BIOSes in the past.
Here's an example of me doing it with another build of mine: Fan Control Thresholds for Node 304/X10-SDV
You do need to set the fan critical thresholds on the BMC to prevent it resetting or taking over when fans fall below the thresholds.
Excellent point - incorrect fan speed thresholds would explain the current behavior. See this thread for details on how to set the fan speed thresholds.
What is the make and model of your CPU fan?
What is the output of ipmitool sensor | grep FAN
nick23369
Hi Kevin,
First of all I really thank you for the great script, it works like a charm. I have tested the script on my new board a Supermicro H11SSL-i with a Epyc 7551P with out any major changes and it does what I expect. I started using Truenas in January 2021 and I'm still learning, therefore please excuse any question that might sound silly. My real question is: what is the best way to let the script running in the background. At the moment I can only let it run in a console but as soon as I exit the console the script exits (as it is clearly visible in your script). I also have tried to run it like this:
 PID_fan_control.pl &
but as well as soon as I quit the console the script quit. I have as well tried to set up a service, but as well without success: as soon as I launch the service I never get back the prompt and when I leave the console the job quit. I guess I might be missing something in the script. Here there is the rc script that I have added in
 /etc/rc.d/pid-fan-control
#!/bin/sh
# PROVIDE: pid-fan-control
# REQUIRE: DAEMON
# pidfancontrol_enable="YES"
# ... to /etc/rc.conf
. /etc/rc.subr
name=pidfancontrol
rcvar=pidfancontrol_enable
command="/usr/sbin/PID_fan_control.pl";
pidfile="/var/run/${name}.pid"
load_rc_config $name
run_rc_command "$1"
I also thought that I could add the script as a post init in TrueNAS, but if I would need to change any parameter I guess I would need to restart TrueNAS (which I don't really want), unless I mange to get the service working properly or any other way to get have the script working in the background.
I tried to look into the discussion but I couldn't find the answer I was looking for.
Any help is really appreciated.
I run the script automatically as a Init/Shutdown script of type POSTINIT. I have selected the option to use a config file for the parametres (see Github to get the later versions of the script that have the config file option). The script reads the config file each time around the loop, and picks up the new values if there have been changes.
Another option is to use tmux or screen to run the script, but this adds the risk that the script would not be running if the server had an uncommanded reboot.
nick23369
Hi Kevin,
thanks a lot for the super quick answer, I'll follow your suggestion of the POSTINIT, I didn't realize that the script reads the config file more than once. I'll come back if I need further help.
Thanks again!
I would recommend running your postinit script like this:
tmux new-session -d -s fanscript '/mnt/pool/path/script.pl'
This way, you can stop and restart your script whenever you want to make changes outside of the "live" config by attaching to the tmux session like this:
tmux attach -t fanscript
CTRL + C to stop the script... make your adjustments... then start it again from that same tmux session /mnt/pool/path/script.pl
Then CTRL + B followed by D to detach again
nick23369
Hi sretalla, thanks for this tip. Currently I'm running the script with tmux as you suggested as a normal process, not yet in the postinit. I didn't want to restart TrueNAS for that, but so far everyting is working as I want. Thanks all for your help!
Stux
What sretalla said.
Also, when the middleware crashes and reboots it won’t take your init script down with it.
gdarends
Can anyone explain the PID control config?
Or maybe somewhere I can read to understand it?
I don't know what values to use.
I am using TrueNAS Scale with 6 HD's
gdarends
I have left the PID config to default for now.
Does this script work with fans with different speeds?
2 x Noctua NF-A12x25 PWM connected to FANA header with max speed of 2000 RPM
1 x Noctua NF-A14 PWM connected to FANB header with max speed of 1500 RPM
I have disabled CPU fan control in the config.
So I'm only doing Zone 1 for HD fan control.
What should I put at $hd_max_fan_speed and $hd_fan_header?
EDIT: This script doesn't work on SCALE it seems. camcontrol isn't available on SCALE / Linux
I'm in the midst of a big road trip, driving all day today and most of tomorrow. Hence the delayed reply.
The required value for $hd_max_fan_speed depends on your fans. Setting a value a bit higher than the max fan speed provided by the manufacturer is a good start, but sometimes the actual fans don't exactly meet the specs, so you may need to increase this setting even a bit more to avoid false detection of runaway fans.
For $hd_fan_header, look at the output of ipmitool sdr and determine which header one of your HD fans is connected to.
I don't have access to SCALE, so I cannot determine what changes could be made to the script to replace camcontrol with whatever equivalent utilities are available on Linux. But there must be something that could do the same functions as camcontrol
gdarends
I have 2 different fans that have different max RPM. That's why I wasn't sure if it would work.
Same here. I have 2 different fans. Not sure how it would work if they are different.
Yeah, I tried searching for camcontrol equivalent in Linux, didn't get any hits.
Pick one fan, and use the max rpm and header for that fan.
yonkoc
Here's how to get the PID fan controller Perl script on TrueNAS SCALE. I started with this script and had it running for years on freeNAS then TrueNAS Core. I originally had it for SATA drives, then moved to SAS and had to customize it for the output of those so I can start tracking the SAS temps. Moving to SCALE was... interesting as all stopped working. Hello there, Linux. :wink: I had to further customize mine to fit my setup as I discovered camcontrol is gone and so is sysctl. Joy. But, in the end, it turned out quite okay and the changes were minimal. I keep my folder with the fan controller in /root/nas_fan_control-master and start it in SCALE with the command (in GUI it is command not script): bash /root/start_fan_controller, which a single-liner to start the pl file and log it.
#!/bin/bash
echo "Starting Fan Controller..."
/root/nas_fan_control-master/PID_fan_control.pl &>> /root/nas_fan_control-master/PID_fan_control.log &
The only changes required when moving from FreeBSD to Linux were:
1. perl, ipmitool locations:
from
$ipmitool = "/usr/local/bin/ipmitool";
to
$ipmitool = "/usr/bin/ipmitool";
Look through your script's files for /usr/local/bin and remove the /local so it becomes /usr/bin/whatever
2. With camcontrol gone I switched to lsblk:
from
$disk_list = `camcontrol devlist | grep -v "SSD" | grep -v "Verbatim" | grep -v "Kingston" | grep -v "Elements" | sed 's:.*(::;s:).*::;s:,pass[0-9]*::;s:pass[0-9]*,::' | egrep '^[a]*da[0-9]+\$' | tr '\012' ' '`;
to
$disk_list = `lsblk -d -n -o model,name | grep -v "SSD" | grep -v "Verbatim" | grep -v "Kingston" | grep -v "Elements" | sed 's:YOURDRIVEMODEL  .::;' | tr '\012' ' '`;
All I did was ssh into my SCALE, then ran lsblk -d -n -o model,name, that pulled up drive model and identifier. Then I started grepping what I did not need (the SSD) and then I amended the sed part to remove my model till all I had left was the name of the drives, in my cases those were sda through sdk (sdl was the ssd so it was grep -v for it).
3. Another example of a small tweak (grep and vals of note here). Sorry, did not bother to change the comments:
from
    foreach my $item (@hd_list)
        my $disk_dev = "/dev/$item";
        my $command = "/usr/local/sbin/smartctl -A $disk_dev | grep Temperature_Celsius";
        my $output = `$command`;
        my @vals = split(" ", $output);
        # grab 10th item from the output, which is the hard drive temperature (on Seagate NAS HDs)
        my $temp = "$vals[9]";
        chomp $temp;
to
        my $command = `/usr/sbin/smartctl -A $disk_dev | grep "Current Drive Temperature"`;
        my $output = $command;
        my $temp = "$vals[3]";
        chomp $temp;
3. With sysctl gone I switched to sensors for cpu temp reading since it came preinstalled on SCALE:
from
    my $core_temps = `sysctl -a dev.cpu | egrep -E \"dev.cpu\.[0-9]+\.temperature\" | awk '{print \$2}' | sed 's/.\$//'`;
to
    my $core_temps = `sensors | egrep -E \"Core [0-9]+\" | awk '{print \$3}' | tr -d '+' | sed 's/.0°C//'`;
    chomp($core_temps);
Of course it will greatly depend on your disk types and cpus you use: Intel/AMD, SATA vs SAS etc. I cannot stress this enough: use the awesome debug! Get it to 4 and a lot will become obvious. It's a lot of:
1. ps aux | grep -i PID_fan_control
2. kill -9 thePIDfromAbove
3. Upload via filezilla the new .pl file
4. Delete the old log files (otherwise the incorrectly logged values for disks you do NOT need will still show up in your .log and mess up your view - will make your values out of order/misplaced/skewed).
5. Start the script.
6. Wait for initial spin up and for all to quiet down (about 30s-45s)
7. Pull logs (debug and normal), inspect, make .pl corrections. Rinse and repeat.
Here's the output from my working setup after the changes I made. As you can tell from the timestamps... I just got it working:tongue::
PID Fan Controller Log  ---  Target 6 Disk HD Temperature = 39.00 deg C  ---  PID Control Gains: Kp =  5.333, Ki =  0.000, Kd =  48.0
        Max   Ave  Temp   Fan   Fan  Fan %   CPU    P      I      D      Fan
2023-01-14 sda  sdb  sdc  sdd  sde  sdf  sdg  sdh  sdi  sdj  sdk Temp  Temp   Err  Mode   RPM Old/New Temp  Corr   Corr   Corr    Duty
19:11:12   36   36   36   36   37   38   37   38   36   39   38  ^39  37.83 -1.17  Full  2800  30/21   41  -9.33  -0.00    0.00   20.67%
19:12:43   36   36   34   36   37   38   37   38   34   39   38  ^39  37.83 -1.17  Full  2300  21/11   40  -9.33  -0.00    0.00   11.33%
19:14:13   36   36   36   36   37   38   37   38   36   39   38  ^39  37.83 -1.17  Full  2200  11/10   41  -9.33  -0.00    0.00   10.00%
19:15:42   36   37   36   36   37   38   38   38   36   39   39  ^39  38.17 -0.83  Full  2400  10/14   40  -6.67  -0.00   10.67   14.00%
19:17:13   36   37   36   37   37   38   38   38   36   39   38  ^39  38.00 -1.00  Full  2200  14/10   42  -8.00  -0.00   -5.33   10.00%
19:18:42   36   37   36   37   37   38   38   38   36   39   39  ^39  38.17 -0.83  Full  2200  10/10   40  -6.67  -0.00    5.33   10.00%
19:20:13   36   37   36   37   37   38   38   38   36   39   39  ^39  38.17 -0.83  Full  2200  10/10   41  -6.67  -0.00    0.00   10.00%
19:21:43   36   37   36   37   37   39   38   39   36   39   39  ^39  38.50 -0.50  Full  2500  10/17   41  -4.00  -0.00   10.67   16.67%
19:23:13   36   37   36   37   37   39   38   38   36   39   39  ^39  38.33 -0.67  Full  2200  17/10   41  -5.33  -0.00   -5.33   10.00%
19:24:43   36   37   36   37   37   39   38   39   36   39   39  ^39  38.50 -0.50  Full  2200  10/11   43  -4.00  -0.00    5.33   11.33%
19:26:12   36   37   36   37   37   39   38   39   36   39   39  ^39  38.50 -0.50  Full  2200  11/10   41  -4.00  -0.00    0.00   10.00%
19:27:43   37   37   37   37   37   39   38   39   36   39   39  ^39  38.50 -0.50  Full  2200  10/10   42  -4.00  -0.00    0.00   10.00%
19:29:12   37   37   36   37   38   39   38   39   37   39   39  ^39  38.67 -0.33  Full  2300  10/13   41  -2.67   0.00    5.33   12.67%
19:30:43   37   38   37   37   38   39   38   39   37   39   39  ^39  38.67 -0.33  Full  2200  13/10   41  -2.67  -0.00    0.00   10.00%
19:32:13   37   38   37   37   38   39   38   39   37   39   39  ^39  38.67 -0.33  Full  2200  10/10   42  -2.67  -0.00    0.00   10.00%
19:33:42   37   38   37   37   38   39   38   39   37   39   39  ^39  38.67 -0.33  Full  2200  10/10   42  -2.67  -0.00    0.00   10.00%
19:36:09   37   38   37   38   38   39   38   39   37   39   39  ^39  38.67 -0.33  Full  3100  30/27   42  -2.67  -0.00    0.00   27.33%
Hope this helps someone. My respect to the creator(s) of the script for their amazing work.
