I recently upgraded my system from 11.1 to 11.2 and I decided to re-create all of my jails using iocage instead of the warden system. I've successfully gotten everything working on my local network, but I'm having trouble getting it to work outside of my network through my domain name. I'm trying to set up each service as a subdomain using the reverse proxy functions of Nginx. I also want to make sure all of my subdomains can load using HTTPS, which I have working through Let's Encrypt. I am able to successfully load the HTML from each of the services using the reverse proxy, but none of the subdomain services are able to load any static files (css, js, etc.).
Below is a screenshot of what I can see when I visit Nextcloud from my public domain (https://nextcloud.domain.com)
Those first couple of errors are occurring because it's expecting a CSS file, but when I actually go to the link, it's an HTML 404 page.
I used nginxconfig.io to help me generate all of the relevant conf files and adjusted to fit my server. Below are the nginx.conf file and nextcloud.domain.com.conf files
And here's nextcloud.domain.com.conf:
I can post some of the other includes if anyone thinks they would be helpful to see.
Can anyone give me any advice as to why it isn't working properly? I've been searching for hours trying to figure this out, but everything else I've found online either has the services running in a subfolder (domain.com/nextcloud) where the issue is with trailing slashes or issues not being able to load the sites at all through the reverse proxy. I haven't been able to find any other threads where anyone was having issues only loading some content, but not all.
user www; pid /var/run/nginx.pid; worker_processes 4; worker_rlimit_nofile 65535; events { multi_accept on; worker_connections 65535; } http { charset utf-8; sendfile on; tcp_nopush on; tcp_nodelay on; server_tokens off; log_not_found off; types_hash_max_size 2048; client_max_body_size 16M; # MIME include mime.types; default_type application/octet-stream; # logging access_log /var/log/nginx/access.log; error_log /var/log/nginx/error.log warn; # SSL ssl_session_timeout 1d; ssl_session_cache shared:SSL:50m; ssl_session_tickets off; # Diffie-Hellman parameter for DHE ciphersuites ssl_dhparam /usr/local/etc/nginx/dhparam.pem; # OWASP B (Broad Compatibility) configuration ssl_protocols TLSv1.2 TLSv1.3; ssl_ciphers TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256; ssl_prefer_server_ciphers on; # OCSP Stapling ssl_stapling on; ssl_stapling_verify on; resolver 1.1.1.1 1.0.0.1 8.8.8.8 8.8.4.4 208.67.222.222 208.67.220.220 valid=60s; resolver_timeout 2s; # load configs include /usr/local/etc/nginx/sites-enabled/*; }
server { listen 443 ssl http2; listen [::]:443 ssl http2; server_name nextcloud.domain.com; # SSL ssl_certificate /usr/local/etc/letsencrypt/live/nextcloud.domain.com/fullchain.pem; ssl_certificate_key /usr/local/etc/letsencrypt/live/nextcloud.domain.com/privkey.pem; ssl_trusted_certificate /usr/local/etc/letsencrypt/live/nextcloud.domain.com/chain.pem; # security include /usr/local/etc/nginx/nginxconfig.io/security.conf; # reverse proxy location / { proxy_pass http://NEXTCLOUD_IP:80; include /usr/local/etc/nginx/nginxconfig.io/proxy.conf; } # additional config include /usr/local/etc/nginx/nginxconfig.io/general.conf; } # HTTP redirect server { listen 80; listen [::]:80; server_name nextcloud.domain.com; include /usr/local/etc/nginx/nginxconfig.io/letsencrypt.conf; location / { return 301 https://nextcloud.domain.com$request_uri; } }
