LennySh
- Apr 13, 2020
Hi all,
So I've figured out how to put jails onto a different VLAN (or second NIC) using VNET (with or without DHCP), and this works great! But now, I have a need to use NAT, but not on the primary NIC. I'd like to use NAT on a secondary NIC (it's on a different VLAN). I've tried setting the NAT interface under advanced jail properties, but I get an error message:
Has anyone been able to do this successfully? I mean, I can continue creating them on the other VLAN using VNET, but NAT would make more sense (to keep from using so many IP addresses).
Thoughts?
nat_interface can only be changed for defaults!
Thoughts?
