i915 driver not loaded
blue55
Hi all,
i have the problem, that the i915 driver is not loading and I don't have the renderD132 in /dev/dri.
What me confused, after the initial update to cobia or dragonfish, the driver was loaded and the renderD132 was available.
What I did after the initial update:
- install of dev-tools
- install of tbs tv card driver (incl. make download untar, install patchutils, libproc-processtable-perl
Output from the system:
dmesg | grep i915
[    0.000000] Command line: BOOT_IMAGE=/ROOT/24.04-RC.1@/boot/vmlinuz-6.6.16-production+truenas root=ZFS=boot-pool/ROOT/24.04-RC.1 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N i915.force_probe=4626
[    0.015339] Kernel command line: BOOT_IMAGE=/ROOT/24.04-RC.1@/boot/vmlinuz-6.6.16-production+truenas root=ZFS=boot-pool/ROOT/24.04-RC.1 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N i915.force_probe=4626
[    6.616376] snd_hda_codec_hdmi hdaudioC0D2: No i915 binding for Intel HDMI/DP codec
Complete console out is attached.
lspci -v
00:00.0 Host bridge: Intel Corporation Device 4630 (rev 05)
        Subsystem: ASRock Incorporation Device 4630
        Flags: bus master, fast devsel, latency 0, IOMMU group 1
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-S GT1 [UHD Graphics 730] (rev 0c) (prog-if 00 [VGA controller])
        Subsystem: ASRock Incorporation Alder Lake-S GT1 [UHD Graphics 730]
        Flags: bus master, fast devsel, latency 0, IRQ 255, IOMMU group 0
        Memory at 6000000000 (64-bit, non-prefetchable) [size=16M]
        Memory at 4000000000 (64-bit, prefetchable) [size=256M]
        I/O ports at 3000
        Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
        Capabilities: [40] Vendor Specific Information: Len=0c <?>
        Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
        Capabilities: [ac] MSI: Enable- Count=1/1 Maskable+ 64bit-
        Capabilities: [d0] Power Management version 2
        Capabilities: [100] Process Address Space ID (PASID)
        Capabilities: [200] Address Translation Service (ATS)
        Capabilities: [300] Page Request Interface (PRI)
        Capabilities: [320] Single Root I/O Virtualization (SR-IOV)
        Kernel modules: i915
00:06.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 (rev 05) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 2
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: [disabled] [16-bit]
        Memory behind bridge: 70a00000-70afffff [size=1M] [32-bit]
        Prefetchable memory behind bridge: [disabled] [64-bit]
        Capabilities: [40] Express Root Port (Slot+), MSI 00
        Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [90] Subsystem: Device 0000:0000
        Capabilities: [a0] Power Management version 3
        Capabilities: [100] Null
        Capabilities: [220] Access Control Services
        Capabilities: [150] Precision Time Measurement
        Capabilities: [280] Virtual Channel
        Capabilities: [a30] Secondary PCI Express
        Capabilities: [a90] Data Link Feature <?>
        Capabilities: [a9c] Physical Layer 16.0 GT/s <?>
        Capabilities: [edc] Lane Margining at the Receiver <?>
        Kernel driver in use: pcieport
00:14.0 USB controller: Intel Corporation Alder Lake-S PCH USB 3.2 Gen 2x2 XHCI Controller (rev 11) (prog-if 30 [XHCI])
        Subsystem: ASRock Incorporation Alder Lake-S PCH USB 3.2 Gen 2x2 XHCI Controller
        Flags: bus master, medium devsel, latency 0, IRQ 127, IOMMU group 3
        Memory at 6001100000 (64-bit, non-prefetchable) [size=64K]
        Capabilities: [70] Power Management version 2
        Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
        Capabilities: [90] Vendor Specific Information: Len=14 <?>
        Capabilities: [b0] Vendor Specific Information: Len=00 <?>
        Kernel driver in use: xhci_hcd
        Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Alder Lake-S PCH Shared SRAM (rev 11)
        Flags: fast devsel, IOMMU group 3
        Memory at 6001114000 (64-bit, non-prefetchable) [disabled] [size=16K]
        Memory at 600111b000 (64-bit, non-prefetchable) [disabled] [size=4K]
        Capabilities: [80] Power Management version 3
00:15.0 Serial bus controller: Intel Corporation Alder Lake-S PCH Serial IO I2C Controller #0 (rev 11)
        Subsystem: ASRock Incorporation Alder Lake-S PCH Serial IO I2C Controller
        Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 4
        Memory at 4017000000 (64-bit, non-prefetchable) [size=4K]
        Kernel driver in use: intel-lpss
        Kernel modules: intel_lpss_pci
00:16.0 Communication controller: Intel Corporation Alder Lake-S PCH HECI Controller #1 (rev 11)
        Subsystem: ASRock Incorporation Alder Lake-S PCH HECI Controller
        Flags: bus master, fast devsel, latency 0, IRQ 138, IOMMU group 5
        Memory at 6001119000 (64-bit, non-prefetchable) [size=4K]
        Capabilities: [50] Power Management version 3
        Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [a4] Vendor Specific Information: Len=14 <?>
        Kernel driver in use: mei_me
        Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Alder Lake-S PCH SATA Controller [AHCI Mode] (rev 11) (prog-if 01 [AHCI 1.0])
        Subsystem: ASRock Incorporation Alder Lake-S PCH SATA Controller [AHCI Mode]
        Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 126, IOMMU group 6
        Memory at 70b20000 (32-bit, non-prefetchable) [size=8K]
        Memory at 70b23000 (32-bit, non-prefetchable)
        I/O ports at 3090
        I/O ports at 3080
        I/O ports at 3060
        Memory at 70b22000 (32-bit, non-prefetchable) [size=2K]
        Capabilities: [70] Power Management version 3
        Capabilities: [a8] SATA HBA v1.0
        Kernel driver in use: ahci
        Kernel modules: ahci
00:1d.0 PCI bridge: Intel Corporation Device 7ab6 (rev 11) (prog-if 00 [Normal decode])
        Subsystem: ASRock Incorporation Device 7ab6
        Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 7
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        Memory behind bridge: 70900000-709fffff [size=1M] [32-bit]
        Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [98] Subsystem: ASRock Incorporation Device 7ab6
00:1d.7 PCI bridge: Intel Corporation Device 7ab7 (rev 11) (prog-if 00 [Normal decode])
        Subsystem: ASRock Incorporation Device 7ab7
        Flags: bus master, fast devsel, latency 0, IRQ 124, IOMMU group 8
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        Memory behind bridge: 70800000-708fffff [size=1M] [32-bit]
        Capabilities: [98] Subsystem: ASRock Incorporation Device 7ab7
00:1f.0 ISA bridge: Intel Corporation Device 7a86 (rev 11)
        Subsystem: ASRock Incorporation Device 7a86
        Flags: bus master, fast devsel, latency 0, IOMMU group 9
00:1f.3 Audio device: Intel Corporation Alder Lake-S HD Audio Controller (rev 11)
        Subsystem: ASRock Incorporation Alder Lake-S HD Audio Controller
        Flags: bus master, fast devsel, latency 32, IRQ 140, IOMMU group 9
        Memory at 6001110000 (64-bit, non-prefetchable) [size=16K]
        Memory at 6001000000 (64-bit, non-prefetchable) [size=1M]
        Capabilities: [80] Vendor Specific Information: Len=14 <?>
        Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
00:1f.4 SMBus: Intel Corporation Alder Lake-S PCH SMBus Controller (rev 11)
        Subsystem: ASRock Incorporation Alder Lake-S PCH SMBus Controller
        Flags: medium devsel, IRQ 18, IOMMU group 9
        Memory at 6001118000 (64-bit, non-prefetchable)
        I/O ports at efa0
        Kernel driver in use: i801_smbus
        Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-S PCH SPI Controller (rev 11)
        Subsystem: ASRock Incorporation Alder Lake-S PCH SPI Controller
        Flags: fast devsel, IOMMU group 9
        Memory at 70b24000 (32-bit, non-prefetchable) [size=4K]
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (17) I219-V (rev 11)
        Subsystem: ASRock Incorporation Ethernet Connection (17) I219-V
        Flags: bus master, fast devsel, latency 0, IRQ 125, IOMMU group 9
        Memory at 70b00000 (32-bit, non-prefetchable) [size=128K]
        Capabilities: [c8] Power Management version 3
        Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Kernel driver in use: e1000e
        Kernel modules: e1000e
01:00.0 Non-Volatile memory controller: Micron/Crucial Technology P2 NVMe PCIe SSD (rev 01) (prog-if 02 [NVM Express])
        Subsystem: Micron/Crucial Technology P2 [Nick P2] / P3 / P3 Plus NVMe PCIe SSD (DRAM-less)
        Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 10
        Memory at 70a00000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [80] Express Endpoint, MSI 00
        Capabilities: [d0] MSI-X: Enable+ Count=9 Masked-
        Capabilities: [e0] MSI: Enable- Count=1/8 Maskable+ 64bit+
        Capabilities: [f8] Power Management version 3
        Capabilities: [100] Latency Tolerance Reporting
        Capabilities: [110] L1 PM Substates
        Capabilities: [200] Advanced Error Reporting
        Capabilities: [300] Secondary PCI Express
        Kernel driver in use: nvme
        Kernel modules: nvme
02:00.0 Multimedia controller: TBS Technologies DVB Tuner PCIe Card
        Subsystem: Device 6905:0001
        Flags: bus master, fast devsel, latency 0, IRQ 139, IOMMU group 11
        Memory at 70900000 (32-bit, non-prefetchable) [size=256K]
        Capabilities: [70] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [90] Express Endpoint, MSI 00
        Capabilities: [100] Device Serial Number 00-00-00-00-00-00-00-00
        Kernel driver in use: TBSECP3 driver
        Kernel modules: tbsecp3
03:00.0 SATA controller: ASMedia Technology Inc. Device 1064 (rev 02) (prog-if 01 [AHCI 1.0])
        Subsystem: ZyDAS Technology Corp. Device 2116
        Flags: bus master, fast devsel, latency 0, IRQ 129, IOMMU group 12
        Memory at 70882000 (32-bit, non-prefetchable) [size=8K]
        Memory at 70880000 (32-bit, non-prefetchable) [size=8K]
        Expansion ROM at 70800000 [disabled] [size=512K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [130] Secondary PCI Express
Can you help me to activate the iGPU and to use the renderD132 in docker containers?
What can I do to debug why the driver is not loaded?
Thanks,
Fabian
  • dmesg.txt
