Because your configuration told it to redirect any http connections to https, but the server can't do https without some (even self-signed) certificate).
I get warnings after restart apache24 and i dont know, how to analyze, what is cause it. Can you forward me to find some solution or diagnosing?
warnings:
Performing sanity check on apache24 configuration:
WARNING: number of probes fixed does not match the number of defined probes (12 != 13, respectively)
WARNING: some probes might not fire or your program might crash
Syntax OK
Stopping apache24.
Waiting for PIDS: 51979.
Syntax OK
Starting apache24.
Installed SW:
Nextcloud 13.0.3, FN9.10, Apache24, PHP v7.2.6. Aslo installed ModSecurity, ClamAV, fail2ban, SSMTP. For now no SSL instalation (only 80).
I get no access to the Settings/overview (german: Einstellungen->Verwaltung->Übersicht) to start an update from here.
How can I start the update process manual from console?
I guess its the script in /usr/local/www/apache24/data/nextcloud/updater/updater.phar but how to start?
sudo -u www php updater.phar does´t work... Or is there a bug (14.0.3.0 )?
yes, but still nothing happens. but now I can reach the backup tool on web-GUI so I can update to the newest version.
But still no idea why manual update doesn´t work or doesn´t show a progress. the file is there and like I said I get no error message when calling
