[How To] Install plexconnect for aTV
traxinv
How to Install PlexConnect (with automatic boot)
Login to your FreeNAS server using the normal ip. Then go to the jails section in the navigation bar and then add jails. Select the following options:
You can give it any IP you prefer. Also make sure you select the following:
Then Click ok!
Next go ahead and open putty (or something similar) and connect directly to your FreeNAS’s IP. Username: root Password: [your password]
First we need to find the jail we just created. Run the following command:
jls
This will return a list of all your current jails:
Now you want to directly connect to the jail itself using the JID. From the list you look for the hostname PlexConnect (I will be using PlexConnect_test as I don’t want to change my current setup, you should use PlexConnect jail.)
To get into the jail run the following command
jexec <JID> csh
Where <JID> is the JID of the PlexConnect jail.
Install the required software:
First we are going to have to install all the extra packages PlexConnect requires to work.
1.Pkg manager.
First let’s do some future proofing. Now pkg_add can be used instead of this method. But everyone seems to have a massive problem with it so lets us pkgng, BUT since it is not as standard part of a pluginjail (or is depending on the version of freenas you are running) we need to install it.
Run:
pkg_add -r pkg
(Note if this is not working skip to the next package)
So then run the command:
pkg2ng
This will take several minutes just be patient. Now for good measure you can just run:
pkg update
If it want you to update the pkg manager just say yes.
2.Python
pkg install python
3.Nano – Text editing
pkg install nano
4.Bash
pkg install bash
5.Git
pkg install git
6.Pillow
pkg install py27-pillow
Part 1: Get PlexConnect and Configure it
Get PlexConnect
Now we have to fetch the newest PlexConnect from the git repo.
git clone https://github.com/iBaa/PlexConnect.git
cd PlexConnect/
git pull
Generate the required SSL certificates
Next we need to create the communication certificates. Change directory to the certificates folder
cd /PlexConnect/assets/certificates
openssl req -new -nodes -newkey rsa:2048 -out trailers.pem -keyout trailers.key -x509 -days 7300 -subj "/C=US/CN=trailers.apple.com"
This will create 2 files trailers.key and trailers.pem. Next run this:
openssl x509 -in trailers.pem -outform der -out trailers.cer && cat trailers.key >> trailers.pem
Create the Settings.cfg file
Go back to the root directory:
cd /
Change Directory
cd PlexConnect/
Start PlexConnect so it creates Settings.cfg
./PlexConnect.py
When it started Exit using CTRL + C
nano Settings.cfg
Change the 2 lines below
ip_pms = 10.0.0.30 # This one you have to change to your Jail IP address
enable_plexgdm = False # This one you have to change from True to False
Test that the basics work:
To start PlexConnect
bash /PlexConnect/PlexConnect_daemon.bash start
Make sure it starts up:
bash /PlexConnect/PlexConnect_daemon.bash status
It should return that it is running. Then you can stop the process:
bash /PlexConnect/PlexConnect_daemon.bash stop
Part 2: Creating Boot Script
Initial Setup:
Creat the boot script
nano /etc/rc.d/plexconnect
copy and paste the following code and then save and close the file.
#!/bin/sh
#PROVIDE: PlexConnect
#REQUIRE: DAEMON
#KEYWORD: shutdown
. /etc/rc.subr
name=plexconnect
rcvar=plexconnect_enable
start_cmd="${name}_start"
stop_cmd="${name}_stop"
status_cmd="${name}_status"
extra_commands="status"
PATH=/usr/local/bin:${PATH}
plexconnect_start()
/usr/local/bin/bash /PlexConnect/PlexConnect_daemon.bash start
plexconnect_stop()
/usr/local/bin/bash /PlexConnect/PlexConnect_daemon.bash stop
plexconnect_status()
/usr/local/bin/bash /PlexConnect/PlexConnect_daemon.bash status
load_rc_config $name
run_rc_command "$1"
NOTE: if you installed PlexConnect in a different directory change the directory to the bash script.
Next make sure the permissions are the same as the other scripts, run the following script:
chmod 0555 /etc/rc.d/plexconnect
Register the script:
Run the following command to open the rc.conf file:
nano /etc/rc.conf
and add the following line:
plexconnect_enable="Yes"
Check that the script works:
so when you are in the root dir and you call:
/etc/rc.d/plexconnect start
and then calling:
/etc/rc.d/plexconnect status
and it returns:
PlexConnect is running
so great the script works.
Now just run:
/etc/rc.d/plexconnect stop
So we make sure plex is not running before we try to start it as a service.
Setup the plexconnect service:
FINALLY:
run the following command:
service plexconnect status
and it should return:
PlexConnect is not running
Okay great the service is now working. Thank god. Now just startup plexconnect:
service plexconnect start
So plexconnect is now running and it is a valid service. Yay.
You can then test if it is working by either rebooting your NAS or toggling the plugins on off switch.
FINAL NOTE:
Update: 2015-05-04 - Changed Boot script to now include the path parameter. Hence you no longer need to edit the bash script. (Thanks @mbaltaks)
Updated: 2015-05-04 - Added the native package manger install procedure for pillow. (also @mbaltaks)
--++00DONE00++--
  • PlexConnect.pdf
Pouper
This was a great discussion over at the Plex forums so it's nice having it here.
Word of warning if you're on 9.2.1: install for FreeBSD packages seems to be broken. Looking into it further to see what's going on.
Great guide and thank you!
lanky8804
As Pouper said jail packages broken!
Also what jail and options are best for PlexConnect?
fracai
Can you clarify a bit what this is actually for? I don't see a link to the original post on the Plex forums, so I think I'm missing some context.
Is aTV referring to AppleTV? Is this the hack that replaces the Trailers channel with Plex?
traxinv
Yes aTv refers to apple tv and yes it replaces the apple tv's trailer app with plex content.
The link to the original post is in the word <post>
fracai
Ah, not sure how I missed the link. Thanks.
traxinv
I am on 9.2.1-Beta no problems with any packages? Might i be missing something?
Chris9149
Trying to do this but every time I make it to running "./PlexConnect.py" I get the error "env: python: No such file or directory"
I am on FreeNas 9.2.1.1. Is this something to do with the packages seeming to be broken as mentioned above? Everything seemed to install fine before that point.
lanky8804
Just updated to freeNAS 9.2.1.2 previously always installed PlexConnect this way however now pkg_add not supported any chance you can update instructions for pkgng?
Have had a look around but cant figure out the commands i need to use.
traxinv
Will have a look when I update to the new freenas:)
DjBac
Although I've installed PlexConnect I am trying now to install in on another server but when I execute ./PlexConnect.py I get "env: python: No such file or directory".
Any help on this please?
186282.39mps
Hmm, I get to this stage and then something unexpected occurs:
Code (text):
./PlexConnect.py
root@plexmediaserver_1:/PlexConnect # ./PlexConnect.py env: python: No such file or directory
root@plexmediaserver_1:/PlexConnect # ls .git PlexConnect_daemon.bash .gitignore PlexConnect_daemon.py ATVSettings.py README.md DNSServer.py Settings.py Debug.py Subtitle.py License.txt Version.py Localize.py WebServer.py PlexAPI.py XMLConverter.py PlexConnect.py assets PlexConnect_WinService.py support root@plexmediaserver_1:/PlexConnect #
Running 9.1.2.5, but this is my first Python experience
traxinv
Code (text):
./PlexConnect.py
Try running pkg_add -r python before you try to run that command.
I so can't wait for the old package system to go away... like 4 months or so now. Then all you old pkg_add users will be forced to use the new system.
traxinv
am rewriting the guide for the new method. Just posted a quick fix :P
186282.39mps
traxinv, I tried this and verified that python version 2.7 is running. Still, I get the same response trying to execute the PlexConnect.py script. BTW, inspecting the script more PlexConnect.py) shows a call to '#!/usr/bin/env python', but I am not sure that is where Python is actually located. From the webgui I use the Display System Processes it shows Python2.7 running. Shouldn't the Python script (I'm not programmer, mind you) be calling on python2.7, and not python?
