SOLVED [Help Needed] TrueNAS Cloud Sync to Backblaze B2 fails
marioawe
Hi all -
I have been attempting to track down an issue with my setup and I am having no luck. I'm on TrueNAS Core (virtualized on Proxmox), attemping to backup everything to my Backblaze B2 bucket. It appears that it everything should be correct, and does indeed sync some data, after a short while, the task fails with this error message.
[EFAULT] rip    0x802f0c8da
rflags 0x202
cs  0x43
fs  0x13
gs  0x1b
rclone failed with exit code 2
Logs are attached, please let me know what additional info I can provide! Thanks in advance!
Edit: Watching it, CPU spikes to 100% and the task then fails. I'm unsure what to do to fix my issue.
  • 44770.txt
marioawe
I believe I may have solved this. I accidentally slipped too many zeros into the 'Transfers' option. Has been running smoothly for the past few hours.
