Me too, although it might have something to do with the type of jail as it looks like you've created as a plugin jail, or at least that's what I'm reading from /mnt/mainvolume/pluginjail/...
If you've copied the /PlexEmail/web/ folder (with all subdirectories) into /usr/local/www/apache24/data/plexemail and then added the correct path into the config.conf file when you run the python script it should create the html files.
I'd check the lines in the config.conf file and then ask over at forums.plex.tv in the PlexEmail thread. The _1 at the end of the jail name makes me think you might have created a plugin jail too?
Where / What exactly is the plexdata folder I am supposed to point my storage at? I currently have my storage pointed as follows
When I try and run the script I get the following error, but as you can see the db file is in the plexms folder/directory (what ever the correct term is). Is it the fact that I have installed Plex using the plugin and not manually installed it?
Hi thanks for help, yes I did the copy as per your instructions.
II am just going to give up, everything is working perfect with my Plex & SickRage setup, just thought this looked interesting but can't be bothered messing around any more.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
