Ethernet Card and 9.3.1 Update
korrupto77
Hi Gents,
Maybe someone of You has already encountered similar issue;
I have a Network Adapter with RTL8169SC chipset which works fine on 9.3, whe i try to upgrade system to 9.3.1, OS doesn't recognize ETH adapter ( no configured interfaces were found) no way to configure manually . I've verified and chipset is included in re4 BSD driver . Does anyone have any suggestion ??
Thanks In Advance
korrupto77
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether d0:50:99:44:d3:40
media: Ethernet autoselect (none)
status: no carrier
re1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether 00:30:4f:6a:24:ce
inet 172.16.10.37 netmask 0xffff0000 broadcast 172.16.255.255
media: Ethernet autoselect (100baseTX <full-duplex>)
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6
ether 02:5b:3f:ef:d1:00
nd6 options=1<PERFORMNUD>
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
member: re1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 200000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:43:5d:00:08:0a
status: active
D
dlavigne
Guest
status: active
This interface is active and configured. Were you expecting something else?
korrupto77
Now is working fine, if im applying the 9.3.1 update it stops to work
im doing now in order to paste here the output of ifconfig
korrupto77
dlavigne , How do I post output from console setup ?? :(
SweetAndLow
Sweet'NASty
Use ipmi or take photo.
korrupto77
here we are
korrupto77
pirateghost u mean my nic is not compatible ??:(
SweetAndLow
Sweet'NASty
korrupto77
no way i've tried to assign ip netmask i went into gui but so many errors, i'm gonna buy an intel chipset !!
korrupto77
I agree but there should at least be an IP.
@korrupto77 that nic is terrible and will probably cause all kinds of problems for freenas.
I've seen !!! till 9.3 is ok but with upgrade doesn't want to work !!
korrupto77
Thanks for the support guys,
any suggestion for acceptable eth card ( not too expensive ) :cool:??
jgreco
Resident Grinch
A typical Intel PCIe desktop card for about thirty dollars will work wonders. Plus it'll actually work, unlike Realteks, which seem rather hit-or-miss.
korrupto77
Heeeelllllllppppp, I've changed the card with an intel EXPI9301CTBLK but is same , it doesn't change the !!! does someone can help me ?? any idea ??
Thanks Guys
depasseg
FreeNAS Replicant
So on the working system, you are connected at 100M full duplex and after the upgrade, the speed is 10M half duplex. I'd look at cabling or the switch port that the freenas connects to.
