Error with linux startup in VM
chaoticdopey
Ok so i installed Parrot OS on Truenas and it worked great for the first day but after i restarted my truenas server i get this call error when trying to start the VM
[EFAULT] Unable to define domain for Parrot: cannot serialize None (type NoneType)
More Info
File "/usr/lib/python3.9/xml/etree/ElementTree.py", line 1052, in _escape_attrib
if "&" in text:
TypeError: argument of type 'NoneType' is not iterable
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 45, in _check_add_domain
self._add(self._vm_from_name(vm_name)['id'])
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 16, in _add
self._add_with_vm_data(vm)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 19, in _add_with_vm_data
self.vms[vm['name']] = VMSupervisor(vm, self.middleware)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 30, in __init__
self.update_domain()
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 60, in update_domain
self.__define_domain()
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 92, in __define_domain
vm_xml = etree.tostring(self.construct_xml()).decode()
File "/usr/lib/python3.9/xml/etree/ElementTree.py", line 1109, in tostring
ElementTree(element).write(stream, encoding,
File "/usr/lib/python3.9/xml/etree/ElementTree.py", line 748, in write
serialize(write, self._root, qnames, namespaces,
File "/usr/lib/python3.9/xml/etree/ElementTree.py", line 913, in _serialize_xml
_serialize_xml(write, e, qnames, None,
[Previous line repeated 1 more time]
File "/usr/lib/python3.9/xml/etree/ElementTree.py", line 906, in _serialize_xml
v = _escape_attrib(v)
File "/usr/lib/python3.9/xml/etree/ElementTree.py", line 1075, in _escape_attrib
_raise_serialization_error(text)
File "/usr/lib/python3.9/xml/etree/ElementTree.py", line 1029, in _raise_serialization_error
raise TypeError(
TypeError: cannot serialize None (type NoneType)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 184, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1317, in _call
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1379, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1247, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 46, in start
await self.middleware.run_in_thread(self._start, vm['name'])
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1234, in run_in_thread
return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1231, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 67, in _start
self._check_add_domain(vm_name)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 47, in _check_add_domain
raise CallError(f'Unable to define domain for {vm_name}: {e}')
middlewared.service_exception.CallError: [EFAULT] Unable to define domain for Parrot: cannot serialize None (type NoneType)
What do i need to do to fix this without reinstalling parrot
OS Version:TrueNAS-SCALE-22.12.4.2
Product:HP Z440 Workstation
Model:Intel(R) Xeon(R) CPU E5-2680 v4@ 2.40GHz
Memory:126 GiB
Memento196
Solved it! Go to your VM -> Devices -> USB ->Edit . Have a Look at the "Davide*" dropdown, Mine was empty i just selected USB Hub and the VM is starting
