Eklenti Kurma Problemi
eonkoyun
Merhabalar,
Eklentiler kısmına geldiğimde Eklentiler-1.jpg deki görüntüyü alıyorum. eklentiyi internetten indirip denediğim de ise aşağıfaki uyarıyı alıyorum. Hta veriyor. Nasıl çözebilirim.
Environment:
Software Version: FreeNAS-11.1-U7 (b45bfcf29)
Request Method: POST
Request URL: http://192.168.1.47/plugins/plugin/upload/?X-Progress-ID=f4d85d94-6b5a-4f09-84eb-6baaa36ab730
Traceback:
File "./freenasUI/jails/utils.py" in new_default_plugin_jail
675. w.template(**template_create_args)
File "./freenasUI/common/warden.py" in template
1159. return self.__call(warden_template(flags, **kwargs))
File "./freenasUI/common/warden.py" in __call
1070. tmp = obj.run()
File "./freenasUI/common/warden.py" in run
465. raise warden_exception(msg)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
42. response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
249. response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
178. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
162. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
23. return view_func(request, *args, **kwargs)
File "./freenasUI/plugins/views.py" in upload_nojail
497. return upload(request)
472. form.done()
File "./freenasUI/plugins/forms.py" in done
138. raise e
136. jail = new_default_plugin_jail("customplugin")
680. raise MiddlewareError(str(e))
Exception Type: MiddlewareError at /plugins/plugin/upload/
Exception Value: [MiddlewareError: [warden_exception: fetch: http://download.freenas.org/jails/11/x64/freenas-pluginjail-11.0-RELEASE.mtree: Operation timed out
http://download.freenas.org/jails/11/x64/freenas-pluginjail-11.0-RELEASE.tgz: Operation timed out
mtree: /mnt/MyDepo/jails/.warden-files-cache/mtree/freenas-pluginjail-11.0-RELEASE.mtree: No such file or directory
ERROR: mtree failed for /mnt/MyDepo/jails/.warden-files-cache/mtree/freenas-pluginjail-11.0-RELEASE.mtree
cannot open 'MyDepo/jails/.warden-template-pluginjail': dataset does not exist
find: /mnt/MyDepo/jails/.warden-template-pluginjail: No such file or directory
ERROR: Failed to create ZFS base dataset
