Calibre-Web mount point not showing up in app
Hi there
I just installed Calibre-Web using TrueCharts. I set a mount point and put the metadata.db file in there in order to use it for the database.
However, the folder appears in the filesystem in Calibre-Web but has no contents. I even set the permissions to 777 in case it was permissions issue.
I can't figure it out. Any help would be great
Thanks
