Boot volume critical alert
programmer01001
I just upgraded to 9.3 version and got this strange alert (screenshot in attachement).
Could you please help knowing, if what is causing this error?
Thank you.
D
dlavigne
Guest
Post a screenshot of System -> Boot Status. Doesn't hurt to also include the output of zpool status as the alert is unclear whether it is the boot device or the pool which has an issue.
D
dlavigne
Guest
Looks like the boot device is flaky. Do you have another USB stick you can install to?
D
dlavigne
Guest
I'd recommend saving the config and installing to the new device to make sure it gets properly formatted by the installer.
