- May 17, 2014
On occasion, external USB attached CMR drives, (3.5"), work well for backups. However, their are problems:
- Leaving USB drives attached semi-permanently may not work, (or work well).
- Heat can be an issue. Many USB enclosures are designed for casual use, not very regular, full blown backups.
- At some point, size wise, you may want something larger. (You want 3 x 2TB, which could be replaced by a 6TB single drive).
- USB 3 speeds can be irregular when compared to SATA, (or SAS), interface(s).
Why you should avoid USB attached drives for data pool disks
This subject has been coming up quite often since about 2022. Perhaps because of TrueNAS SCALE has brought forth some attention to TrueNAS in general and ZFS in specific. Please note that this is about USB attached storage for ZFS data pools. On occasion, people use USB drives, (flash...
www.truenas.com
