SOLVED After bios update supermicro motherboard truenas does not start up anymore
K.J
After bios update supermicro motherboard truenas does not start up anymore.
Must say though that I accidentally, unfortunately pressed reset after the update.
Can I now assume that everything has been removed?
And I have to completely reinstall truenas.
Or is there any other solution?
ChrisRJ
Re-installation is not likely to help.
I would check the order of boot drives first. Actually, you should check all BIOS settings.
Exactly. The BIOS update is very likely to have changed the boot order, especially if you loaded the default settings afterward as the docs almost certainly instructed you to do.
K.J
Thank you very much for your responses!
Didn't think about this at all.
It's working as usual again.
What a great forum this is and remains.
@ChrisRJ @danb35
ChrisRJ
Happy to help. Please mark thread as solved ...
