AD not working after 9.3 upgrade
generaltablet
Hello, after upgrading 2 machines to 9.3 from 9.2.1.7, AD seems to have been lost in both cases. In Directory Service > Active Directory, I've entered my domain.local for Domain Name, an administrator's account & password, and checked the Enable box. Same settings as before, but now I get the error: "The service failed to restart."
wbinfo -u doesn't return any of my AD users.
Are there any known problems with AD as a result of this upgrade?
generaltablet
I don't see anything. The upgrade was yesterday 12/9. I can ping the DC by name, and the DC can ping this machine by name.
Dec 9 10:45:11 morgan kernel: ugen0.4: <Dell> at usbus0
Dec 9 10:45:11 morgan kernel: ukbd0: <Dell Dell USB Keyboard, class 0/0, rev 1.10/3.01, addr 4> on usbus0
Dec 9 10:45:11 morgan kernel: kbd2 at ukbd0
Dec 9 10:45:40 morgan shutdown: power-down by root:
Dec 9 10:45:48 morgan smbd[6543]: dnssd_clientstub DNSServiceProcessResult called with DNSServiceRef with no ProcessReply function
Dec 9 10:45:48 morgan kernel: .
Dec 9 10:45:49 morgan kernel: , 4618.
Dec 9 10:45:49 morgan kernel: .
Dec 9 10:45:49 morgan winbindd[6547]: [2014/12/09 10:45:49.662198, 0] ../source3/winbindd/winbindd.c:234(winbindd_sig_term_handler)
Dec 9 10:45:49 morgan winbindd[6547]: Got sig[15] terminate (is_parent=1)
Dec 9 10:45:49 morgan winbindd[6559]: [2014/12/09 10:45:49.677174, 0] ../source3/winbindd/winbindd.c:234(winbindd_sig_term_handler)
Dec 9 10:45:49 morgan winbindd[6559]: Got sig[15] terminate (is_parent=0)
Dec 9 10:45:49 morgan winbindd[9357]: [2014/12/09 10:45:49.732357, 0] ../source3/winbindd/winbindd.c:234(winbindd_sig_term_handler)
Dec 9 10:45:49 morgan winbindd[9357]: Got sig[15] terminate (is_parent=0)
Dec 9 10:45:49 morgan winbindd[96414]: STATUS=daemon 'winbindd' finished starting up and ready to serve connectionsGot sig[15] terminate (is_parent=0)
Dec 9 10:45:49 morgan nmbd[6539]: [2014/12/09 10:45:49.758886, 0] ../source3/nmbd/nmbd.c:57(terminate)
Dec 9 10:45:49 morgan nmbd[6539]: Got SIGTERM: going down...
Dec 9 10:45:49 morgan nmbd[6539]: [2014/12/09 10:45:49.765873, 0] ../source3/libsmb/nmblib.c:873(send_udp)
Dec 9 10:45:49 morgan nmbd[6539]: Packet send failed to 192.168.1.255(138) ERRNO=Network is down
Dec 9 10:45:49 morgan python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Dec 9 10:45:50 morgan ntpd[2923]: ntpd exiting on signal 15
Dec 9 10:45:50 morgan python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Dec 9 10:45:50 morgan kernel: .
Dec 9 10:45:51 morgan python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Dec 9 10:45:52 morgan python: dnssd_clientstub ConnectToServer: connect() failed Socket:4 Err:-1 Errno:61 Connection refused
Dec 9 10:45:54 morgan python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Dec 9 10:45:54 morgan kernel:
Dec 9 10:45:54 morgan kernel: ugen0.4: <Dell> at usbus0 (disconnected)
Dec 9 10:45:54 morgan kernel: ukbd0: at uhub3, port 2, addr 4 (disconnected)
Dec 9 10:45:55 morgan python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Dec 9 10:45:56 morgan python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Dec 9 10:45:57 morgan python: dnssd_clientstub ConnectToServer: connect() failed Socket:4 Err:-1 Errno:61 Connection refused
Dec 9 10:45:58 morgan python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Dec 9 10:45:59 morgan syslogd: exiting on signal 15
Dec 9 11:08:45 morgan syslog-ng[1668]: syslog-ng starting up; version='3.5.6'
Dec 9 11:08:45 morgan Copyright (c) 1992-2014 The FreeBSD Project.
Dec 9 11:08:45 morgan Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Dec 9 11:08:45 morgan The Regents of the University of California. All rights reserved.
Dec 9 11:08:45 morgan FreeBSD is a registered trademark of The FreeBSD Foundation.
Dec 9 11:08:45 morgan FreeBSD 9.3-RELEASE-p5 #0 3b4abc3: Mon Dec 8 15:09:41 PST 2014
Dec 9 11:08:45 morgan root@build3.ixsystems.com:/tank/home/jkh/build/M/FN/objs/os-base/amd64/fusion/jkh/M/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
Dec 9 11:08:45 morgan gcc version 4.2.1 20070831 patched [FreeBSD]
Dec 9 11:08:45 morgan CPU: Intel(R) Pentium(R) CPU G860 @ 3.00GHz (2993.27-MHz K8-class CPU)
Dec 9 11:08:45 morgan Origin = "GenuineIntel" Id = 0x206a7 Family = 0x6 Model = 0x2a Stepping = 7
Dec 9 11:08:45 morgan Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Dec 9 11:08:45 morgan Features2=0xd9ae3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,POPCNT,TSCDLT,XSAVE,OSXSAVE>
Dec 9 11:08:45 morgan AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
Dec 9 11:08:45 morgan AMD Features2=0x1<LAHF>
Dec 9 11:08:45 morgan TSC: P-state invariant, performance statistics
Dec 9 11:08:45 morgan real memory = 17381191680 (16575 MB)
Dec 9 11:08:45 morgan avail memory = 16500027392 (15735 MB)
Dec 9 11:08:45 morgan Event timer "LAPIC" quality 600
Dec 9 11:08:45 morgan ACPI APIC Table: <HP ProLiant>
Dec 9 11:08:45 morgan FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
Dec 9 11:08:45 morgan FreeBSD/SMP: 1 package(s) x 2 core(s)
Dec 9 11:08:45 morgan cpu0 (BSP): APIC ID: 0
Dec 9 11:08:45 morgan cpu1 (AP): APIC ID: 2
Dec 9 11:08:45 morgan WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Dec 9 11:08:45 morgan ACPI Warning: Invalid length for Pm1aControlBlock: 32, using default 16 (20111123/tbfadt-658)
Dec 9 11:08:45 morgan ACPI Warning: Invalid length for Pm2ControlBlock: 32, using default 8 (20111123/tbfadt-658)
Dec 9 11:08:45 morgan ioapic0: Changing APIC ID to 8
Dec 9 11:08:45 morgan ioapic0 <Version 2.0> irqs 0-23 on motherboard
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_1040>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_1040_it>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_1080>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_1080_it>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_12160>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_12160_it>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_2100>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_2200>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_2300>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_2322>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_2400>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_2400_multi>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_2500>
Dec 9 11:08:45 morgan ispfw: registered firmware <isp_2500_multi>
Dec 9 11:08:45 morgan kbd1 at kbdmux0
Dec 9 11:08:45 morgan cryptosoft0: <software crypto> on motherboard
Dec 9 11:08:45 morgan aesni0: No AESNI support.
Dec 9 11:08:45 morgan padlock0: No ACE support.
Dec 9 11:08:45 morgan acpi0: <HP ProLiant> on motherboard
Dec 9 11:08:45 morgan acpi0: Power Button (fixed)
Dec 9 11:08:45 morgan cpu0: <ACPI CPU> on acpi0
Dec 9 11:08:45 morgan cpu1: <ACPI CPU> on acpi0
Dec 9 11:08:45 morgan attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Dec 9 11:08:45 morgan Timecounter "i8254" frequency 1193182 Hz quality 0
Dec 9 11:08:45 morgan Event timer "i8254" frequency 1193182 Hz quality 100
Dec 9 11:08:45 morgan hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Dec 9 11:08:45 morgan Timecounter "HPET" frequency 14318180 Hz quality 950
Dec 9 11:08:45 morgan Event timer "HPET" frequency 14318180 Hz quality 550
Dec 9 11:08:45 morgan Event timer "HPET1" frequency 14318180 Hz quality 440
Dec 9 11:08:45 morgan Event timer "HPET2" frequency 14318180 Hz quality 440
Dec 9 11:08:45 morgan Event timer "HPET3" frequency 14318180 Hz quality 440
Dec 9 11:08:45 morgan Event timer "HPET4" frequency 14318180 Hz quality 440
Dec 9 11:08:45 morgan Event timer "HPET5" frequency 14318180 Hz quality 440
Dec 9 11:08:45 morgan Event timer "HPET6" frequency 14318180 Hz quality 440
Dec 9 11:08:45 morgan atrtc0: <AT realtime clock> port 0x70-0x71 on acpi0
Dec 9 11:08:45 morgan Event timer "RTC" frequency 32768 Hz quality 0
Dec 9 11:08:45 morgan Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
Dec 9 11:08:45 morgan acpi_timer0: <24-bit timer at 3.579545MHz> port 0x908-0x90b on acpi0
Dec 9 11:08:45 morgan pcib0: <ACPI Host-PCI bridge> on acpi0
Dec 9 11:08:45 morgan pci0: <ACPI PCI bus> on pcib0
Dec 9 11:08:45 morgan pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
Dec 9 11:08:45 morgan pci4: <ACPI PCI bus> on pcib1
Dec 9 11:08:45 morgan pcib2: <ACPI PCI-PCI bridge> at device 6.0 on pci0
Dec 9 11:08:45 morgan pci7: <ACPI PCI bus> on pcib2
Dec 9 11:08:45 morgan ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfacc0000-0xfacc03ff irq 21 at device 26.0 on pci0
Dec 9 11:08:45 morgan usbus0: EHCI version 1.0
Dec 9 11:08:45 morgan usbus0 on ehci0
Dec 9 11:08:45 morgan pcib3: <ACPI PCI-PCI bridge> at device 28.0 on pci0
Dec 9 11:08:45 morgan pci10: <ACPI PCI bus> on pcib3
Dec 9 11:08:45 morgan pcib4: <ACPI PCI-PCI bridge> at device 28.4 on pci0
Dec 9 11:08:45 morgan pci2: <ACPI PCI bus> on pcib4
Dec 9 11:08:45 morgan em0: <Intel(R) PRO/1000 Network Connection 7.4.2> port 0x4000-0x401f mem 0xfbee0000-0xfbefffff,0xfbed0000-0xfbed3fff irq 16 at device 0.0 on pci2
Dec 9 11:08:45 morgan em0: Using MSIX interrupts with 3 vectors
Dec 9 11:08:45 morgan em0: Ethernet address: a0:b3:cc:ec:2b:aa
Dec 9 11:08:45 morgan pcib5: <ACPI PCI-PCI bridge> at device 28.5 on pci0
Dec 9 11:08:45 morgan pci3: <ACPI PCI bus> on pcib5
Dec 9 11:08:45 morgan em1: <Intel(R) PRO/1000 Network Connection 7.4.2> port 0x5000-0x501f mem 0xfbfe0000-0xfbffffff,0xfbfd0000-0xfbfd3fff irq 17 at device 0.0 on pci3
Dec 9 11:08:45 morgan em1: Using MSIX interrupts with 3 vectors
Dec 9 11:08:45 morgan em1: Ethernet address: a0:b3:cc:ec:2b:ab
Dec 9 11:08:45 morgan pcib6: <ACPI PCI-PCI bridge> at device 28.6 on pci0
Dec 9 11:08:45 morgan pci13: <ACPI PCI bus> on pcib6
Dec 9 11:08:45 morgan pcib7: <ACPI PCI-PCI bridge> at device 28.7 on pci0
Dec 9 11:08:45 morgan pci1: <ACPI PCI bus> on pcib7
Dec 9 11:08:45 morgan vgapci0: <VGA-compatible display> mem 0xf9000000-0xf9ffffff,0xfbde0000-0xfbde3fff,0xfb000000-0xfb7fffff irq 16 at device 0.1 on pci1
Dec 9 11:08:45 morgan vgapci0: Boot video device
Dec 9 11:08:45 morgan uhci0: <UHCI (generic) USB controller> port 0x2000-0x201f irq 16 at device 0.4 on pci1
Dec 9 11:08:45 morgan usbus1 on uhci0
Dec 9 11:08:45 morgan ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfacb0000-0xfacb03ff irq 20 at device 29.0 on pci0
Dec 9 11:08:45 morgan usbus2: EHCI version 1.0
Dec 9 11:08:45 morgan usbus2 on ehci1
Dec 9 11:08:45 morgan pcib8: <PCI-PCI bridge> at device 30.0 on pci0
Dec 9 11:08:45 morgan pci19: <PCI bus> on pcib8
Dec 9 11:08:45 morgan isab0: <PCI-ISA bridge> at device 31.0 on pci0
Dec 9 11:08:45 morgan isa0: <ISA bus> on isab0
Dec 9 11:08:45 morgan atapci0: <Intel Cougar Point SATA300 controller> port 0x1400-0x1407,0x1408-0x140b,0x1410-0x1417,0x1418-0x141b,0x1420-0x142f,0x1430-0x143f irq 17 at device 31.2 on pci0
Dec 9 11:08:45 morgan ata2: <ATA channel> at channel 0 on atapci0
Dec 9 11:08:45 morgan ata3: <ATA channel> at channel 1 on atapci0
Dec 9 11:08:45 morgan atapci1: <Intel Cougar Point SATA300 controller> port 0x1440-0x1447,0x1448-0x144b,0x1450-0x1457,0x1458-0x145b,0x1460-0x146f,0x1470-0x147f irq 17 at device 31.5 on pci0
Dec 9 11:08:45 morgan ata4: <ATA channel> at channel 0 on atapci1
Dec 9 11:08:45 morgan ata5: <ATA channel> at channel 1 on atapci1
Dec 9 11:08:45 morgan acpi_tz0: <Thermal Zone> on acpi0
Dec 9 11:08:45 morgan atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
Dec 9 11:08:45 morgan atkbd0: <AT Keyboard> irq 1 on atkbdc0
Dec 9 11:08:45 morgan kbd0 at atkbd0
Dec 9 11:08:45 morgan atkbd0: [GIANT-LOCKED]
Dec 9 11:08:45 morgan psm0: <PS/2 Mouse> irq 12 on atkbdc0
Dec 9 11:08:45 morgan psm0: [GIANT-LOCKED]
Dec 9 11:08:45 morgan psm0: model Generic PS/2 mouse, device ID 0
Dec 9 11:08:45 morgan uart0: <Non-standard ns8250 class UART with FIFOs> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Dec 9 11:08:45 morgan ichwd0 on isa0
Dec 9 11:08:45 morgan ichwd0: ICH WDT present but disabled in BIOS or hardware
Dec 9 11:08:45 morgan device_attach: ichwd0 attach returned 6
Dec 9 11:08:45 morgan ichwd0 at port 0x930-0x937,0x960-0x97f on isa0
Dec 9 11:08:45 morgan orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xcafff on isa0
Dec 9 11:08:45 morgan sc0: <System console> at flags 0x100 on isa0
Dec 9 11:08:45 morgan sc0: VGA <16 virtual consoles, flags=0x300>
Dec 9 11:08:45 morgan vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Dec 9 11:08:45 morgan uart1: <Non-standard ns8250 class UART with FIFOs> at port 0x2f8-0x2ff irq 3 on isa0
Dec 9 11:08:45 morgan wbwd0: DevID 0x02 DevRev 0x01, will not attach, please report this.
Dec 9 11:08:45 morgan coretemp0: <CPU On-Die Thermal Sensors> on cpu0
Dec 9 11:08:45 morgan est0: <Enhanced SpeedStep Frequency Control> on cpu0
Dec 9 11:08:45 morgan est: CPU supports Enhanced Speedstep, but is not recognized.
Dec 9 11:08:45 morgan est: cpu_vendor GenuineIntel, msr 25ca00001e00
Dec 9 11:08:45 morgan device_attach: est0 attach returned 6
Dec 9 11:08:45 morgan p4tcc0: <CPU Frequency Thermal Control> on cpu0
Dec 9 11:08:45 morgan coretemp1: <CPU On-Die Thermal Sensors> on cpu1
Dec 9 11:08:45 morgan est1: <Enhanced SpeedStep Frequency Control> on cpu1
Dec 9 11:08:45 morgan device_attach: est1 attach returned 6
Dec 9 11:08:45 morgan p4tcc1: <CPU Frequency Thermal Control> on cpu1
Dec 9 11:08:45 morgan ZFS filesystem version: 5
Dec 9 11:08:45 morgan ZFS storage pool version: features support (5000)
Dec 9 11:08:45 morgan Timecounters tick every 1.000 msec
Dec 9 11:08:45 morgan ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
Dec 9 11:08:45 morgan DUMMYNET 0xfffffe0007352d80 with IPv6 initialized (100409)
Dec 9 11:08:45 morgan load_dn_sched dn_sched FIFO loaded
Dec 9 11:08:45 morgan load_dn_sched dn_sched PRIO loaded
Dec 9 11:08:45 morgan load_dn_sched dn_sched QFQ loaded
Dec 9 11:08:45 morgan load_dn_sched dn_sched RR loaded
Dec 9 11:08:45 morgan load_dn_sched dn_sched WF2Q+ loaded
Dec 9 11:08:45 morgan usbus0: 480Mbps High Speed USB v2.0
Dec 9 11:08:45 morgan usbus1: 12Mbps Full Speed USB v1.0
Dec 9 11:08:45 morgan usbus2: 480Mbps High Speed USB v2.0
Dec 9 11:08:45 morgan ugen0.1: <Intel> at usbus0
Dec 9 11:08:45 morgan uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
Dec 9 11:08:45 morgan ugen1.1: <0x103c> at usbus1
Dec 9 11:08:45 morgan uhub1: <0x103c UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
Dec 9 11:08:45 morgan ugen2.1: <Intel> at usbus2
Dec 9 11:08:45 morgan uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
Dec 9 11:08:45 morgan uhub1: 2 ports with 2 removable, self powered
Dec 9 11:08:45 morgan ada0 at ata2 bus 0 scbus0 target 0 lun 0
Dec 9 11:08:45 morgan ada0: <ST1000DM003-1CH162 CC47> ATA-9 SATA 3.x device
Dec 9 11:08:45 morgan ada0: Serial Number Z1D620VL
Dec 9 11:08:45 morgan ada0: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec 9 11:08:45 morgan ada0: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
Dec 9 11:08:45 morgan ada0: quirks=0x1<4K>
Dec 9 11:08:45 morgan ada0: Previously was known as ad4
Dec 9 11:08:45 morgan ada1 at ata2 bus 0 scbus0 target 1 lun 0
Dec 9 11:08:45 morgan ada1: <ST1000DM003-1CH162 CC47> ATA-9 SATA 3.x device
Dec 9 11:08:45 morgan ada1: Serial Number Z1D69XJG
Dec 9 11:08:45 morgan ada1: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
Dec 9 11:08:45 morgan ada1: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
Dec 9 11:08:45 morgan ada1: quirks=0x1<4K>
Dec 9 11:08:45 morgan ada1: Previously was known as ad5
Dec 9 11:08:45 morgan ada2 at ata3 bus 0 scbus1 target 0 lun 0
Dec 9 11:08:45 morgan ada2: <ST1000DM003-1CH162 CC47> ATA-9 SATA 3.x device
Dec 9 11:08:45 morgan ada2: Serial Number Z1D67ZJ7
Dec 9 11:08:45 morgan ada2: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec 9 11:08:45 morgan ada2: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
Dec 9 11:08:45 morgan ada2: quirks=0x1<4K>
Dec 9 11:08:45 morgan ada2: Previously was known as ad6
Dec 9 11:08:45 morgan cd0 at ata5 bus 0 scbus3 target 0 lun 0
Dec 9 11:08:45 morgan cd0: <hp DVD A DU8D4SH MHE4> Removable CD-ROM SCSI-0 device
Dec 9 11:08:45 morgan cd0: Serial Number 648241041933
Dec 9 11:08:45 morgan cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes)
Dec 9 11:08:45 morgan cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed
Dec 9 11:08:45 morgan ada3 at ata3 bus 0 scbus1 target 1 lun 0
Dec 9 11:08:45 morgan ada3: <ST1000DM003-1CH162 CC47> ATA-9 SATA 3.x device
Dec 9 11:08:45 morgan ada3: Serial Number Z1D6ALGV
Dec 9 11:08:45 morgan ada3: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
Dec 9 11:08:45 morgan ada3: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
Dec 9 11:08:45 morgan ada3: quirks=0x1<4K>
Dec 9 11:08:45 morgan ada3: Previously was known as ad7
Dec 9 11:08:45 morgan SMP: AP CPU #1 Launched!
Dec 9 11:08:45 morgan Timecounter "TSC-low" frequency 1496632514 Hz quality 1000
Dec 9 11:08:45 morgan uhub0: 2 ports with 2 removable, self powered
Dec 9 11:08:45 morgan uhub2: 2 ports with 2 removable, self powered
Dec 9 11:08:45 morgan ugen0.2: <vendor 0x8087> at usbus0
Dec 9 11:08:45 morgan uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
Dec 9 11:08:45 morgan ugen2.2: <vendor 0x8087> at usbus2
Dec 9 11:08:45 morgan uhub4: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus2
Dec 9 11:08:45 morgan Root mount waiting for: usbus2 usbus0
Dec 9 11:08:45 morgan uhub3: 6 ports with 6 removable, self powered
Dec 9 11:08:45 morgan uhub4: 6 ports with 6 removable, self powered
Dec 9 11:08:45 morgan Root mount waiting for: usbus0
Dec 9 11:08:45 morgan ugen0.3: <SanDisk> at usbus0
Dec 9 11:08:45 morgan umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.00/1.26, addr 3> on usbus0
Dec 9 11:08:45 morgan umass0: SCSI over Bulk-Only; quirks = 0x4100
Dec 9 11:08:45 morgan umass0:5:0:-1: Attached to scbus5
Dec 9 11:08:45 morgan da0 at umass-sim0 bus 0 scbus5 target 0 lun 0
Dec 9 11:08:45 morgan da0: <SanDisk Cruzer Fit 1.26> Removable Direct Access SCSI-5 device
Dec 9 11:08:45 morgan da0: Serial Number 4C532000070406116310
Dec 9 11:08:45 morgan da0: 40.000MB/s transfers
Dec 9 11:08:45 morgan da0: 30532MB (62530624 512 byte sectors: 255H 63S/T 3892C)
Dec 9 11:08:45 morgan da0: quirks=0x2<NO_6_BYTE>
Dec 9 11:08:45 morgan ugen0.4: <Dell> at usbus0
Dec 9 11:08:45 morgan ukbd0: <Dell Dell USB Keyboard, class 0/0, rev 1.10/3.01, addr 4> on usbus0
Dec 9 11:08:45 morgan kbd2 at ukbd0
Dec 9 11:08:45 morgan Trying to mount root from zfs:freenas-boot/ROOT/default []...
Dec 9 11:08:45 morgan GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
Dec 9 11:08:45 morgan ipmi0: <IPMI System Interface> port 0xca2-0xca3 on acpi0
Dec 9 11:08:45 morgan ipmi0: KCS mode found at io 0xca2 on acpi
Dec 9 11:08:45 morgan ipmi0: KCS error: ff
Dec 9 11:08:45 morgan ipmi0: IPMI device rev. 1, firmware rev. 1.55, version 2.0
Dec 9 11:08:45 morgan ipmi0: Number of channels 1
Dec 9 11:08:45 morgan ipmi0: Attached watchdog
Dec 9 11:08:45 morgan ipmi1: <IPMI System Interface> on isa0
Dec 9 11:08:45 morgan device_attach: ipmi1 attach returned 16
Dec 9 11:08:45 morgan notifier: collectd not running?
Dec 9 11:08:46 morgan notifier: ls: /var/db/system: No such file or directory
Dec 9 11:08:47 morgan notifier: collectd not running?
Dec 9 11:08:47 morgan notifier: Starting collectd.
Dec 9 11:08:49 morgan notifier: kern.corefile: %N.core -> /var/db/system/cores/%N.core
Dec 9 11:13:07 morgan ugen0.4: <Dell> at usbus0 (disconnected)
Dec 9 11:13:07 morgan ukbd0: at uhub3, port 2, addr 4 (disconnected)
Dec 10 00:00:00 morgan syslog-ng[1668]: Configuration reload request received, reloading configuration;
generaltablet
Thanks. I see that you now need to use SSL/TLS to connect to AD. How is that accomplished? And how does one determine what the idmap backend set to? Sorry, beginner here.
generaltablet
I should note that everything is good with the shares except for the AD authentication. I'm able to access the shares from the Windows machines as the FreeNAS root.
D
dlavigne
Guest
Good! I'm trying to get instructions on how to answer your comment #5 and will add them to the docs when I find out.
J
jkh
Guest
Actually, I was totally wrong about that. :( This has nothing to do with SSL/TLS and AD can't be configured that way. Just LDAP. I was over-generalizing from the LDAP case. Not sure what's going on here! The previously cited bug is now in John's queue.
generaltablet
I now recall that somewhere under System settings previously there was something to select which indicated use of AD. I can't seem to find it now. Could it be that I don't have that properly set now in addition to the configurations shown in the attached? I believe the attached are the only places in the current web interface where AD info appears. I'm beginning to suspect that I'm just missing something.
drinking12many
The thing I see on mine is if I do a wbinfo or run the cache.py of whatever its called I see my users so AD is responding. Its whatever seems to move that to passwd or groups that fails. i tried switching my idmap to RID as some suggested for similar issues but when I do and restart cifs it reverts back to tdb.
