2fa not working after update from Core to Scale
kjw638
I upgraded from Core to Scale recently. I was not using 2fa prior to the upgrade, but I decided to implement it post-upgrade. However, when I try to enable 2fa, I get the error show in the screenshot attached: [ENOMETHOD] Method 'provisioning_uri' not found in 'auth.twofactor.' I note also that when I reveal the "Secret," it says "undefined" (I think there should be some code there or something, yes?).
As an unrelated aside, it was necessary to re-enable SMB following the upgrade in order to re-map shares.
Otherwise, I was super elated at the seamlessness of the entire platform upgrade. :)
Kate
