I have freenas installed, but i'm not sure if i'm doing it right.
I'm not sure if i need to use zvols or datasets. i'm currently using 2x3tb in mirror. i created 1 volume and 4 datasets for all the users and for jail. should i use zvol instead? if 1 user uploads something and i install a plugin, and the same user uploads again. are the datasets spread out?
I'm also trying to get 2 virtualmachines running, but i'm not sure if i also need to use zvol for the jail (if the virtualmachine is installed in a jail). Is it possible to use control the virtualmachine on a different computer on the network on wifi?
I'm also have transfer speed problems. the ports on the motherboard are both 1 Gb/s (i217m and i210at) but the router is 100Mb/s. when transfering it peaks at 12 Mb/s (the limit of 100mb/s) but most of the time it is at 3Mb/s. I tried different compression and no compression but still the same problem. There was no difference in speed with or without compression
sorry for my really bad english :(.
xeon 1230v3
16gb ecc ram
2x3tb
xeon 1230v3
16gb ecc ram
2x3tb
